I am working with a KNX-binding, visualized on Basic UI and iOS. Everything works fine so far, but I am not able to get dimmer state working.
My item looks like this: Dimmer H2_Licht_Eltern_Decke "Eltern Decke [%d %%]" (H2_Eltern) { knx="0/1/210+<0/1/212, 0/1/211, 0/1/213+<0/1/214" }
Thus the label-text will appear as “Eltern Decke” and I don’t get the current dimming state visualized, although I can see it as a number in the log files as well as in myopenhab.
Try the following:
use the label=“Eltern Decke [%d %%]” also in your sitemap file
and/or
Use a Switch in the sitemap instead of the Dimmer (The item definition remains a Dimmer)
not sure if this will help
Your item config looks good. The KNX syntax is correct for the listeningGAs…
