Dishwasher price calculation automation
Here’s a small example of how I have used the Miele and HTTP bindings to automate calculation and execution of running the dishwasher during the night when the electricity prices are lowest. The implementation uses rates from https://www.energidataservice.dk/ provided in JSON format, so the concrete implementation is quite tailored to my needs.
The example could serve as inspiration though - and I could get lucky as well and receive feedback for improvements/other ways of doing things. :slight_smile:
Prerequisites
For the concrete usage of the Miele binding, this pull request is needed in order to provide stable start/end times for scheduled program to avoid recalculations each minute:
Notes
I have everything implemented (for now) as DSL rules with limitations in terms of reuse etc. I would love to have implemented it using jsscripting, but unfortunately memory leaks are still preventing this. Additionally, the algorithms use brute force and there is room for optimizations.
Setup
http.things
Thing http:url:energidataservice "EnergiDataService" [ baseURL="https://api.energidataservice.dk/dataset/Elspotprices?start=%1$tY-%1$tm-%1$td&filter={\"PriceArea\":\"DK1\"}&columns=HourUTC,SpotPriceDKK", refresh=3600] {
        Channels:
                Type string : records
http.items
String EnergiDataService_Records { channel = "http:url:energidataservice:records" }
miele.items
Number Dishwasher_RawState "Raw state" (Dishwasher) ["Point"] {channel="miele:dishwasher:home:dishwasher:rawState"}
Number Dishwasher_RawProgram "Raw program" (Dishwasher) ["Point"] {channel="miele:dishwasher:home:dishwasher:rawProgram"}
DateTime Dishwasher_StartTime "Start time [%1$td.%1tm.%1$tY %1$tR]" <time> (Dishwasher) ["Point"] {channel="miele:dishwasher:home:dishwasher:start"}
DateTime Dishwasher_EndTime "End time [%1$td.%1tm.%1$tY %1$tR]" <time> (Dishwasher) ["Point"] {channel="miele:dishwasher:home:dishwasher:end"}
DateTime Dishwasher_CalculatedStartTime "Calculated start time [%1$td.%1tm.%1$tY %1$tR]" <time> (Dishwasher)
Number Dishwasher_CalculatedPrice "Calculated price [%.2f kr.]" <price> (Dishwasher)
Rules
First a generic rule which assumes a linear energy consumption during the program.
rule "Calculate dishwasher start time based on lowest price"
    Item EnergiDataService_Records changed or
    Item Dishwasher_StartTime changed or
    Item Dishwasher_EndTime changed or
    Item Dishwasher_RawState changed to 4 // Waiting to start
    if (Dishwasher_RawState.state != 4) // Waiting to start
        return
    // Use dedicated rule for the ECO program.
    if (Dishwasher_RawProgram.state == 28) // ECO
        return
    val DateTimeType startTimeState = (Dishwasher_StartTime.state as DateTimeType)
    val DateTimeType endTimeState = (Dishwasher_EndTime.state as DateTimeType)
    if (startTimeState == UNDEF || endTimeState == UNDEF)
        return
    val ZonedDateTime startTimeZoned = startTimeState.getZonedDateTime()
    val ZonedDateTime endTimeZoned = endTimeState.getZonedDateTime()
    if (endTimeZoned.isBefore(startTimeZoned))
        return
    val Instant programmedStart = startTimeZoned.toInstant()
    val Instant programmedEnd = endTimeZoned.toInstant()
    val Duration programDuration = Duration.between(programmedStart, programmedEnd)
    logInfo("Dishwasher", "Starting rate/timeslot calculation for program "
        + LocalDateTime.ofInstant(programmedStart, ZoneId.systemDefault()).toString + " - "
        + LocalDateTime.ofInstant(programmedEnd, ZoneId.systemDefault()).toString)
    var calcStart = now.toInstant().plusSeconds(60).truncatedTo(ChronoUnit.MINUTES)
    var calcEnd = calcStart.plusSeconds(programDuration.getSeconds())
    val String json = (EnergiDataService_Records.state as StringType).toString
    val Number numRows = Integer::parseInt(transform("JSONPATH", "$.total", json))
    var Instant cheapestStart
    var Number cheapestPrice = 99999999
    val HashMap<Instant, Number> priceMap = new HashMap()
    for (var i = 0; i < numRows; i++)
        val Instant hourStart = Instant.parse(transform("JSONPATH", "$.records[" + i + "].HourUTC", json) + "Z")
        val Number hourPrice = Float::parseFloat(transform("JSONPATH", "$.records[" + i + "].SpotPriceDKK", json))
        priceMap.put(hourStart, hourPrice)
    while (calcEnd.compareTo(programmedEnd) <= 0)
        var Instant hourStart = calcStart.truncatedTo(ChronoUnit.HOURS)
        var Instant hourEnd   = hourStart.plus(1, ChronoUnit.HOURS)
        var Number price = 0
        while (calcStart.isBefore(hourEnd) && calcEnd.isAfter(hourStart))
            var Instant priceStart = hourStart
            if (calcStart.isAfter(priceStart))
                priceStart = calcStart
            var Instant priceEnd = hourEnd
            if (calcEnd.isBefore(priceEnd))
                priceEnd = calcEnd
            val Number hourPrice = priceMap.get(hourStart)
            if (hourPrice === null)
                logWarn("Dishwasher", "Unable to perform rate/timeslot calculation for upcoming program: "
                    + ": missing rate for " + hourStart.toString)
                return
            var Number seconds = Duration.between(priceStart, priceEnd).getSeconds
            price += (hourPrice * (seconds/3600))
            hourStart = hourStart.plus(1, ChronoUnit.HOURS)
            hourEnd = hourEnd.plus(1, ChronoUnit.HOURS)
        if (price < cheapestPrice)
            cheapestPrice = price
            cheapestStart = calcStart
        else if (price == cheapestPrice && calcStart.isBefore(cheapestStart))
        // Now fast forward to the nearest start or end intersecting with a different hourly rate.
        val Instant nextStartHour = calcStart.plus(1, ChronoUnit.HOURS).truncatedTo(ChronoUnit.HOURS)
        val Instant nextEndHour = calcEnd.plus(1, ChronoUnit.HOURS).truncatedTo(ChronoUnit.HOURS)
        if (calcStart.until(nextStartHour, ChronoUnit.SECONDS) < calcEnd.until(nextEndHour, ChronoUnit.SECONDS))
            calcStart = nextStartHour
        else
            calcEnd = nextEndHour
            calcStart = calcEnd.minusSeconds(programDuration.getSeconds())
    if (cheapestStart === null)
            + LocalDateTime.ofInstant(programmedStart, ZoneId.systemDefault()).toString)
        return
    logInfo("Dishwasher", "Finished rate/timeslot calculation with cheapest: " + cheapestPrice.toString + " with start "
        + LocalDateTime.ofInstant(cheapestStart, ZoneId.systemDefault()).toString)
    if (Duration.between(cheapestStart, programmedStart).toMinutes < 2)
        logInfo("Dishwasher", "Best timeslot is same as already programmed, skipping override.")
    else
        val cheapestDt = new DateTimeType(ZonedDateTime.ofInstant(cheapestStart, ZoneId.systemDefault()))
        Dishwasher_CalculatedStartTime.postUpdate(cheapestDt)
Next rule is based on a mapped program where I have used the powerConsumption channel to record 0.1 kWh data points to know exactly when the program uses the energy:
2022-09-16 02:01:31.420, 0.0
2022-09-16 02:37:13.428, 0.1
2022-09-16 02:45:05.096, 0.2
2022-09-16 02:49:15.462, 0.3
2022-09-16 02:51:35.576, 0.4
2022-09-16 02:55:28.788, 0.5
2022-09-16 03:31:06.045, 0.6
2022-09-16 04:12:54.429, 0.7
This makes it possible to perform a much more accurate calculation and better fit the program into the lowest price intervals.
The result will usually be quite different from the generic calculation, because the appliance actually doesn’t use any significant energy during the last 1:45 of the ECO program. Also, the concrete price is calculated, because it is known exactly how much energy is used by the program.
rule "Calculate dishwasher start time based on lowest accurate price (ECO)"
        return
    if (Dishwasher_RawProgram.state != 28) // ECO
        return
    // Timetable for program, 0.1 kWh consumed after each duration.
    val ArrayList<Duration> phases = new ArrayList<Duration>()
    phases.add(Duration.ofMinutes(37))
    phases.add(Duration.ofMinutes(8))
    phases.add(Duration.ofMinutes(4))
    phases.add(Duration.ofMinutes(2))
    phases.add(Duration.ofMinutes(36))
    phases.add(Duration.ofMinutes(41))
        return
        return
    var Number lowestPrice = 99999999
    var Number highestPrice = 0
        var Instant calcPartStart = calcStart
        var Instant calcPartEnd
        var Number calcPrice = 0
        var long minSecondsUntilNextHour = 60*60
        for (var i = 0; i < phases.size(); i++)
            val Duration current = phases.get(i)
            calcPartEnd = calcPartStart.plus(current)
            var Instant hourStart = calcPartStart.truncatedTo(ChronoUnit.HOURS)
            // Get next intersection with hourly rate change.
            var long secondsUntilNextHour = Duration.between(calcPartStart, hourEnd).getSeconds
            if (secondsUntilNextHour < minSecondsUntilNextHour)
                minSecondsUntilNextHour = secondsUntilNextHour
            var Number partPrice = 0
            while (calcPartStart.isBefore(hourEnd) && calcPartEnd.isAfter(hourStart))
                    return
                var Instant subPartStart = hourStart
                if (calcPartStart.isAfter(subPartStart))
                    subPartStart = calcPartStart
                var Instant subPartEnd = hourEnd
                if (calcPartEnd.isBefore(subPartEnd))
                    subPartEnd = calcPartEnd
                var Number subPartSeconds = Duration.between(subPartStart, subPartEnd).getSeconds
                var Number partSeconds = Duration.between(calcPartStart, calcPartEnd).getSeconds
                partPrice += (hourPrice / 10 * (subPartSeconds / partSeconds))
            calcPrice += partPrice
            calcPartStart = calcPartEnd
        if (calcPrice < lowestPrice)
            lowestPrice = calcPrice
        else if (calcPrice == lowestPrice && calcStart.isBefore(cheapestStart))
        if (calcPrice > highestPrice)
            highestPrice = calcPrice
        // Now fast forward to next hourly rate intersection.
        calcStart = calcStart.plusSeconds(minSecondsUntilNextHour)
        return
    // Convert to kr. and add VAT.
    lowestPrice  = lowestPrice  * 1.25 / 1000
    highestPrice = highestPrice * 1.25 / 1000
    logInfo("Dishwasher", "Finished rate/timeslot calculation with lowest price " + lowestPrice.toString + ", starting "
        + LocalDateTime.ofInstant(cheapestStart, ZoneId.systemDefault()).toString + ". Highest price was: " + highestPrice.toString)
    else
        Dishwasher_CalculatedPrice.postUpdate(lowestPrice)
And finally some rules for maintenance, notifications and triggering of the program at the right time:
rule "Send notification after dishwasher calculation"
    Item Dishwasher_CalculatedStartTime changed
    if (Dishwasher_CalculatedStartTime.state == NULL || Dishwasher_CalculatedStartTime.state == UNDEF)
        return
    val DateTimeType calculatedStartTimeState = (Dishwasher_CalculatedStartTime.state as DateTimeType)
    val LocalDateTime calculatedStartTime = calculatedStartTimeState.getZonedDateTime().toLocalDateTime()
    val DateTimeFormatter formatter = DateTimeFormatter.ofPattern("dd-MM-yyyy HH:mm")
    if (Dishwasher_CalculatedPrice.state != UNDEF)
        sendPushMessage.apply("Dishwasher", "Program start changes to "
            + calculatedStartTime.format(formatter).toString + " after calculation of lowest price: "
            + String.format("%.2f", (Dishwasher_CalculatedPrice.state as Number).doubleValue).replace(".", ",")
            + " kr.")
    else
        + calculatedStartTime.format(formatter).toString + " after calculation of lowest price.")
rule "Start dishwasher based on calculated price"
    Time cron "0 0/1 * * * ?" or
        return
        return
    val ZonedDateTime calculatedStart = (Dishwasher_CalculatedStartTime.state as DateTimeType).getZonedDateTime()
    if (now.isBefore(calculatedStart))
        return
    logInfo("Dishwasher", "Starting program ahead of time to get lower electricity price")
    Dishwasher_Switch.sendCommand(ON)
rule "Clear calculated start time for dishwasher"
    Item Dishwasher_RawState changed from 4 // Waiting to start
    Dishwasher_CalculatedStartTime.postUpdate(UNDEF)
    Dishwasher_CalculatedPrice.postUpdate(UNDEF)
One last note: When my Miele dishwasher is started this way, for some reason it will stay in the last phase: Finished with remaining 0:00. So it needs to be manually turned on and off again to get out of the state.
