I’ve started tinkering with Openhab on the RancherOS/Docker system and tried to install the IpCamera binding (IpCamera, @matt1). It throws an error:
2020-01-02 19:08:30.056 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/openhab/addons/org.openhab.binding.ipcamera-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.ipcamera [235]
Unresolved requirement: Require-Capability: osgi.extender; filter:="(&(osgi.extender=osgi.component)(version>=1.4.0)(!(version>=2.0.0)))"
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) [?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [9:org.apache.felix.fileinstall:3.6.4]
What I can’t tell is if this is an issue with something missing in the docker base image, Openhab image or something in the IpCamera binding. I think think it is a dependency that has to be added within Openhab, but I don’t recall adding it when originally setting up IpCamera binding.
Any thoughts?
