Doing it smarter - help with rule code rollershutter automation
I wonder if I could ask you to have a look on my rule code for my automatic shadowing with the rollershutters. It is working so far but I have a feeling, it is very C64 style.
Thanks for your help
var boolean development = false
var Number schliesswertGr = 80
var Number schliesswertKl = 75
var Number aussentempschwelle = 15
rule "Temperatur Differenz Aussen"
Item TemperatureAussenHinten received update
or
Item TemperatureAussenVorne received update
or
Item HeatPump_Temperature_1 received update
or
Item RolloAutomatik changed to ON
//Temperaturdifferenz berechnen und senden
var Number TempAussenVorne = (TemperatureAussenVorne.state)
var Number TempAussenHinten = (TemperatureAussenHinten.state)
var Number TempAussDiff = (TempAussenVorne - TempAussenHinten)
var boolean sonne = (Sun.state)
if (sonne == ON) sonne = true
else sonne = false
//Azimuth und Elivation auslesen
var Number AzimuthNow = (Azimuth.state)
var Number ElevationNow = (Elevation.state)
var Number Diff = (TempAussenHinten - TempAussDiff)
var Number tau = 0.05 // Glaettungsfaktor, 1 waere keine Glaettung
TempAussDiff = TempAussDiff + (tau * Diff)
TemperatureAussenDifferenz.postUpdate(TempAussDiff)
if (TempAussDiff >= 6 && RolloAutomatik.state == ON && TemperatureAussenHinten.state > aussentempschwelle && sonne == false || sonne && TempAussDiff >= 3 && RolloAutomatik.state == ON && TemperatureAussenHinten.state > aussentempschwelle || development ) {
    sonne = true
    Sun.postUpdate(ON)
    if (ElevationNow < 45 && ElevationNow > 0) {
        if (AzimuthNow > 105 && AzimuthNow < 196) {
            AziOGSued.sendCommand(ON)
            AziEGSued.sendCommand(ON)
            AziOGWest.sendCommand(OFF)
            AziEGWest.sendCommand(OFF)
            AziEGSuedMitte.sendCommand(ON)
        if (AzimuthNow > 196 && AzimuthNow < 270) {
            AziOGWest.sendCommand(ON)
            AziEGWest.sendCommand(ON)
        if (AzimuthNow > 270 && AzimuthNow < 350) {
            AziOGSued.sendCommand(OFF)
            AziEGSued.sendCommand(OFF)
            AziEGSuedMitte.sendCommand(OFF)
    else if (ElevationNow > 45 && ElevationNow < 80) {
        if (AzimuthNow > 100 && AzimuthNow < 196) {
else if (TempAussDiff < 3 && sonne) {
    Thread::sleep(300000) // schlafe 5 minuten
    if (TempAussDiff < 3) {
        sonne = false
        Sun.postUpdate(OFF)
else {
    AziOGSued.postUpdate(OFF)
    AziEGSued.postUpdate(OFF)
    AziEGSuedMitte.postUpdate(OFF)
    AziOGWest.postUpdate(OFF)
    AziEGWest.postUpdate(OFF)
rule "Rolladen AziOGSued"
Item AziOGSued received command ON
SchlafzimmerRollo_S.sendCommand(schliesswertKl)
KindMaxRollo_S.sendCommand(schliesswertKl)
rule "Rolladen AziOGWest"
Item AziOGWest received command ON
KindEmmiRollo_W.sendCommand(schliesswertGr)
rule "Rolladen AziEGSued"
Item AziEGSued received command ON
WohnzimmerRollo_SW.sendCommand(schliesswertGr)
WohnzimmerRollo_SO.sendCommand(schliesswertGr)
rule "Rolladen AziEGWest"
Item AziEGWest received command ON
WohnzimmerRollo_W.sendCommand(schliesswertGr)
BueroRollo_W.sendCommand(schliesswertGr)
rule "Rolladen AziEGSuedMitte"
Item AziEGSuedMitte received command ON
var aussperrschutz = WohnzimmerFenster_S.state
if (aussperrschutz == NULL){
    aussperrschutz = 'OPEN'
if (aussperrschutz == 'CLOSED'){
    WohnzimmerRollo_S.sendCommand(schliesswertGr)
// OFF RULES
Item AziOGSued received command OFF
if ()
SchlafzimmerRollo_S.sendCommand(0)
KindMaxRollo_S.sendCommand(0)
Item AziOGWest received command OFF
KindEmmiRollo_W.sendCommand(0)
//KindMaxRollo_W.sendCommand(0)
Item AziEGSued received command OFF
WohnzimmerRollo_SW.sendCommand(0)
WohnzimmerRollo_SO.sendCommand(0)
Item AziEGWest received command OFF
WohnzimmerRollo_W.sendCommand(0)
BueroRollo_W.sendCommand(0)
Item AziEGSuedMitte received command OFF
WohnzimmerRollo_S.sendCommand(0)
Personally, putting parens around things that don’t need parens is asking for trouble and it makes the code harder to read. So, for example,
would be
var Number TempAussenVorne = TemperatureAussenVorne.state
Review Design Pattern: How to Structure a Rule. I think this Rule might benefit from this. It could at least make it shorter a bit. But beyond that there isn’t a whole lot you can do to simplify this using normal straight forward means.
There might be something clever we can do here though to split up the complexity. For example, separate the calculation of the Azimuth/Elevation into it’s own Rules as described in Design Pattern: Separation of Behaviors and Design Pattern: Simple State Machine (e.g. Time Of Day). Create a name for each of the six states represented by the elevation and azimuth (perhaps seven states for when the elevation/azimuth doesn’t fit one of the states you care about). This goes into it’s own Rule triggered by changes to the Elevation and Azimuth.
In your “Temperatur Differenz Aussen” Rule, you only need to test the temp and use a switch statement for the state calculated above.
Next you can use clever naming and Groups to further simplify the Rule. Create two Groups for each state calculated above, one for ON and one for OFF. Then you can use Design Pattern: Associated Items to send the ON and OFF commands based on the calculated state. Put the appropriate Items into each Group.
It will look something like this.
Since I don’t know appropriate names that make sense I’ll just use “ONE”, “TWO” etc for the elevation/azimuth states.
Items:
String EleAzm
Group:Switch EleAzm_ONE_ON
Group:Switch EleAzm_ONE_OFF
Group:Switch EleAzm_TWO_ON
Group:Switch EleAzm_TWO_OFF
// and so on
Group:Switch All_RS // all Azi Items are members of this Group
Switch AziOGSued ... (All_RS, EleAzm_ONE_ON, EleAzm_TWO_ON, EleAzm_THREE_OFF, EleAzm_FOUR_OFF, EleAzm_Five_OFF, EleAzm_SIX_OFF) ...
Switch AziEGSued ... (All_RS, EleAzm_ONE_ON, EleAzm_TWO_ON, EleAzm_THREE_OFF, EleAzm_FOUR_ON, EleAzm_FIVE_ON, EleAzm_SIX_ON) ...
// and so on
rule "Calculate EleAzm state"
    Item Elevatio changed or
    Item Aziuth changed
    val newState = "NONE"
    if(Elevation.state < 45 && Elevation.state > 0) {
        if(Azimuth.state > 105 && Azimuth.state < 196) newState = "ONE"
        if(Azimuth.state >196 && Azimuth.state < 270) newState = "TWO"
        if(Azimuth.state >270 && Azimuth.state < 350) newState = "THREE"
    else if(Elevation.state > 45 && Elevation.state > 80) {
        if(Azimuth.state > 105 && Azimuth.state < 196) newState = "FOUR"
        if(Azimuth.state >196 && Azimuth.state < 270) newState = "FIVE"
        if(Azimuth.state >270 && Azimuth.state < 350) newState = "SIX"
    // NOTE: We could be clever here to avoid the duplicated code but I don't
    // see the need for it here.
    if(EleAzm.state != newState) EleAzm.postUpdate(newState)
    Item TemperatureAussenHinten received update or
    Item TemperatureAussenVorne received update or
    Item HeatPump_Temperature_1 received update or
    // all the calculations at the top remain the same only you don't need
    // AzimuthNow and ElevationNow any longer
        sonne == false ||
        sonne &&
        development ) {
        sonne = true
        Sun.postUpdate(ON)
        // Here is the clever part that takes advantage of the Groups and the state we set up above
        if(EleAzm.state.toString != "NONE") {
            sendCommand("EleAzm_"+EleAzm.state.toString+"_ON", "ON")
            sendCommand("EleAzm_"+EleAzm.state.toString+"_OFF", "OFF")
        createTimer(now.plusMinutes(5), [ | // Never sleep for more than 500 msec. If you need to delay the execution of some commands, create a Timer instead.
            if (TempAussDiff < 3) { // woudn't you want to recalculate the temp diff now that it's five minutes later?
                sonne = false
                Sun.postUpdate(OFF)
                All_RS.sendCommand(OFF) // sends OFF to all the Azi Items
    else All_RS.sendCommand(OFF) // sends OFF to all Azi Items
You can consolidate your ON and OFF Rules but I’m not sure it buys you much.
NOTE: I just typed in the above without even using VSCode. It’s not complete (see the … and comments) and likely has errors.
Great , any many thanks! I will try to follow your good to understand hints!
This part is a kind of limiting the number of shutter drives.
If temperature trigger is fired, wait for some minutes to see if it is a stable decrease of temperature or just a short one … therefor I wanted to wait for 5min …
But you don’t ever check it again. You need to recalculate TempAussDiff after the five minutes to see if the diff is still < 3. Otherwise all you are doing is waiting five minutes and using the TempAussDiff calculated five minutes ago.
And like the comment says, you should never sleep for more than 500 msec. Use Timers if you need a longer amount of time. This is what is shown above. See (OH 1.x and OH 2.x Rules DSL only] Why have my Rules stopped running? Why Thread::sleep is a bad idea for details.
Hi
I wanted to give a feedback what my current code looks like. With your help I made it shorter and I reduced complexity a little. The previous precision was too much and I ended up with this.
Most benefit is the dramtically reduced use of homematic Unit work load. I did not liek to use groups because If something is changing or I have to adjust it is easier to do it with the single items.
Thanks again for your help
or
or
Time cron "0 */5 * * * ?"
or
//Azimuth und Elevation auslesen
var Number AzimuthNow = Azimuth.state
var Number ElevationNow = Elevation.state
if (ElevationNow <= 0 && ElevationNow >= 80 || RolloAutomatik.state == OFF || TemperatureAussenHinten.state <= aussentempschwelle || AzimuthNow < 100 && AzimuthNow > 285 ) {
    AziWest.postUpdate(OFF)
    return;
else {
    var Number TempAussDiff = (TemperatureAussenVorne.state as Number) - (TemperatureAussenHinten.state as Number)
    var Number Diff = (TemperatureAussenHinten.state as Number) - (TemperatureAussenDifferenz.state as Number)
    var Number tau = 0.1 // Glaettungsfaktor, 1 waere keine Glaettung
    var Boolean sonne = Sun.state
    else sonne = false
    if (TempAussDiff >= 6 && sonne == false || sonne && TempAussDiff > 3 || development ) {
        sonne = true
        Sun.postUpdate(ON)
            if (ElevationNow > 45) AziOGSued.sendCommand(OFF)
            else (AziOGSued.sendCommand(ON))
        AziWest.sendCommand(OFF)
        AziWest.sendCommand(ON)
        if (AzimuthNow > 270 && AzimuthNow < 285) {
    else if (TempAussDiff <= 3 && sonne) {
        createTimer(now.plusMinutes(5), [ | // schlafe 5 minuten
        if ((TemperatureAussenVorne.state as Number) - (TemperatureAussenHinten.state as Number) + (tau * ((TemperatureAussenHinten.state as Number) - (TemperatureAussenDifferenz.state as Number))) < 3) {
            sonne = false
            Sun.postUpdate(OFF)
// ON RULES
if ( SchlafzimmerRollo_S_OUT.state == 1) SchlafzimmerRollo_S_IN.sendCommand(schliesswertKl)
if ( KindMaxRollo_S_OUT.state == 1) KindMaxRollo_S_IN.sendCommand(schliesswertKl)
rule "Rolladen AziWest"
Item AziWest received command ON
if (log) logInfo("****RolloSteuerung****", "AziWest Kommandos gesendet" + KindEmmiRollo_W_OUT.state)
if ( KindEmmiRollo_W_OUT.state == 1) KindEmmiRollo_W_IN.sendCommand(schliesswertGr)
if ( WohnzimmerRollo_W_OUT.state == 1) {
    WohnzimmerRollo_W_IN.sendCommand(schliesswertGr)
if ( BueroRollo_W_OUT.state == 1) BueroRollo_W_IN.sendCommand(schliesswertGr)
if ( WohnzimmerRollo_SW_OUT.state == 1) WohnzimmerRollo_SW_IN.sendCommand(schliesswertGr)
if ( WohnzimmerRollo_SO_OUT.state == 1) WohnzimmerRollo_SO_IN.sendCommand(schliesswertGr)
if (aussperrschutz == NULL) aussperrschutz = 'OPEN'
if (aussperrschutz == 'CLOSED' && WohnzimmerRollo_S_OUT.state == OFF ) WohnzimmerRollo_S_IN.sendCommand(schliesswertGr)
// OFF RULES
SchlafzimmerRollo_S_IN.sendCommand(1)
KindMaxRollo_S_IN.sendCommand(1)
Item AziWest received command OFF
KindEmmiRollo_W_IN.sendCommand(1)
//KindMaxRollo_W_IN.sendCommand(1)
WohnzimmerRollo_W_IN.sendCommand(1)
BueroRollo_W_IN.sendCommand(1)
WohnzimmerRollo_SW_IN.sendCommand(1)
WohnzimmerRollo_SO_IN.sendCommand(1)
WohnzimmerRollo_S_IN.sendCommand(1)
