Understood! Thanks!
And whitch Door sensors do u use now (besides 433 Mhz Keru)? )))
I mostly made my own:
I gave it a real tryâŠ
I guess i am not cut up to the electronics part
i ended up spending hundreds of dollars on 0.50 cent parts
but its real fun, i guess when i will have more time i will make it work
i will advise staying away from this kind of project, if you donât yet have the skills and you want Home automation working in the near fauture
Or be ready for failuresâŠ
But itâs real fun indeed to make your own hardware and deploy it
There is not less problems with commercial products that costs real money!
I read now reviews on zwave systems on amazon they have average 3,5 stars. How do u think It is ok for door or motion sensor for 50Eur? For example that battery life is 2-3 weeks((
And is it better then 433 interference problem?
I do not know what to choose))) It it a complex World)))
Why does it have to be 433MHz? I have made a solution with Open/close and battery status using an ESP32 and the build-in WiFi. It can run app. 5 years on a battery. It is using MQTT which is build-in in OpenHab.
/Michael
Hi please share
what code are you using?
what sensor?
i have some E32 laying around maybe i will give it a try
it can also report temp right?
The code is homemade, based on freeRTOS (not Arduino) to save power. ESP32 doesnât have a build-in temp sensor. For the window sensor I am using a reed relay and a magnet - pretty standard. Here is a picture of the it.
/Michael
This is just a prototype - it is missing a few components, but is working fine anyway. (I have made a real PCB which is currently in production).
I canât upload the code as c extension is not allowed?
/Michael
Convert it to text or just post it
Why a more expensive esp32 for merely open/close/batt status? Why not a $3 Esp8266-01. I just donât like seeing all the features of esp32 unused. I also suggest OTA on your code to make it easier to update. But overall, nice work
you are right from a design perspective!
but i have one laying around and i have no clue what to do with it hhh
i was able to work with the ESP8266 but not a lot of luck with the 32
i take examples from online projects and most of them are for the 8266
also i think my ESP has a temp sensor built in so maybe i can integrate them both
So i have got zwave stick and zigbee stick with corresponding sensors.
And what do u think?
All of them works maximal 6-7m from stick. They are not usable without addition router.
Is there a ready product, wich i can buy without soldering?
No, you will have to make everything your self, incl. PCB.
/Michael
