I noticed that the IFTTT page was a mere copy of some promotional page that was used in the past.
Below you can find a first updated draft.
Some remarks:
- Removed information on DO button, as this was integrated into the core IFTTT app
- Changed channels to services and recipes to applets (new names from IFTTT)
- Updated links
- Removed outdated images containing old openHAB logo
Would like to add some images (one logo at the start) and some examples at the end, but not a clue how to do this.
Would appreciate input on this initial change.
IFTTT Integration for openHAB
If This Then That (IFTTT) is a very popular web-based service that allows users to create “applets”, which can combine different web services into powerful automation rules. With its hundreds of services, there are limitless new creative options: Be notified through text-to-speech if you are receive a DM on twitter, be warned through your lights if your favorite stock price falls below a certain threshold or put your house in away-mode when you turn on the ignition of your car - you can get further inspiration by browsing through existing applets.
openHAB users can take advantage of IFTTT to realize even more use cases in their smart home!
Besides the new kinds of integration possibilities, IFTTT is also a good start for new openHAB users as it makes the creation of rules dead simple - no need to do any scripting, no complex setup routines, it all works through a few mouse clicks!
insert here openHAB service logo from IFTTT.com
Getting Started
Requirements
- openHAB Cloud Connector configured using myopenHAB.org
- IFTTT account
Configuration
1. Connect openHAB with IFTTT
IFTTT is available to all our users through the myopenHAB service. Activating the integration is easy. Just log in to your IFTTT account and activate the openHAB service. You will be forwarded to the myopenHAB.org website to authorize the IFTTT service connection. You can delete the IFTTT authorization token in the myopenHAB Applications section at any time.
2. Expose specific items to IFTTT
Before you start creating IFTTT applets you need to make sure that you configured your local openHAB runtime to expose certain items to myopenHAB.org. Only those items will be visible to IFTTT. Read here how to expose items to myopenHAB.org. You will also be able to send commands to those items from IFTTT Applets.
Important: Items will appear in myopenHAB and thus in IFTTT only after at least one state update has been received by myopenHAB.org from your local openHAB runtime.
This can be done by for instance creating a simple rule:
rule "Set initial values IFTTT items"
System started
createTimer(now.plusSeconds(160)) [|
logInfo("RULE", "Set initial values IFTTT items")
postUpdate(YourItem, 5)
Some Examples
insert images of openHAB applets.
