After i try to add “vaillant_template.json” i got this error.
10:27:14.381 [WARN ] [.ebus.cfg.std.EBusConfigurationReader] - Property ‘name’ is not allowed for type ‘template-block’, ignore property !
how can i solve it?
how can i solve it?
Hi @Trainer,
the error is comming from the following entrys, try to change “template-block” to “template” or change the name: “slot1” to “slot01”:
“name”: “slot1-3”,
“template”: [
{“name”:“slot1”,“type”:“template-block”,“id”:“vaillant.slot1”},
{“name”:“slot2”,“type”:“template-block”,“id”:“vaillant.slot2”},
{“name”:“slot3”,“type”:“template-block”,“id”:“vaillant.slot3”}
“name”: “timer”,
“template”: [
{“name”:“slot1-3”,“type”:“template-block”,“id”:“vaillant.slot1-3”},
Thank you for your answer.
i tried it, but without luck
here is my change text:
“name”: “slot1-3”,
“template”: [
{“name”:“slot01”,“type”:“template-block”,“id”:“vaillant.slot1”},
{“name”:“slot02”,“type”:“template-block”,“id”:“vaillant.slot2”},
{“name”:“slot03”,“type”:“template-block”,“id”:“vaillant.slot3”}
and if i change template-block to template, i got this error:
11:18:38.292 [ERROR] [sdev.ebus.command.EBusCommandRegistry] - error!
de.csdev.ebus.cfg.EBusConfigurationReaderException: Unable to find a template for id vaillant.slot1!
try to remove the name property:
“name”: “slot1-3”,
“template”:
{“type”:“template-block”,“id”:“vaillant.slot1”},
{“type”:“template-block”,“id”:“vaillant.slot2”},
{“type”:“template-block”,“id”:“vaillant.slot3”}
“name”: “timer”,
“template”:
{“type”:“template-block”,“id”:“vaillant.slot1-3”},
{“name”:“daysel”,“type”:“template”,“id”:“vaillant.templ.daysel”}
@John_Doe thank you.
this fix the problem.
after i add Vaillant VRT 392 json file it got this error:
16:53:14.578 [WARN ] [nding.ebus.thing.EBusTypeProviderImpl] - eBUS command clearerrorhistory only contains a setter channel!
do you also know how to use the configurationBundle?
there i got this error message:
16:51:00.337 [ERROR] [org.apache.felix.configadmin ] - [org.openhab.binding.ebus.thing.EBusTypeProvider, org.eclipse.smarthome.core.thing.binding.ThingTypeProvider, org.eclipse.smarthome.core.thing.type.ChannelTypeProvider, org.eclipse.smarthome.core.thing.type.ChannelGroupTypeProvider, org.osgi.service.cm.ManagedService, id=121, bundle=204/mvn:org.openhab.binding/org.openhab.binding.ebus/2.4.0-SNAPSHOT]: Unexpected problem updating configuration org.openhab.ebus
at de.csdev.ebus.cfg.std.EBusConfigurationReader.parseValueConfiguration(EBusConfigurationReader.java:306) ~[?:?]
at de.csdev.ebus.cfg.std.EBusConfigurationReader.parseTelegramConfiguration(EBusConfigurationReader.java:273) ~[?:?]
at de.csdev.ebus.cfg.std.EBusConfigurationReader.loadConfigurationCollection(EBusConfigurationReader.java:139) ~[?:?]
at de.csdev.ebus.cfg.std.EBusConfigurationReader.loadConfigurationCollection(EBusConfigurationReader.java:114) ~[?:?]
at de.csdev.ebus.cfg.std.EBusConfigurationReader.loadConfigurationCollectionBundle(EBusConfigurationReader.java:512) ~[?:?]
at de.csdev.ebus.command.EBusCommandRegistry.loadCommandCollectionBundle(EBusCommandRegistry.java:112) ~[?:?]
at org.openhab.binding.ebus.thing.EBusTypeProviderImpl.loadConfigurationBundleByUrl(EBusTypeProviderImpl.java:301) ~[?:?]
at org.openhab.binding.ebus.thing.EBusTypeProviderImpl.updateConfiguration(EBusTypeProviderImpl.java:484) ~[?:?]
at org.openhab.binding.ebus.thing.EBusTypeProviderImpl.updated(EBusTypeProviderImpl.java:501) ~[?:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker$1.run(ManagedServiceTracker.java:177) ~[9:org.apache.felix.configadmin:1.9.4]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:173) ~[9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1389) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:126) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:123) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:122) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [9:org.apache.felix.configadmin:1.9.4]
The configurationBundleUrl
parameter is for an index file like https://github.com/csowada/ebus-configuration/blob/master/src/main/resources/index-configuration.json to load a complete set of files.
I would suggest to fork the my configuration repository, work together on a solution and maybe send me a pull request to fix issues.
Since yesterday I test a new version in my productive environment. It looks good so far. I’ll prepare a new release today.
Hi @csowada,
thanks for spending yet another share of your time for this great binding. It works quite well for me, especially putting and displaying some interesting values on my KNX bus. I am using the addresses 08 for general variables, 76 for SM1 and 51 for MM. Have not figured out the additional addresses 0C, 15, 35, 51 and 75 yet.
If I may ask/suggest some small things:
2019-12-28 12:14:38.412 [ERROR] [dev.ebus.core.EBusLowLevelController] - emergency break!!!!
Thanks again for your effort.
Thomas
Hello @tkropf,
I’ve added a commadn in the next release to set the heating mode from a BM1. I can’t check if it works, but you can try it. Feedback are always welcome.
Your other issue with the Solar return temperature,
Try “E1 - Return temp” instead. I use this value for my environment.
I will add the command for heating mode. But completely untested!
Sorry, I have no telegram information to force the DHW
Hallo @All,
I’ve decided to release the eBUS binding! So it is not called Alpha, Beta or RC anymore. Due to the release I’ve started a new thread. Please use this thread for all questions to the new release.
Hi @csowada,
thanks for your quick reply, much appreciated
I tried “E1 - Return temp” , same issue. If I force a read on my BM directly, the correct value shows up in your binding. Thus, SM1 address and variable address seem to work. As soon as I force a polling, the error message occurs. Strange.
I discovered your BM heating program command. Unfortunately, it does not work, same error message as above.
Eventually, I will have to dig myself in the eBus protocol, which I avoided until now (seems pretty tedious). I do have an ancient Wold ISM2 PC interface and a “Wolf WRS Soft” software, thus with an old Win95 laptop I can access and change all values (exampes enclosed). Thus I should be able to log the bus traffic. However, the weather today is too nice
Thomas
Heizgerät.prn.pdf (167.8 KB) Solarkreis.prn.pdf (147.4 KB)
Hi @dkuschmierz, @Peter1984,
I saw that both of you have also a Vaillant VWL. I own a VWL 102/3 S, but I think regarding eBUS codes, it should be identically to yours.
My current situation is, that I did not find any config (json) files for this type. I have ebusd running and can read a lot of values manually. Now, I want to integrate it into openhab using the great binding from csowada (a great thank you for the binding and the support here in the forum).
Did you create already json files which you could share?
Fyi: “ebusctl info” shows me:
version: ebusd 3.4.v3.3-51-g57eae05
signal: acquired
symbol rate: 116
max symbol rate: 141
min arbitration micros: 763
max arbitration micros: 1038
min symbol latency: 5
max symbol latency: 6
reconnects: 0
masters: 3
conditional: 262
poll: 3
update: 59
address 03: master #11
address 08: slave #11, scanned "MF=Vaillant;ID=EHP00;SW=0419;HW=7201", loaded "vaillant/08.ehp.csv"
address 10: master #2
address 15: slave #2, scanned "MF=Vaillant;ID=UIH00;SW=0374;HW=6901", loaded "vaillant/15.uih.csv"
address 23: slave, scanned "MF=Vaillant;ID=EHP00;SW=0419;HW=7201", loaded "vaillant/23.ehp.cc.csv"
address 25: slave, scanned "MF=Vaillant;ID=EHP00;SW=0419;HW=7201", loaded "vaillant/25.ehp.hwc.csv"
address 31: master #8, ebusd
address 36: slave #8, ebusd
address 50: slave, scanned "MF=Vaillant;ID=EHP00;SW=0419;HW=7201", loaded "vaillant/50.ehp.mc.csv"
address e0: slave, scanned "MF=Vaillant;ID=OMU00;SW=0118;HW=5202", loaded "vaillant/e0.omu.csv"
Any help appreciated!
Thanks,
Dieter
Please can you help me to configure vr71?
