Eclipse Issue after upgrade to OH 2.3 - 8080 not reachable any longer
Hi all,
after upgrading to OH 2.3 I ran into an issue. I assume I had eclipse still open while upgrading…
Openhab.log is showing the following message:
Unresolved requirement: Import-Package: javax.inject
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1613) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
I am facing the problem that I can’t reach openhabian:8080 with the browser and I assume that the stated log is causing the issue..Does someone has an Idea where the issue is related to? What can I do to fix this?
Thank you.
Woogi
First try Clear the Cache. Let us know either way if that changed anything.
Hi Rich,
thanks for your link. I already followed that link before. Did it again but still no changes and with
tail -F /var/log/openhab2/openhab.log I still receive:
Any Idea?
short remark:
Checking the status of my system provides me the following information:
**/** $ sudo /etc/init.d/openhab2 status -l
**●** openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: **active (running)** since Wed 2018-08-15 17:51:58 CEST; 3min 57s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 4605 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 4822 (java)
CGroup: /system.slice/openhab2.service
└─4822 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dop...
Aug 15 17:52:34 openHABianPi karaf[4822]: at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.open(ZipBundleFile.java:355)
Aug 15 17:52:34 openHABianPi karaf[4822]: at org.eclipse.osgi.storage.Storage.install(Storage.java:538)
Aug 15 17:52:34 openHABianPi karaf[4822]: ... 11 more
Aug 15 17:52:34 openHABianPi karaf[4822]: Caused by: java.util.zip.ZipException: error in opening zip file
Aug 15 17:52:34 openHABianPi karaf[4822]: at java.util.zip.ZipFile.open(Native Method)
Aug 15 17:52:34 openHABianPi karaf[4822]: at java.util.zip.ZipFile.<init>(ZipFile.java:225)
Aug 15 17:52:34 openHABianPi karaf[4822]: at java.util.zip.ZipFile.<init>(ZipFile.java:155)
Aug 15 17:52:34 openHABianPi karaf[4822]: at java.util.zip.ZipFile.<init>(ZipFile.java:169)
Aug 15 17:52:34 openHABianPi karaf[4822]: at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:304)
Aug 15 17:52:34 openHABianPi karaf[4822]: ... 15 more
I don’t have anything else to suggest except to make a backup and do a clean install. The best I can guess is something went wrong or got corrupted either during the last install or for some other reason (lost power instead of properly shutting down the machine, SD card corruption, etc).
Thanks Rich for your reply.
I searched a bit through the web and the forum and found this post OH2 does not start
This thread is a bit older, but I am facing the exact issue right now. I upgraded from OH 2.3 and facing the same error notifications then described there. My Java Versions are:
openjdk version "1.8.0_152"
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
I checked the permissions, but I do not see any gaps in.
openhabian@openHABianPi:/var/log/openhab2$ ls -al
total 2972
drwxrwxr-x+  2 openhab openhabian    4096 Aug 15 16:06 .
drwxr-xr-x  11 root    root          4096 Aug 15 19:36 ..
-rw-rw-r--   1 openhab openhab          0 Aug 15 16:06 audit.log
-rw-rw-r--   1 openhab openhab     199714 Aug 15 15:20 events.log
-rw-rw-r--   1 openhab openhab    2823052 Aug 15 21:03 openhab.log
-rwxr-xr-x   1 openhab openhab          0 May 28 10:33 Readme.txt
openhabian@openHABianPi:~$ ls -al
total 60
drwxr-xr-x 4 openhabian openhabian 4096 Aug 15 18:38 .
drwxr-xr-x 3 root       root       4096 Apr 10  2017 ..
-rw------- 1 openhabian openhabian 6642 Aug 15 20:47 .bash_history
-rw-r--r-- 1 openhabian openhabian  220 Apr 10  2017 .bash_logout
-rw-r--r-- 1 openhabian openhabian 2615 Oct 14  2017 .bash_profile
-rw-r--r-- 1 openhabian openhabian 3512 Apr 10  2017 .bashrc
-rwx------ 1 openhabian openhabian    0 Aug 15 14:59 .com.apple.timemachine.supported
-rwx------ 1 openhabian openhabian 4096 Aug 15 18:35 ._.DS_Store
-rwx------ 1 openhabian openhabian 8196 Aug 15 18:38 .DS_Store
-rw-r--r-- 1 openhabian openhabian  675 Apr 10  2017 .profile
-rw-r--r-- 1 root       root         89 Oct 14  2017 README.txt
drwx------ 2 openhabian openhabian 4096 Oct 14  2017 .ssh
drwxr-xr-x 4 openhabian openhabian 4096 Oct 14  2017 .vim
This is the issue message I get with sudo journalctl -u openhab2.service -b
Aug 15 19:36:09 openHABianPi systemd[1]: Starting openHAB 2 - empowering the smart home...
    Aug 15 19:36:09 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
    Aug 15 19:36:36 openHABianPi karaf[793]: !SESSION 2018-08-15 19:36:36.526 -----------------------------------------------
    Aug 15 19:36:36 openHABianPi karaf[793]: eclipse.buildId=unknown
    Aug 15 19:36:36 openHABianPi karaf[793]: java.version=1.8.0_152
    Aug 15 19:36:36 openHABianPi karaf[793]: java.vendor=Azul Systems, Inc.
    Aug 15 19:36:36 openHABianPi karaf[793]: BootLoader constants: OS=linux, ARCH=arm, WS=gtk, NL=en_US
    Aug 15 19:36:36 openHABianPi karaf[793]: !ENTRY org.eclipse.osgi 4 0 2018-08-15 19:36:36.529
    Aug 15 19:36:36 openHABianPi karaf[793]: !MESSAGE Error reading configuration: Unable to create lock manager.
    Aug 15 19:36:36 openHABianPi karaf[793]: !STACK 0
    Aug 15 19:36:36 openHABianPi karaf[793]: java.io.IOException: Unable to create lock manager.
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:698)
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.eclipse.osgi.storage.Storage.getChildStorageManager(Storage.java:1776)
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.eclipse.osgi.storage.Storage.getInfoInputStream(Storage.java:1793)
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.eclipse.osgi.storage.Storage.<init>(Storage.java:132)
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:85)
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:68)
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.apache.karaf.main.Main.launch(Main.java:256)
    Aug 15 19:36:36 openHABianPi karaf[793]: at org.apache.karaf.main.Main.main(Main.java:179)
    Aug 15 19:36:36 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=255/n/a
    Aug 15 19:36:40 openHABianPi karaf[1521]: /var/lib/openhab2/tmp/port shutdown port file doesn't exist. The container is not running.
    Aug 15 19:36:40 openHABianPi systemd[1]: openhab2.service: control process exited, code=exited status=3
    Aug 15 19:36:40 openHABianPi systemd[1]: Unit openhab2.service entered failed state.
    Aug 15 19:36:45 openHABianPi systemd[1]: openhab2.service holdoff time over, scheduling restart.
    Aug 15 19:36:45 openHABianPi systemd[1]: Stopping openHAB 2 - empowering the smart home...
    Aug 15 19:36:45 openHABianPi systemd[1]: Starting openHAB 2 - empowering the smart home...
    Aug 15 19:36:45 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
    Aug 15 19:36:50 openHABianPi karaf[1781]: !SESSION 2018-08-15 19:36:50.868 -----------------------------------------------
    Aug 15 19:36:50 openHABianPi karaf[1781]: eclipse.buildId=unknown
    Aug 15 19:36:50 openHABianPi karaf[1781]: java.version=1.8.0_152
Maybe you @waitz_sebastian or @ThomDietrich have an idea? I think there is somewhere the issue that needs to determined and fixed that I can you the program as previous to the upgrade. I would like to prevent from reinstalling openhab2 or openhabian at all.
Thank you for you help,
Kindly,
Woogi.
I doubt you will be able to avoid it frankly. This is a fundamental problem with the stuff that OH runs on top of. Only a failed install or corrupted install would be causing an error like this.
Hi everybody,
I reinstalled everything. Took me 2 hours to setup everything with exec and upload my item/thing and cfg files.
Topic can be closed for now.
Kindly,
Woogi
I am getting a bit frustrated with OH. I setup the system proper based on the manuals, but after running one day proper the connection to the rip got lost completely. So I set the system up again and got again the issue with 8080 not reachable.
System information:
Release = Raspbian GNU/Linux 9 (stretch) → openhabian openhabianpi-raspbian-201804031720-gitdba76f6-crc9e93c3eb.img (image downloaded last week)
Kernel = Linux 4.14.62-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
openHAB 2.3.0-1 (Release Build)
Java Version:
openjdk version “1.8.0_152”
After setting it up I did directly update and upgrade as recommended and a reboot afterwards. Then I executed the following things for my exec binding:
git://git.drogon.net/wiringPi
With the rip I am able to control my switches. So far so good. But now it gets crazy:
I reached the Dash by 8080 and installed the standard configuration. Then I installed some bindings and checked the log. thereby I figured out that sth. is not working proper. During the installation of the standard configuration occurred and issue. As I learned I should clear the cache after stopping OH what I exactly did. After restarting OH I am not able any longer to access 8080.
My logs are:
Aug 19 11:41:32 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
Aug 19 11:42:28 openHABianPi karaf[538]: org.apache.karaf.features.core[org.apache.karaf.features.internal.service.BootFeaturesInstaller] : Error installing boot features
Aug 19 11:42:28 openHABianPi karaf[538]: org.osgi.framework.BundleException: Error occurred installing a bundle.
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.osgi.storage.Storage.install(Storage.java:574)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.osgi.internal.framework.BundleContextImpl.installBundle(BundleContextImpl.java:146)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.equinox.internal.region.BundleIdBasedRegion.installBundle0(BundleIdBasedRegion.java:117)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.equinox.internal.region.BundleIdBasedRegion.installBundleAtLocation(BundleIdBasedRegion.java:97)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.apache.karaf.features.internal.service.FeaturesServiceImpl.installBundle(FeaturesServiceImpl.java:1335)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:771)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1248)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$1(FeaturesServiceImpl.java:1147)
Aug 19 11:42:28 openHABianPi karaf[538]:         at java.util.concurrent.FutureTask.run(FutureTask.java:266)
Aug 19 11:42:28 openHABianPi karaf[538]:         at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
Aug 19 11:42:28 openHABianPi karaf[538]:         at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
Aug 19 11:42:28 openHABianPi karaf[538]:         at java.lang.Thread.run(Thread.java:748)
Aug 19 11:42:28 openHABianPi karaf[538]: Caused by: java.util.zip.ZipException: Exception in opening zip file: /var/lib/openhab2/cache/org.eclipse.osgi/34/0/bundleFile
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:317)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.basicOpen(ZipBundleFile.java:93)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:106)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.open(ZipBundleFile.java:355)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.osgi.storage.Storage.install(Storage.java:538)
Aug 19 11:42:28 openHABianPi karaf[538]:         ... 11 more
Aug 19 11:42:28 openHABianPi karaf[538]: Caused by: java.util.zip.ZipException: error in opening zip file
Aug 19 11:42:28 openHABianPi karaf[538]:         at java.util.zip.ZipFile.open(Native Method)
Aug 19 11:42:28 openHABianPi karaf[538]:         at java.util.zip.ZipFile.<init>(ZipFile.java:225)
Aug 19 11:42:28 openHABianPi karaf[538]:         at java.util.zip.ZipFile.<init>(ZipFile.java:155)
Aug 19 11:42:28 openHABianPi karaf[538]:         at java.util.zip.ZipFile.<init>(ZipFile.java:169)
Aug 19 11:42:28 openHABianPi karaf[538]:         at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:304)
Aug 19 11:42:28 openHABianPi karaf[538]:         ... 15 more
cat /var/log/syslog
Aug 19 11:48:20 openHABianPi karaf[2723]: org.apache.karaf.features.core[org.apache.karaf.features.internal.service.BootFeaturesInstaller] : Error installing boot features
Aug 19 11:48:20 openHABianPi karaf[2723]: org.osgi.framework.BundleException: Error occurred installing a bundle.
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.osgi.storage.Storage.install(Storage.java:574)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.osgi.internal.framework.BundleContextImpl.installBundle(BundleContextImpl.java:146)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.equinox.internal.region.BundleIdBasedRegion.installBundle0(BundleIdBasedRegion.java:117)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.equinox.internal.region.BundleIdBasedRegion.installBundleAtLocation(BundleIdBasedRegion.java:97)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.apache.karaf.features.internal.service.FeaturesServiceImpl.installBundle(FeaturesServiceImpl.java:1335)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:771)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1248)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$1(FeaturesServiceImpl.java:1147)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at java.util.concurrent.FutureTask.run(FutureTask.java:266)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at java.lang.Thread.run(Thread.java:748)
Aug 19 11:48:20 openHABianPi karaf[2723]: Caused by: java.util.zip.ZipException: Exception in opening zip file: /var/lib/openhab2/cache/org.eclipse.osgi/34/0/bundleFile
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:317)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.basicOpen(ZipBundleFile.java:93)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:106)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.open(ZipBundleFile.java:355)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.osgi.storage.Storage.install(Storage.java:538)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011... 11 more
Aug 19 11:48:20 openHABianPi karaf[2723]: Caused by: java.util.zip.ZipException: error in opening zip file
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at java.util.zip.ZipFile.open(Native Method)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at java.util.zip.ZipFile.&lt;init&gt;(ZipFile.java:225)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at java.util.zip.ZipFile.&lt;init&gt;(ZipFile.java:155)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at java.util.zip.ZipFile.&lt;init&gt;(ZipFile.java:169)
Aug 19 11:48:20 openHABianPi karaf[2723]: #011at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:304)
tail -f openhab.log:
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:147) [?:?]
at org.eclipse.osgi.container.Module.doStop(Module.java:636) [?:?]
at org.eclipse.osgi.container.Module.stop(Module.java:498) [?:?]
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) [?:?]
2018-08-19 11:37:08.825 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-08-19 11:37:08.865 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-08-19 11:37:08.891 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-08-19 11:37:08.935 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
Tail - F 9001 provides me the following log:
2018-08-19 11:37:07.776 [WARN ] [org.eclipse.smarthome.model.script  ] - FrameworkEvent WARNING - org.eclipse.smarthome.model.script
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:1829) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:395) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:375) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:291) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1241) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1136) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:996) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1175) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [39:org.apache.felix.scr:2.0.12]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222) [?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:909) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:874) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:139) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:951) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:806) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:788) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.deactivateComponentManager(DependencyManager.java:2225) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.access$500(DependencyManager.java:55) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.removedService(DependencyManager.java:890) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.removedService(DependencyManager.java:743) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:580) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:706) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:523) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:439) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.access$300(Activator.java:54) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:293) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender$2.run(AbstractExtender.java:285) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.destroyExtension(AbstractExtender.java:307) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.bundleChanged(AbstractExtender.java:181) [39:org.apache.felix.scr:2.0.12]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
	at org.eclipse.osgi.container.Module.doStop(Module.java:634) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1675) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1594) [?:?]
	at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:270) [?:?]
I really don’t now what I am doing wrong after just entering the openhabian SD card letting the system install. This shouldn’t be the purpose . I am really disturbed by reinstalling everything for X-times. Maybe someone has a good advice if sth. is missing or I am doing sth. wrong. I just want to start and use the OH-system which shouldn’t be that difficult, right? :slight_smile:
Thank you very much.
So latest update:
I checked now everything. In the end the issue is related to the SD card. I used a different one and it worked without any problems…:grinning:
