I have some problems regarding the latest eclipse smart home designer version on macOS sierra.
Get some error written to a log file in .eclipse folder.
Had the eclipse smart home ide installed first but deleted all folders of it.
Would be great if somebody could help me.
Thanks a lot
Lorenz
A part of the logfile since the whole file is to big and i cannot upload files:
SESSION 2016-09-27 21:59:00.965 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_31
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=de_DE
Command-line arguments: -os macosx -ws cocoa -arch x86_64
!ENTRY org.eclipse.core.runtime 4 0 2016-09-27 21:59:01.621
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.core.runtime [2]
Unresolved requirement: Require-Bundle: javax.annotation; bundle-version=“1.1.0”; visibility:=“reexport”; resolution:=“optional”
Unresolved requirement: Require-Bundle: javax.inject; bundle-version=“1.0.0”; visibility:=“reexport”; resolution:=“optional”
Unresolved requirement: Require-Bundle: org.eclipse.equinox.common; bundle-version=“[3.6.100,4.0.0)”; visibility:=“reexport”
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.SystemModule.startWorker(SystemModule.java:242)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.container.SystemModule.start(SystemModule.java:172)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:393)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:412)
at org.eclipse.osgi.launch.Equinox.start(Equinox.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:320)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:232)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
!ENTRY org.eclipse.equinox.ds 1 0 2016-09-27 21:59:03.993
!MESSAGE Could not bind a reference of component ConfigDescriptionRegistry. The reference is: Reference[name = ConfigOptionProvider, interface = org.eclipse.smarthome.config.core.ConfigOptionProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addConfigOptionProvider, unbind = removeConfigOptionProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-09-27 21:59:03.995
!MESSAGE Could not bind a reference of component ConfigDescriptionRegistry. The reference is: Reference[name = ConfigDescriptionProvider, interface = org.eclipse.smarthome.config.core.ConfigDescriptionProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addConfigDescriptionProvider, unbind = removeConfigDescriptionProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-09-27 21:59:04.932
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.persistence. The reference is: Reference[name = PersistenceService, interface = org.eclipse.smarthome.core.persistence.PersistenceService, policy = dynamic, cardinality = 0..n, target = null, bind = addPersistenceService, unbind = removePersistenceService]
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.349
!MESSAGE Could not install bundle plugins/ch.qos.logback.classic_1.0.7.v20121108-1250.jar A bundle is already installed with the name “ch.qos.logback.classic” and version “1.0.7.v20121108-1250”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.351
!MESSAGE Could not install bundle plugins/ch.qos.logback.core_1.0.7.v20121108-1250.jar A bundle is already installed with the name “ch.qos.logback.core” and version “1.0.7.v20121108-1250”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.352
!MESSAGE Could not install bundle plugins/ch.qos.logback.slf4j_1.0.7.v20121108-1250.jar A bundle is already installed with the name “ch.qos.logback.slf4j” and version “1.0.7.v20121108-1250”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.353
!MESSAGE Could not install bundle plugins/com.google.gson_2.2.4.v201311231704.jar A bundle is already installed with the name “com.google.gson” and version “2.2.4.v201311231704”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.355
!MESSAGE Could not install bundle plugins/com.google.guava_10.0.1.v201203051515.jar A bundle is already installed with the name “com.google.guava” and version “10.0.1.v201203051515”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.357
!MESSAGE Could not install bundle plugins/com.google.inject_3.0.0.v201312141243.jar A bundle is already installed with the name “com.google.inject” and version “3.0.0.v201312141243”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.358
!MESSAGE Could not install bundle plugins/com.ibm.icu.base_52.1.0.v201404171520.jar A bundle is already installed with the name “com.ibm.icu.base” and version “52.1.0.v201404171520”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.359
!MESSAGE Could not install bundle plugins/com.ibm.icu_52.1.0.v201404241930.jar A bundle is already installed with the name “com.ibm.icu” and version “52.1.0.v201404241930”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.361
!MESSAGE Could not install bundle plugins/com.jcraft.jsch_0.1.50.v201403120620.jar A bundle is already installed with the name “com.jcraft.jsch” and version “0.1.50.v201403120620”
!MESSAGE Could not install bundle plugins/com.sun.el_2.2.0.v201303151357.jar A bundle is already installed with the name “com.sun.el” and version “2.2.0.v201303151357”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.362
!MESSAGE Could not install bundle plugins/javax.activation_1.1.0.v201211130549.jar A bundle is already installed with the name “javax.activation” and version “1.1.0.v201211130549”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.363
!MESSAGE Could not install bundle plugins/javax.annotation_1.2.0.v201401042248.jar A bundle is already installed with the name “javax.annotation” and version “1.2.0.v201401042248”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.364
!MESSAGE Could not install bundle plugins/javax.el_2.2.0.v201303151357.jar A bundle is already installed with the name “javax.el” and version “2.2.0.v201303151357”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.365
!MESSAGE Could not install bundle plugins/javax.inject_1.0.0.v20091030.jar A bundle is already installed with the name “javax.inject” and version “1.0.0.v20091030”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.366
!MESSAGE Could not install bundle plugins/javax.mail.glassfish_1.4.1.v201108011116.jar A bundle is already installed with the name “javax.mail.glassfish” and version “1.4.1.v201108011116”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.367
!MESSAGE Could not install bundle plugins/javax.servlet.jsp_2.2.0.v201112011158.jar A bundle is already installed with the name “javax.servlet.jsp” and version “2.2.0.v201112011158”
!ENTRY org.eclipse.update.configurator 4 0 2016-09-27 21:59:05.368
!MESSAGE Could not install bundle plugins/javax.servlet_3.0.0.v201112011016.jar A bundle is already installed with the name “javax.servlet” and version “3.0.0.v201112011016”
