I have a simple Number:Temperature Item that I’m using as part of a group for a thermostat using Alexa. I created the Item and put it in the group as desired. I’ve added metadata, but when I go back and try to edit or view the metadata in the Main UI, I get a spinning wheel that never stops. I can see the correct metadata in the jsondb file, but I should be able to edit in the GUI. I tried restarting OH and that made no difference.
Any suggestions to resolve this? I have other Items with metadata that I can edit. This one in particular seems problematic. I think that all 3 Items that I have in the group seem to have trouble with this. Other Items not in the group can edit the metadata.
Reloading the browser doesn’t change behavior, still spinning.
The browser console does show the error below which is probably the cause, but I don’t know how to interpret this. Suggestions?
I haven’t tried the API Explorer yet - will try that and report back.
Using Chrome: Version 121.0.6167.161 (Official Build) (64-bit)
thanks
app.3456231afb83cd720478.js:7 TypeError: undefined is not iterable (cannot read property Symbol(Symbol.iterator))
at H (14.app.3456231afb83cd720478.js:1:79732)
at Z (14.app.3456231afb83cd720478.js:1:81051)
at Le (14.app.3456231afb83cd720478.js:1:89003)
at parameters (14.app.3456231afb83cd720478.js:1:100832)
at 14.app.3456231afb83cd720478.js:1:119568
at Array.map (<anonymous>)
at 14.app.3456231afb83cd720478.js:1:119544
at Array.reduce (<anonymous>)
at r.parameters (14.app.3456231afb83cd720478.js:1:118825)
at fn.get (app.3456231afb83cd720478.js:7:26678)
Thanks for reporting this issue. A bug has been found affecting all temperature related alexa metadata attributes in MainUI since OH 4.1. A fix has been submitted for the next OH release. Unfortunately, the only workaround is to use the code tab to configure the affected metadata attributes.
