I think just the wink package will do.
@joel_shumann Hi,
It finally happened this time with DEBUG turned on. Here is the long error log with my four(4) thermostat IDs X’ed out for security reason. I have to split the log into 2 parts because of the 48000 character limit per post. Thanks.
PART 1 OF 2
2019-04-17 20:01:20.630 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Getting Device: xxxxxxxxxxxxxxxxxxxx
2019-04-17 20:01:20.648 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Doing Get: JerseyWebTarget { https://api.wink.com/thermostats/xxxxxxxxxxxxxxxxxxxx }
2019-04-17 20:01:20.717 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Getting Device: xxxxxxxxxxxxxxxxxxxx
2019-04-17 20:01:20.739 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Doing Get: JerseyWebTarget { https://api.wink.com/thermostats/xxxxxxxxxxxxxxxxxxxx }
2019-04-17 20:01:20.786 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Getting Device: xxxxxxxxxxxxxxxxxxxx
2019-04-17 20:01:20.800 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Doing Get: JerseyWebTarget { https://api.wink.com/thermostats/xxxxxxxxxxxxxxxxxxxx }
2019-04-17 20:01:20.856 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Getting Device: xxxxxxxxxxxxxxxxxxxx
2019-04-17 20:01:20.872 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Doing Get: JerseyWebTarget { https://api.wink.com/thermostats/xxxxxxxxxxxxxxxxxxxx }
2019-04-17 20:01:21.499 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
javax.ws.rs.ProcessingException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: validity check failed
at org.glassfish.jersey.client.internal.HttpUrlConnector.apply(HttpUrlConnector.java:287) ~[?:?]
at org.glassfish.jersey.client.ClientRuntime.invoke(ClientRuntime.java:255) ~[?:?]
at org.glassfish.jersey.client.JerseyInvocation$1.call(JerseyInvocation.java:684) ~[?:?]
at org.glassfish.jersey.client.JerseyInvocation$1.call(JerseyInvocation.java:681) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:228) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:444) ~[?:?]
at org.glassfish.jersey.client.JerseyInvocation.invoke(JerseyInvocation.java:681) ~[?:?]
at org.glassfish.jersey.client.JerseyInvocation$Builder.method(JerseyInvocation.java:411) ~[?:?]
at org.glassfish.jersey.client.JerseyInvocation$Builder.get(JerseyInvocation.java:311) ~[?:?]
at org.openhab.binding.wink.client.CloudRestfulWinkClient.doGet(CloudRestfulWinkClient.java:130) ~[?:?]
at org.openhab.binding.wink.client.CloudRestfulWinkClient.executeGet(CloudRestfulWinkClient.java:113) ~[?:?]
at org.openhab.binding.wink.client.CloudRestfulWinkClient.getDevice(CloudRestfulWinkClient.java:73) ~[?:?]
at org.openhab.binding.wink.handler.WinkHub2BridgeHandler.getDevice(WinkHub2BridgeHandler.java:151) ~[?:?]
at org.openhab.binding.wink.handler.WinkBaseThingHandler.getDevice(WinkBaseThingHandler.java:171) ~[?:?]
at org.openhab.binding.wink.handler.WinkBaseThingHandler$1.run(WinkBaseThingHandler.java:107) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:?]
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: validity check failed
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:?]
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1959) ~[?:?]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302) ~[?:?]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296) ~[?:?]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1529) ~[?:?]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:226) ~[?:?]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1026) ~[?:?]
at sun.security.ssl.Handshaker.process_record(Handshaker.java:961) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1072) ~[?:?]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) ~[?:?]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559) ~[?:?]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1564) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.access$200(HttpURLConnection.java:91) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1484) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1482) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at java.security.AccessController.doPrivilegedWithCombiner(AccessController.java:782) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1481) ~[?:?]
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:347) ~[?:?]
at org.glassfish.jersey.client.internal.HttpUrlConnector._apply(HttpUrlConnector.java:394) ~[?:?]
at org.glassfish.jersey.client.internal.HttpUrlConnector.apply(HttpUrlConnector.java:285) ~[?:?]
... 23 more
Caused by: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: validity check failed
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:362) ~[?:?]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:259) ~[?:?]
at sun.security.validator.Validator.validate(Validator.java:260) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124) ~[?:?]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1506) ~[?:?]
... 23 more
Caused by: java.security.cert.CertPathValidatorException: validity check failed
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:135) ~[?:?]
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:223) ~[?:?]
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:140) ~[?:?]
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:79) ~[?:?]
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:292) ~[?:?]
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:357) ~[?:?]
... 23 more
Caused by: java.security.cert.CertificateExpiredException: NotAfter: Wed Apr 17 19:59:59 EDT 2019
at sun.security.x509.CertificateValidity.valid(CertificateValidity.java:274) ~[?:?]
at sun.security.x509.X509CertImpl.checkValidity(X509CertImpl.java:629) ~[?:?]
at sun.security.provider.certpath.BasicChecker.verifyValidity(BasicChecker.java:190) ~[?:?]
at sun.security.provider.certpath.BasicChecker.check(BasicChecker.java:144) ~[?:?]
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:125) ~[?:?]
... 23 more
2019-04-17 20:01:21.522 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
... 23 more
... 23 more
... 23 more
... 23 more
2019-04-17 20:01:21.518 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
... 23 more
... 23 more
... 23 more
... 23 more
@joel_shumann
PART 2 OF 2
... 23 more
... 23 more
... 23 more
... 23 more
@oh_newbie Hello,
Thank you for the detailed error/debug log. I received this same error at roughly the same date/time stamp. Mine was:
2019-04-17 20:00:56.586
and yours was:
This looks like an expired SSL certificate, but unfortunately I’m not sure how to properly handle this exception. If anyone has any suggestions, they would be greatly welcomed.
I found this blog entry, so I’ll try debugging with the openssl tool and see what I can learn.
-Joel
@joel_shumann Hi Joel,
Many thanks for looking into the issue. I wish you much luck.
I have close to ZERO SSL knowledge but will try to poke around the web to see how other people deal with an expired certificate.
@oh_newbie
I was able to add some error handling and witnessed via the logs a recovery from an Unknown Host Exception.
I pushed an updated version here.
Hopefully this will be more reliable. Please let me know how it works for you.
You will see the retries in your log at an ERROR level if you search for:
retrying...
For example from my log:
2019-04-29 10:23:21.120 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:21.622 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:22.124 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:22.626 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:23.128 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:23.631 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:24.136 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:24.638 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:25.139 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:25.642 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:26.142 [ERROR] [g.wink.client.CloudRestfulWinkClient] - IWinkDevice getDevice threw Exception: null, retrying...
2019-04-29 10:23:27.143 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Doing Get: JerseyWebTarget { https://api.wink.com/thermostats/xxxxxxxxxxxxxxxx }
2019-04-29 10:23:27.149 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:27.651 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:28.153 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:28.656 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:29.160 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:29.664 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:30.166 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:30.667 [ERROR] [g.wink.client.CloudRestfulWinkClient] - doGet threw Exception: java.net.UnknownHostException: api.wink.com, retrying...
2019-04-29 10:23:31.836 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - CloudRestfulWinkClient::getResultAsJson() response passed in = {"data":{"uuid":" *****SUCCESS FROM HERE ON******
Thank you,
Joel
@joel_shumann, Hi Joel,
Many thanks for the update. Sorry, I did not know about it until today (5/7).
Unfortunately, I cannot evaluate it right away because I currently have a PubNub timeout error.
2019-05-07 04:50:47.185 [ERROR] [ng.wink.handler.WinkBaseThingHandler] - PubNub Error PNBadRequestCategory
2019-05-07 04:50:47.191 [WARN ] [nub.api.managers.ReconnectionManager] - reconnection policy is disabled, please handle reconnection manually.
2019-05-07 04:50:47.373 [ERROR] [ng.wink.handler.WinkBaseThingHandler] - PubNub timeout, reconnecting
Do you or anyone here know how to fix it?
I saw that error when I removed my internet connection from my computer that was running openhab in order to try to duplicate the unknown host error. But when I plugged the Ethernet back in, it recovered.
Joel
I loaded in your latest jar file. Thanks.
I still have the PubNub timeout errors, which do not seem to interfere with the retrieval of the thermostat data. Right now I have wink binding logging set to OFF to keep the PubNub errors from filling up my log file. So if something goes wrong I cannot give you much details.
Joel, and all,
First of all… THANK YOU Joel Shumann for creating the WINK Binding!
None of this would be possible without your excellent work and posts and the binding code. THANKS SO MUCH!
I have read every post on this thread (several times) to figure it all out and now I have successfully connected my Emerson Sensi WiFi Thermostat to my OH2 running on my Intel NUC. Its a detailed process of many steps, but this thread had enough info to point me the right way.
I am using BINDING org.openhab.binding.wink-2.4.0-SNAPSHOT.jar in the FOLDER /usr/share/openhab2/addons/
2 QUESTIONS as of now:
is there ANY WAY to please allow the 5-minute WINK POLLING INTERVAL to be faster? The 5-minute resolution of monitoring my Thermostat(s) is far too long… I use mySQL persist to capture IDLE timestamps COOLING timestamps into my local database for analysis and reports… and the coarse 5-minute boundary is not really something I can use long term. PLEASE?
The PubNub Errors… can this be fixed or solved?
Again, THANK YOU and I look forward to working with you on this. GREAT STUFF!
Dave
Hello @BirdingPix Dave,
First of all, I cannot take credit for the binding. I have just worked on adding the thermostat support, which works, but not as well as I hoped. Thank you for the kind words.
Over the next few weeks I should have time to look into this some more. I will figure out a way to make the polling interval configurable.
I will also do some work on the PubNub errors. Thanks for posting what your logs look like.
Joel
Joel, THANKS SO MUCH!
I am also frustrated by the fact that sometimes… even though the binding is online and everything looks okay in openHAB… any THERMOSTAT setting changes made in the PaperUI or via my own BasicUI running my sitemap… (for example, change the setpoint temp)… the change appears on my screen… but NOTHING changes on the actual thermostat.
Its as if either WINK or openhab-authservice or ? is not connected or active… and the bottom line is that I am UNABLE to actually change any settings or if I manually change the thermostat by pushing the buttons on the actual thermostat… those changes do not show up in my openhab.
After installation 2 weeks ago, all worked great… for a few days. Then, something was “down” for 4 days… and suddenly as of 2 days ago… it all started working again and changes made in my openhab basicUI screens DID IN FACT change the thermostat!
I really would love to be able to not need any external cloud services to make this all work!
THANKS SO MUCH… looking forward very much to working with you.
Dave
Houston, Texas
I made the polling interval configurable. It defaults to 300 seconds. Add the following to your wink.cfg to adjust the time to 60 seconds, for instance.
pollingIntervalSeconds=60
For the PubNub issues, I found while reading on the HomeAssistant site that Wink changed the PubNub setup. I made adjustments so things no longer timeout, however more work is needed to get the PubNub subscriptions working properly.
I pushed a new jar to my github.
Please let me know what you find. I made the polling wait for the PubNub to connect, so there is a chance the polling will never work if the PubNub does not succeed. Let me know if that happens and I can make an adjustment.
Joel
THANK YOU! I’ve installed your updated BINDING… and it’s working GREAT! Still something that PubNub is not happy about… but the 60 seconds polling is working nicely. Great progress!!
What do we need PubNub for ?
THANKS SO MUCH!
Dave
Glad it is working so far.
We use pubnub to get instant updates when things change, rather than polling. But since pubnub is not working right, we will continue to rely on polling.
Joel
Hi @joel_shumann, @BirdingPix
With the latest binding and polling interval set at 60 sec, do you get a temperature update every 60 sec? In my log below, I can see a device polling every 60 sec but not all results in an update. Is this a correct behavior?
In older bindings, an update occurs every 5 minutes which I rely on to trigger some of my rules. So for now I have to use an older version.
2019-09-24 14:57:20.492 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - WinkBaseThingHandler::pollingJob() calling GetDevice
2019-09-24 14:57:34.717 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - PubNub request is incorrect.
2019-09-24 14:57:36.032 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - PubNub status operation null
2019-09-24 14:58:20.492 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - WinkBaseThingHandler::pollingJob() calling GetDevice
2019-09-24 14:58:23.710 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - PubNub request is incorrect.
2019-09-24 14:58:25.034 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - PubNub status operation null
2019-09-24 14:59:20.492 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - WinkBaseThingHandler::pollingJob() calling GetDevice
2019-09-24 15:00:20.492 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - WinkBaseThingHandler::pollingJob() calling GetDevice
2019-09-24 15:00:30.227 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - PubNub.message string to be parsed by json: {"nonce":"xxxxx","pull_url":"https://api.wink.com/thermostats/xxxxxx","thermostat_id":"xxxxxxx"}
2019-09-24 15:00:30.230 [DEBUG] [ng.wink.handler.WinkBaseThingHandler] - PubNub.message, PubNub unable to get current state, calling GetDevice, polling...
2019-09-24 15:00:30.233 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Getting Device: xxxxxxxxxxxxxxxxxxxx
2019-09-24 15:00:30.249 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Doing Get: JerseyWebTarget { https://api.wink.com/thermostats/xxxxxxxxxxxxxxxxxxxx }
2019-09-24 15:00:30.960 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - CloudRestfulWinkClient::getResultAsJson() response passed in = {"data":xxxxxx}
2019-09-24 15:00:30.989 [DEBUG] [g.wink.client.CloudRestfulWinkClient] - Got Device, Name: T2
2019-09-24 15:00:31.009 [DEBUG] [nding.wink.handler.ThermostatHandler] - units string contents: f
2019-09-24 15:00:31.016 [DEBUG] [nding.wink.handler.ThermostatHandler] - Updated CHANNEL_THERMOSTAT_CURRENTTEMPERATURE
In an effort to get PubNub working, I made it so the polling does not occur until the PubNub subscription is established. In your log, I do not see a ‘PubNub connected’ statement which means polling is disabled.
I just uploaded a version that removed this and also does not attempt any PubNub subscriptions.
Thanks,
Joel
Using the latest 2.5.0 SNAPSHOT. Got this error message when I added the .jar to the addons folder.
22:46:44.968 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, id=444, bundle=236/file:/C:/openhab2/addons/org.openhab.binding.wink-2.4.0-SNAPSHOT.jar]: Unexpected problem updating configuration org.openhab.wink
at org.openhab.binding.wink.internal.AuthenticationConfigurationService.updated(AuthenticationConfigurationService.java:37) ~[?:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) ~[bundleFile:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [bundleFile:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1118) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1074) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [bundleFile:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_163]
I’m sorry, I have not been able to get things to build with the latest version, 2.5. I have stopped using the wink binding.
