Hey,
i want to add my EnOcean-Switch (PTM215) to OH2 (with USB 300). So i follow the wiki and add the items:
Switch Button01top "Switch left top" <wallswitch> { enocean="{id=FE:FA:E7:27, eep=F6:02:01, channel=A, parameter=O}" }
Switch Button01bottom "Switch left bottom" <wallswitch> { enocean="{id=FE:FA:E7:27, eep=F6:02:01, channel=A, parameter=I}" }
Switch Button02top "Switch right top" <wallswitch> { enocean="{id=FE:FA:E7:27, eep=F6:02:01, channel=B, parameter=O}" }
Switch Button02bottom "Switch right bottom" <wallswitch> { enocean="{id=FE:FA:E7:27, eep=F6:02:01, channel=B, parameter=I}" }
Configure the port in services/enocean.cfg
serialPort=/dev/ttyUSB0
And it seens to be worked as well…
Blockquo[INFO ] [.enocean.internal.bus.EnoceanBinding] - Connecting to Enocean [serialPort='/dev/ttyUSB0' ].te
But it dont!
I pressed a button on the Switch and nothing happens. Also nothing in the logfile. With EnOceanSpy every press is shown up.
The “funny”-thing. I stopped the OH2 service and get one of these errors for each press on my switch:
at org.openhab.core.events.EventPublisherDelegate.postUpdate(EventPublisherDelegate.java:66) [210:org.openhab.core.compat1x:2.2.0]
at org.openhab.binding.enocean.internal.profiles.StandardProfile.valueChanged(StandardProfile.java:81) [209:org.openhab.binding.enocean:1.11.0]
at org.openhab.binding.enocean.internal.bus.EnoceanBinding.valueChanged(EnoceanBinding.java:298) [209:org.openhab.binding.enocean:1.11.0]
at org.opencean.core.ParameterChangeNotifier.receivePacket(ParameterChangeNotifier.java:47) [209:org.openhab.binding.enocean:1.11.0]
at org.opencean.core.ESP3Host.notifyReceivers(ESP3Host.java:52) [209:org.openhab.binding.enocean:1.11.0]
at org.opencean.core.ESP3Host.run(ESP3Host.java:73) [209:org.openhab.binding.enocean:1.11.0]
Any ideas ? ![]()
Lukas
