Iāll also be happy to help and contribute a few euros.
sure, me too! paypal?
Hi to all!
many thanks once again for this great support here!
I placed both files eq3.exp & eq3.php in /etc/openhab2/html/
, which is accessible via http://[your OH server]:8080/static/[the file name]
(see the following link)
And I think the files are correctly accesible via this, meaning that when i try to run this script via the following url= http://XXX.XXX.X.XX:8080/static/bluetooth/eq3.php?mac=XX-XX-X-X-XX-XX&temperature=20
i get the following:
"auto", "OFF" => "manual"); function readShortStatus($mac) { global $script; $cmd = $script . $mac . " devjson"; return shell_exec($cmd); } function setTemperature($mac, $temp) { global $script; $cmd = $script . $mac . " temp " . $temp; return shell_exec($cmd); } function setComforteco($mac, $comfort, $eco) { global $script; $cmd = $script . $mac . " comforteco " . $comfort . " " . $eco; return shell_exec($cmd); } function setMode($mac, $mode) { global $script; $cmd = $script . $mac . " " . $mode; return shell_exec($cmd); } function setBoost($mac, $off) { global $script; $cmd = $script . $mac . " boost"; if ($off) { $cmd .= " off"; } return shell_exec($cmd); } if(strcasecmp($_SERVER['REQUEST_METHOD'], 'POST') == 0){ $request_parameters = $_POST; } else if(strcasecmp($_SERVER['REQUEST_METHOD'], 'GET') == 0) { $request_parameters = $_GET; } $mac = str_replace("-", ":", $request_parameters['mac']); if (isset($request_parameters['temperature'])) { $temperature = str_replace(",", ".", $request_parameters['temperature']); } if (isset($request_parameters['mode'])) { $mode = $request_parameters['mode']; } if (isset($request_parameters['boost'])) { $boost = $request_parameters['boost']; } if (isset($mac)) { if (preg_match($mac_regex, $mac)) { // temperature if (isset($temperature)) { $temperature = floatval($temperature); $result = setTemperature($mac, $temperature); } // mode if (in_array($mode, array_keys($modes))) { $result = setMode($mac, $modes[$mode]); } // boost if (isset($boost)) { if (strcasecmp($boost, "ON") == 0) { $result = setBoost($mac, 0); } if (strcasecmp($boost, "OFF") == 0) { $result = setBoost($mac, 1); } } $response = readShortStatus($mac); } } header('Content-Type: application/json'); echo $response; ?>
which should be the content of the eq3.php.
i adapted the link to the exp-file, see
but unfortunately, it does not work, meaning that the radiator does not change the temperature to 20Ā°.
any help?
hi hans,
the output youāve got is the content of the php file, which is being displayed as text - so php isnāt set-up properly on your system.
Iām not sure if you can run php from within the OH āstaticā directory.
Iāve got a ānormalā (not OH) webserver running on my server with php already configured and installed the scripts there.
hey man, many thanks for all these tips!
I add the code lines needed for me to set this up (a bit like a tutorial), so others can be helped here too.
- Set up an apache2 webserver by:
sudo apt-get install apache2
Test if eveything is installed properly by tiping your rpi-url in the webbrower ) e.g.
http://raspberrypi
Now, html files can be placed here: /var/www/html
- install php, i did this with the following code fence:
sudo apt-get -t stretch -y install php7.0 php7.0-mysql php7.0-curl php7.0-gd php7.0-zip php7.0-fpm php7.0-cli php7.0-opcache php7.0-json php7.0-mbstring php7.0-xml libapache2-mod-php7.0
- create the following file via
sudo nano /var/www/html/info.php
and add the following code
<?php
phpinfo();
- go to your rpi webser again with the following link, e.g.
http://raspberrypi/info.php
- check if everything is working:
At the end, for me the above mentioned code fence remains, after having set up the php webserver, in a completely empty, blank, webpage, and nothing did change to the radiator.
the files are located here:
and eq3.php refers to
any more ideas?
what happens if you run āhcitools lescanā from the commandline? Does the bluetooth see the Radstat?
If so, what happens if you run
./eq3.exp 11:22:33:44:55:66 sync
(with your RadStatās mac-address, from the directory that eq3.exp is in)
Note that running eq3.exp might not work everytime, so try a few times. If that reports back with temperature, etc, as detailed in the readme for the code, then it should work.
Many thanks again, i appreciate your help a lot!!
hcitools lescan gives me:
sudo hcitool lescan
LE Scan ...
2A:C1:95:8B:5D:71 (unknown)
F1:97:98:1A:35:0E (unknown)
5C:49:7D:8A:37:02 (unknown)
88:0F:10:4F:75:99 (unknown)
88:0F:10:4F:75:99 MI
00:1A:22:0F:3D:71 (unknown)
00:1A:22:0F:3D:71 CC-RT-BLE
F1:97:98:1A:35:0E Amazfit Bip Watch
Meaning, the radiator is foundā¦
when i try to run
i get
[19:23:00] openhabian@openHABianPi:/var/www/html/eq3/php$ ./eq3.exp 00-1A-22-0F-3D-71 sync
-bash: ./eq3.exp: Permission denied
ls -l gives me
ls -l
total 36
-rw-r--r-- 1 openhab openhabian 31232 Oct 13 07:11 eq3.exp
-rw-r--r-- 1 openhab openhabian 2087 Oct 14 08:56 eq3.php
after having done
chmod 777 eq3.exp & chmod 777 eq3.php
theres something going on
but no i get
./eq3.exp 00:1A:22:0F:3D:71 sync
Connection failed.
also this (ā-ā instead of ā:ā)
Connection failed.
results in a failure.
you are 100% sure that you are not connected/ paired with this radiator??
i tried to do that, but whenever i try to run
sudo bluetoothctl
and then
pair "my mac adress"
bluetoothctl does not ask me to enter a pairing code, but the display of the radiators give me one (long press on the round button); meaning that after a 5 seconds timeout, i lose connection to the radiator.
Im quite happy because i managed it to get status information on the terminal level!
what i have done is (only once, after reboot the following are also working)
gatttool -I
connect "my mac adress"
now i can exetuting this (i need to use the ā-ā, the ā:ā are not working!!!
and gets that:
Temperature: 21.0Ā°C
Valve: 100%
Mode: auto dst
Vacation mode: off
hey!!
any idea about the error i still get when running the php command via the webpage?
see: https://community.openhab.org/t/eq3-eqiva-bluetooth-radiator/52728/26?u=baggerfahrer
after executing the command via the webpage, i still get an empty page and the radiator does not change the values, but when executing the command via the terminal, i receive data from the radiatorā¦
meaning there must be a mistakeā¦
I have my eq3.exp script in the āeq3ā directory and the eq3.php script in the āphpā subdirectory - so Iām guessing thatās the structure it unzips in. You have both scripts in the php directory.
So try moving eq3.exp to the āeq3ā directory and adjust the $script variable in the php script to reflect that.
seriously, im not quite sure if this change made the difference or not, but after having changed this what you mentioned it works!!!
but additional to that, i completely deleted the eq3.php file again and created it once more with the correctly set up path to the eq3.exp.
now it works!! great man, i really really appreciate your help!
right, letās get Vlad sorted with a radstat that he can use for testing.
Whoās going to take charge (Iād prefer not to), and how much do the three of us need to chip in?
radiator is 20ā¬; depends on the shipping costs, what i definitely dont know to new zealand. i would recommed that we send him the money and he, if possible, can order the device by himself.
Sorry, I completely missed that thread. Are you guys still interested in this?
I can do paypal and order it myself, you could also just order it to my address as well. How many of you who want to chip in?
Is this that one?
hi vlad, Iām still interested, yes, and still happy to chip in.
And that looks to be the same device, although the display is the other way up on mine.
i am also interested in an implementation. if you need any kind of support, please let me know.
Interested.
To be precise it is eq3 MOdel Bluetooth
