I have rule to turn on and off the lights based on dusk and dawn times calculated using astro binding. The astro binding items get correct values and no errors there. However, the rule works sometimes and sometimes it doesn’t. the rule is as below.
import org.joda.time.*
import org.openhab.core.library.types.*
import org.openhab.core.library.types.PercentType
import org.openhab.core.library.items.SwitchItem
import org.openhab.model.script.actions.*
import org.openhab.model.script.actions.Timer
import java.util.HashMap
import java.util.LinkedHashMap
import java.util.ArrayList
import java.util.Map
import java.util.concurrent.locks.Lock
import java.util.concurrent.locks.ReentrantLock
var Lock lock = new ReentrantLock()
* This rule turns ON front porch lights on at dusk.
rule "Lights ON at Dusk"
System started or
Time cron "0 * * * * ?"
var DateTime daystart = new DateTime((dawnStart.state as DateTimeType).calendar.timeInMillis)
var DateTime dayend = new DateTime((duskEnd.state as DateTimeType).calendar.timeInMillis)
val boolean isDark = now.isBefore(daystart) || now.isAfter(dayend)
// val boolean isDark = now.isAfter(dayend)
logInfo("Date Midnight: " , (now.toDateMidnight).toString)
logInfo( "Dusk Rule", isDark.toString)
lock.lock()
DuskOn.members.forEach [ pl |
var plStateOnOff = pl.getStateAs(pl.acceptedDataTypes.get(0))
logDebug( "Dusk Rule", "Item Name" + pl.name)
if(isDark){
logInfo( "Dusk Rule", "Is Dusk")
if (plStateOnOff == OFF) {
logInfo( "Dusk Rule", "Item State" + plStateOnOff.toString)
sendCommand(pl, ON)
} else {
logInfo( "Dusk Rule", "Is NOT Dusk")
if(plStateOnOff == ON){
sendCommand(pl, OFF)
lock.unlock()
When it doesn’t work the following exception can be see in the openHAB log.
2015-09-09 20:00:00.026 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule Lights ON at Dusk
java.lang.IllegalStateException: Could not invoke method: org.openhab.model.script.actions.BusEvent.sendCommand(java.lang.String,java.lang.String) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:738) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
at sun.reflect.GeneratedMethodAccessor172.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_51]
at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.8.0_51]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at sun.reflect.GeneratedMethodAccessor180.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor189.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:329) ~[na:na]
at sun.reflect.GeneratedMethodAccessor191.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:28) ~[na:na]
at com.sun.proxy.$Proxy84.apply(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:395) ~[na:na]
at sun.reflect.GeneratedMethodAccessor201.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(XbaseInterpreter.java:549) ~[na:na]
at sun.reflect.GeneratedMethodAccessor179.invoke(Unknown Source) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_51]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_51]
... 74 common frames omitted
Environment: OpenHAB 1.7.1 JAVA 1.8.0_51 WIndows 10 Aeon USB ZStick Gen 5
Any help is appreciated.
