Error downloading binding
openHAB 3.2.0
I try install HTTP binding.
2022-06-14 12:26:02.646 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-http’: Error:
Error downloading mvn:org.openhab.addons.bundles/org.openhab.binding.http/3.2.0
I´ve the same problem..,
https://openhab.jfrog.io is down..
… same to me :frowning_face: … I shut down my system for some maintenance and now it does not start anymore
Hmm. Could this also be the reason why I can’t import a binding into Eclipse? It gets stuck at 9%.
Yes, facing maven issues also in eclipse.
DNS…. It’s always dns…
Don’t think it’s DNS in this case. openhab.jfrog.io resolves to an IP. But if you go there with a browser you’ll get an nginx 504. The servers behind jfrog’s reverse proxy are down. There really isn’t anything we can do about this. Presumably jfrog is aware of the problem and furiously working on it.
Never thought I’d have a use for this video, but 7 years later, here I am…
A furious frog: (SFW of course)
This video freaked out my corgies! :rofl:
Now it´s working :+1:
Thank the furious frog with its thunderous war cry :rofl:
the attempt to install the addon network ups tools fails.
The following message appears in the log file:
2022-09-15 19:54:31.286 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-networkupstools’: Error:
Error downloading mvn:org.openhab.addons.bundles/org.openhab.binding.networkupstools/3.3.0
My system is oh3.3.0 running Docker on a synology nas
See Jfrog repo is down, can't install OH nor add-ons
so bad luck, you want to download a new binding after a year and then something like this… thanks for the info!
