Error for configuration after upgrade to OH4 (Failed to normalize)
Hi there,
after upgrading to OH4 i have the following errors in the logfile:
2023-07-29 10:19:24.234 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'smartmeter:meter:87e2db31cf' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2023-07-29 10:19:24.293 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'smartmeter:meter:87e2db31cf': {thing/channel=Type description smartmeter:129-129_199-130-3 for smartmeter:meter:87e2db31cf:129-129_199-130-3 not found, although we checked the presence before.}
2023-07-29 10:19:24.565 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'smartmeter:meter:430459fe04' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2023-07-29 10:19:24.608 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'smartmeter:meter:430459fe04': {thing/channel=Type description smartmeter:129-129_199-130-3 for smartmeter:meter:430459fe04:129-129_199-130-3 not found, although we checked the presence before.}
What to do about this?
br
According to the warning, if it happens just after the upgrade, you can ignore it. If it keeps happening after restarting openHAB, please create an issue in the openhab add-ons repository.
A had similar warnings from amazon echo devices, I did recreate the things (amazon account bridge and echo device thing) and the warning is gone.
Unfortunatly removing thing an recreating it does not solve the issue.
Created the issue in Git
