Error installing Widgets from community in User Interfaces
When i try to install user widgets in user interface i get an error and this in log.
2021-11-13 17:48:57.116 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Widget from marketplace is invalid: Couldn't find the widget in the add-on entry
What am i doing wrong?
It looks like the author didn’t post the widget correctly. The forum post has a specific format that has to be used.
I have upgraded OpenHab to version 3.2.0 and I am getting the same error as well as this:
2021-12-23 08:51:29.423 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Unable to parse YAML: Cannot deserialize value of type `java.util.Date` from String "Jan 1, 2021, 4:08:53 PM": not a valid representation (error: Failed to parse Date value 'Jan 1, 2021, 4:08:53 PM': Unparseable date: "Jan 1, 2021, 4:08:53 PM")
 at [Source: (StringReader); line: 12, column: 12] (through reference chain: org.openhab.core.ui.components.RootUIComponent["timestamp"])
2021-12-23 08:51:29.424 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Widget from marketplace is invalid: Unable to parse YAML
maybe post the widget code you tried to use
It is pretty much any widgets in the User interfaces page.
The dishwasher widget.
The harmony hub remote.
Is there something else I have to do to get them to install?
Same issue here, 3.2.0 on RPi4 Buster.
I have the same issue, but it’s not with all widgets. I could install from the UI the Battery Level Status and Universal Toggle ; however, I couldn’t install the Washing machine status widget or Dishwasher Status.
Most probably what @rlkoshak mentioned is correct, although these are not new widgets. They seem to have been published and downloaded by many people since February.
Edit: I only get this error, not the one with the YAML:
since I have the same issue, I tried to install nearly all of the available widgets, including the battery status, Garbage Collection, Keypad, etc. All of which without success…
It’s allwas the same error message:
[ERROR] [munity.CommunityUIWidgetAddonHandler] - Unable to parse YAML: Cannot deserialize value of type java.util.Date from String “Oct 28, 2021, 10:52:35 AM”: not a valid representation (error: Failed to parse Date value ‘Oct 28, 2021, 10:52:35 AM’: Unparseable date: “Oct 28, 2021, 10:52:35 AM”)
at [Source: (StringReader); line: 37, column: 12] (through reference chain: org.openhab.core.ui.components.RootUIComponent[“timestamp”])
My installation is RPi 3B+ with upgraded OH vom 2 to 3.2 via 3.1
So, I don’t think it’s a problem with the widgets, but could it be a problem with date format? My region is Austria.
Hi, @cra. Welcome to the community and thanks for doing the in-depth test and sharing the results.
It would be useful to use the code fences option in the text editor when reporting error messages. There is a great post from Rich Koshak on the topic (How to use code fences)
Regards.
@nelson.aponte, sorry, will do so next time.
But,surprising that no one else has this marketplace problem?
Regards,
Christian
It looks like I have the same problem. Updated from 3.0.2 to 3.2.0 with region Germany.
Dear all,
on my new installed OH3.2 (VM on QNAP NAS with Ubuntu20.04LTS) I do have the same problems.
If I would do a wild guess I thing we ahve a regional settings problem. I installed my Ubunto with German locale and I see the errors below in the log file (tried 3 different ones) always referencing on the “timestamp” row as issue.
Interestingly there is one widget called “AirCondition Controller” which I am able to add. but it looks like all the others dont (havent tested all of them but 6-8 others ) .
Any idea ?
M
2022-01-02 11:00:37.723 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Unable to parse YAML: Cannot deserialize value of type `java.util.Date` from String "May 18, 2021, 12:42:12 PM": not a valid representation (error: Failed to parse Date value 'May 18, 2021, 12:42:12 PM': Unparseable date: "May 18, 2021, 12:42:12 PM")
 at [Source: (StringReader); line: 31, column: 12] (through reference chain: org.openhab.core.ui.components.RootUIComponent["timestamp"])
2022-01-02 11:00:37.757 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Widget from marketplace is invalid: Unable to parse YAML
2022-01-02 11:05:33.053 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Unable to parse YAML: Cannot deserialize value of type `java.util.Date` from String "Oct 4, 2021, 11:28:30 PM": not a valid representation (error: Failed to parse Date value 'Oct 4, 2021, 11:28:30 PM': Unparseable date: "Oct 4, 2021, 11:28:30 PM")
 at [Source: (StringReader); line: 71, column: 12] (through reference chain: org.openhab.core.ui.components.RootUIComponent["timestamp"])
2022-01-02 11:05:33.057 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Widget from marketplace is invalid: Unable to parse YAML
2022-01-02 11:05:42.288 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Unable to parse YAML: Cannot deserialize value of type `java.util.Date` from String "Feb 3, 2021, 1:12:37 PM": not a valid representation (error: Failed to parse Date value 'Feb 3, 2021, 1:12:37 PM': Unparseable date: "Feb 3, 2021, 1:12:37 PM")
 at [Source: (StringReader); line: 25, column: 12] (through reference chain: org.openhab.core.ui.components.RootUIComponent["timestamp"])
2022-01-02 11:05:42.309 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Widget from marketplace is invalid: Unable to parse YAML
This is odd, because the AirCondition Controller also has the timestamp property with a date that doesn’t appear to be functionally different than the ones giving you the errors.
timestamp: Oct 6, 2021, 3:47:22 PM
@ysc, any idea what’s gong on here?
Same problems.
2022-01-02 21:01:42.260 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Unable to parse YAML: Cannot deserialize value of type `java.util.Date` from String "Oct 2, 2021, 9:24:59 PM": not a valid representation (error: Failed to parse Date value 'Oct 2, 2021, 9:24:59 PM': Unparseable date: "Oct 2, 2021, 9:24:59 PM")
 at [Source: (StringReader); line: 36, column: 12] (through reference chain: org.openhab.core.ui.components.RootUIComponent["timestamp"])
2022-01-02 21:01:42.261 [ERROR] [munity.CommunityUIWidgetAddonHandler] - Widget from marketplace is invalid: Unable to parse YAML
yes, indeed same format of timestamp on the AirCondition Controller widget. Perhaps the logged error is just a knock-on effect and not the root cause…
I will try to copy the yaml code from one that does not work and add this as a personal widget to see if this is a may be a problem of the “marketplace”
M
EDIT : 13:36h
I tried with the garage widget rlk_lock_list from Rich Koshak. Addng from the marketplace did not worked. But If I go to developer tools → widgets I could add the YAML code without any problems and then use the widget on an Item chainging the “Add Metadata” and “Default List Item Widget”.
I was confused by this too because the parser is explicitely configured to handle this date format:
It doesn’t specify the Locale however and if the system-configured one happens to be German, October 3-character is likely “Okt”, not “Oct”. Should be an easy fix.
In the meantime removing this timestamp line from the widgets’ code works too, as it’s not too important.
