I’m not sure what I screwed up but I think it stemmed from installing an unofficial binding that I have since removed. I had a backup from a few months back and restored my SD card to that but OH2.2 is still unusable. Any page I bring up in paperui, habpanel, or habmin generates these. Can anyone point me in the right direction?
2017-11-29 10:18:15.571 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:18:15.610 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:18:15.648 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:18:15.738 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘OFF’ failed: An error occurred while opening file.
2017-11-29 10:18:15.778 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘NULL’ failed: An error occurred while opening file.
2017-11-29 10:18:53.558 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:18:53.600 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:18:53.639 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:18:53.678 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:18:53.764 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘OFF’ failed: An error occurred while opening file.
2017-11-29 10:18:53.805 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘NULL’ failed: An error occurred while opening file.
2017-11-29 10:19:07.514 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:19:07.556 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:19:07.629 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:19:07.678 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘CLOSED’ failed: An error occurred while opening file.
2017-11-29 10:19:07.751 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘OFF’ failed: An error occurred while opening file.
2017-11-29 10:19:07.790 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘NULL’ failed: An error occurred while opening file.
2017-11-29 10:19:18.844 [WARN ] [.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.map.internal.MapTransformationService@123ead8’ with value ‘OFF’ failed: An error occurred while opening file.
