Hi Guys,
I need again some help. I am running a new installtion with OH 2.3.0-Snapshot on an Banana Pro (latest Armbian) and i am having Transformation Warnings in my logfile.
[WARN ] [.core.transform.TransformationHelper] - Transformation 'org.eclipse.smarthome.transform.map.internal.MapTransformationService@1f1d5f5' with value 'NULL' failed: An error occurred while opening file.
The warning is more serious, as i think it keeps my Sonoff devices with mosquitto mqtt from operating.
I reduced my configuration to a simpe sitemap with just one switch and also created a single items file with only the item for this switch.
Hi Harry,
Yes i forgot to place my sitemap and items file, i just put it in the origional post.
And yes all map files are places in …/conf/transform directory.
bert@openhab-bpro:/opt/openhab2/conf$ ls items
astro.items mqtt.items mqtt.items-bt readme.txt
But now I gave the astro.items file an other extension, so it is no longer read by openhab.
Also i commented-out the astro frame in the sitemap file.
Unfortunately, the problem remains. With each press on the Switch item on the sitemap i get this error in the log…
Perhaps some other info.
I have installed node-Red on this Banana Pro. And i am working on rules for switching my Sonoff devices.
(I find programming rules within openhab a crime… thats why i am trying node-Red.)
And from node-Red, all my Sonoff devices (~10) are working, also from the node-Red dashboard. Node-Red is using the same mosquitto broker as openhab. The same topics are being used.
Before i started with node-Red the openhab config worked with all these Sonoff switches. But i can’t see what node-Red has to do with this error… And it took me a while to setup node-red, so i am not reluctant to remove node-Red or begin again from scratch…
Thanks for your suggestions. I think you might be right about the editor.
I removed all files in items and sitemaps and started again using Visual Studio now.
It seems to work, because i do not receive the errors naymore. But now i have a problem with mqtt, but that’s something differently My node-Red / mqtt with the same broker is working, but the connection from openhab to the broker seems not to work anymore. To be continued…
