With the updated OH 2.5 stable I still have issues with the embedded MQTT broker. I have ESP devices which connects to the MQTT but some times when they reboot and connects back the log is flooded with this error:
2019-12-23 15:18:06.050 [ERROR] [.moquette.broker.NewNettyMQTTHandler] - Error processing protocol message: SUBSCRIBE
at io.moquette.broker.PostOffice.subscribeClientToTopics(PostOffice.java:86) ~[bundleFile:?]
at io.moquette.broker.MQTTConnection.processSubscribe(MQTTConnection.java:307) ~[bundleFile:?]
at io.moquette.broker.MQTTConnection.handleMessage(MQTTConnection.java:71) ~[bundleFile:?]
at io.moquette.broker.NewNettyMQTTHandler.channelRead(NewNettyMQTTHandler.java:58) [bundleFile:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:374) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:360) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:352) [bundleFile:4.1.42.Final]
at io.moquette.broker.metrics.MQTTMessageLogger.channelRead(MQTTMessageLogger.java:46) [bundleFile:?]
at io.moquette.broker.metrics.MessageMetricsHandler.channelRead(MessageMetricsHandler.java:50) [bundleFile:?]
at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:328) [bundleFile:4.1.42.Final]
at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:315) [bundleFile:4.1.42.Final]
at io.netty.handler.codec.ReplayingDecoder.callDecode(ReplayingDecoder.java:349) [bundleFile:4.1.42.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:283) [bundleFile:4.1.42.Final]
at io.moquette.broker.metrics.BytesMetricsHandler.channelRead(BytesMetricsHandler.java:51) [bundleFile:?]
at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:287) [bundleFile:4.1.42.Final]
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1422) [bundleFile:4.1.42.Final]
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:931) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:163) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2019-12-23 15:18:06.090 [ERROR] [.moquette.broker.NewNettyMQTTHandler] - Unexpected exception while processing MQTT message. Closing Netty channel. CId=LivingRoom02
at io.moquette.broker.MQTTConnection.handleConnectionLost(MQTTConnection.java:255) ~[?:?]
at io.moquette.broker.NewNettyMQTTHandler.channelInactive(NewNettyMQTTHandler.java:82) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:257) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:243) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannelHandlerContext.fireChannelInactive(AbstractChannelHandlerContext.java:236) [bundleFile:4.1.42.Final]
at io.moquette.broker.metrics.MQTTMessageLogger.channelInactive(MQTTMessageLogger.java:109) [bundleFile:?]
at io.netty.handler.codec.ByteToMessageDecoder.channelInputClosed(ByteToMessageDecoder.java:393) [bundleFile:4.1.42.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelInactive(ByteToMessageDecoder.java:358) [bundleFile:4.1.42.Final]
at io.netty.channel.ChannelInboundHandlerAdapter.channelInactive(ChannelInboundHandlerAdapter.java:81) [bundleFile:4.1.42.Final]
at io.moquette.broker.AutoFlushHandler.channelInactive(AutoFlushHandler.java:90) [bundleFile:?]
at io.netty.handler.timeout.IdleStateHandler.channelInactive(IdleStateHandler.java:278) [bundleFile:4.1.42.Final]
at io.moquette.broker.InflightResender.channelInactive(InflightResender.java:123) [bundleFile:?]
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelInactive(DefaultChannelPipeline.java:1417) [bundleFile:4.1.42.Final]
at io.netty.channel.DefaultChannelPipeline.fireChannelInactive(DefaultChannelPipeline.java:913) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannel$AbstractUnsafe$8.run(AbstractChannel.java:819) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:510) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:518) [bundleFile:4.1.42.Final]
I found similar topic in the forum where the solution was to switch back to Mosquitto.
According to rlkoshak Moquette is abandoned by its developer. Is there any news regarding this?
Should I just totally forget the embedded broker and use Mosquitto instead or will this ever be stabilized?
Thanks a lot!
