Error while Installing openhab-cloud on Ubuntu 18.04
I got myself a small VPS to test with the openhab-cloud. But I sturggle while installing the Software.
I use a Linux VPS with Ubuntu 18.04, 1vCore and 2 GB RAM.
Everything works fine and as soon as I try to start npm install, I get the following errors.
root@XXX:/var/www/XXX.de/openhab-cloud# npm install
npm WARN deprecated bcrypt@1.0.2: versions < v5.0.0 do not handle NUL in passwords properly
npm WARN deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
npm WARN deprecated chokidar@0.6.2: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
npm WARN deprecated email-templates@3.3.2: Please upgrade to email-templates@6.0.0+ as we have significantly improved rendering performance (now occurs in parallel versus serially), and there is only one breaking change with ‘preview’ option, see https://github.com/niftylettuce/email-templates\#v600 and https://github.com/niftylettuce/preview-email\#custom-preview-template-and-stylesheets
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated mongodb@1.4.40: Please upgrade to 2.2.19 or higher
npm WARN deprecated connect@1.9.2: connect 1.x series is deprecated
npm WARN deprecated formidable@1.0.17: Old versions of Formidable are not compatible with the current Node.js; Upgrade to 1.2.0 or later
npm WARN deprecated bson@0.2.22: Fixed a critical issue with BSON serialization documented in CVE-2019-2391, see https://bit.ly/2KcpXdo for more details
npm WARN deprecated ejs@0.8.8: Critical security bugs fixed in 2.5.5
npm WARN deprecated @ladjs/i18n@0.2.0: Please upgrade to v3.0.3+ as we have fixed a core bug with Accept/Accepts-Language language detection when a wildcard / is provided - it was previously not respecting the default locale and was using the first locale provided in the locales list, see https://github.com/ladjs/i18n/releases/tag/v3.0.3
npm WARN deprecated boom@5.2.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated i18n-locales@0.0.2: Please upgrade to v0.0.3+ as we have fixed missing ISO-639-1 codes
npm WARN deprecated hoek@4.2.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm ERR! Linux 4.15.0-124-generic
npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “install”
npm ERR! node v8.10.0
npm ERR! npm v3.5.2
npm ERR! code EMISSINGARG
npm ERR! typeerror Error: Missing required argument #1
npm ERR! typeerror at andLogAndFinish (/usr/share/npm/lib/fetch-package-metadata.js:31:3)
npm ERR! typeerror at fetchPackageMetadata (/usr/share/npm/lib/fetch-package-metadata.js:51:22)
npm ERR! typeerror at resolveWithNewModule (/usr/share/npm/lib/install/deps.js:456:12)
npm ERR! typeerror at /usr/share/npm/lib/install/deps.js:457:7
npm ERR! typeerror at /usr/share/npm/node_modules/iferr/index.js:13:50
npm ERR! typeerror at /usr/share/npm/lib/fetch-package-metadata.js:37:12
npm ERR! typeerror at addRequestedAndFinish (/usr/share/npm/lib/fetch-package-metadata.js:82:5)
npm ERR! typeerror at returnAndAddMetadata (/usr/share/npm/lib/fetch-package-metadata.js:117:7)
npm ERR! typeerror at pickVersionFromRegistryDocument (/usr/share/npm/lib/fetch-package-metadata.js:134:20)
npm ERR! typeerror This is an error with npm itself. Please report this error at:
npm ERR! typeerror http://github.com/npm/npm/issues
npm ERR! Please include the following file with any support request:
npm ERR! /var/www/XXX.de/openhab-cloud/npm-debug.log
And the debug log is where??
First Part of npm-debug.log
Second Part of npm-debug.log
Third Part of npm-debug.log
Fourth Part of npm-debug.log
Hey,
I updated my node to 14.15 (instead of Version 7 as mentioned in the Tutorial) and my Errors changed.
bson@0.2.22 install /var/www/osbenji.de/openhab-cloud/node_modules/bson
> (node-gyp rebuild 2> builderror.log) || (exit 0)
make: Entering directory '/var/www/osbenji.de/openhab-cloud/node_modules/bson/build'
  CXX(target) Release/obj.target/bson/ext/bson.o
bson.target.mk:109: recipe for target 'Release/obj.target/bson/ext/bson.o' failed
make: Leaving directory '/var/www/osbenji.de/openhab-cloud/node_modules/bson/build'
> kerberos@0.0.11 install /var/www/osbenji.de/openhab-cloud/node_modules/kerberos
make: Entering directory '/var/www/osbenji.de/openhab-cloud/node_modules/kerberos/build'
  CXX(target) Release/obj.target/kerberos/lib/kerberos.o
kerberos.target.mk:115: recipe for target 'Release/obj.target/kerberos/lib/kerberos.o' failed
make: Leaving directory '/var/www/osbenji.de/openhab-cloud/node_modules/kerberos/build'
> bufferutil@1.2.1 install /var/www/osbenji.de/openhab-cloud/node_modules/bufferutil
> node-gyp rebuild
make: Entering directory '/var/www/osbenji.de/openhab-cloud/node_modules/bufferutil/build'
  CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
../src/bufferutil.cc:25:30: error: ‘v8::Handle’ has not been declared
   static void Initialize(v8::Handle<v8::Object> target)
../src/bufferutil.cc:25:36: error: expected ‘,’ or ‘...’ before ‘<’ token
../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(int)’:
../src/bufferutil.cc:33:14: error: ‘target’ was not declared in this scope
 Nan::Set(target, Nan::New<String>("BufferUtil").ToLocalChecked(), t->GetFunction());
../src/bufferutil.cc:33:14: note: suggested alternative: ‘Merge’
          Merge
../src/bufferutil.cc:33:86: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
In file included from ../src/bufferutil.cc:7:0:
/root/.cache/node-gyp/14.15.1/include/node/v8.h:6475:46: note: candidate: v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)
   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
/root/.cache/node-gyp/14.15.1/include/node/v8.h:6475:46: note:   candidate expects 1 argument, 0 provided
../src/bufferutil.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BufferUtil::Merge(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/bufferutil.cc:49:49: error: no matching function for call to ‘v8::Value::ToObject()’
 Local<Object> bufferObj = info[0]->ToObject();
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2822:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2822:44: note:   candidate expects 1 argument, 0 provided
../src/bufferutil.cc:56:39: error: no matching function for call to ‘v8::Array::Get(unsigned int&)’
   Local<Object> src = array->Get(i)->ToObject();
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3717:43: note: candidate: v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)
   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3717:43: note:   candidate expects 2 arguments, 1 provided
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3720:43: note: candidate: v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3720:43: note:   candidate expects 2 arguments, 1 provided
../src/bufferutil.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BufferUtil::Unmask(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/bufferutil.cc:67:50: error: no matching function for call to ‘v8::Value::ToObject()’
 Local<Object> buffer_obj = info[0]->ToObject();
../src/bufferutil.cc:69:48: error: no matching function for call to ‘v8::Value::ToObject()’
 Local<Object> mask_obj = info[1]->ToObject();
../src/bufferutil.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BufferUtil::Mask(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/bufferutil.cc:88:50: error: no matching function for call to ‘v8::Value::ToObject()’
../src/bufferutil.cc:89:48: error: no matching function for call to ‘v8::Value::ToObject()’
../src/bufferutil.cc:91:50: error: no matching function for call to ‘v8::Value::ToObject()’
 Local<Object> output_obj = info[2]->ToObject();
../src/bufferutil.cc:92:51: error: no matching function for call to ‘v8::Value::Int32Value()’
 unsigned int dataOffset = info[3]->Int32Value();
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2869:40: note: candidate: v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const
   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2869:40: note:   candidate expects 1 argument, 0 provided
../src/bufferutil.cc:93:47: error: no matching function for call to ‘v8::Value::Int32Value()’
 unsigned int length = info[4]->Int32Value();
../src/bufferutil.cc: At global scope:
../src/bufferutil.cc:114:12: error: variable or field ‘init’ declared void
 void init (Handle<Object> target)
../src/bufferutil.cc:114:12: error: ‘Handle’ was not declared in this scope
../src/bufferutil.cc:114:12: note: suggested alternative: ‘rand_r’
        rand_r
../src/bufferutil.cc:114:25: error: expected primary-expression before ‘>’ token
../src/bufferutil.cc:114:27: error: ‘target’ was not declared in this scope
../src/bufferutil.cc:114:27: note: suggested alternative: ‘tzset’
                       tzset
In file included from ../src/bufferutil.cc:8:0:
../src/bufferutil.cc:120:25: error: ‘init’ was not declared in this scope
 NODE_MODULE(bufferutil, init)
/root/.cache/node-gyp/14.15.1/include/node/node.h:758:36: note: in definition of macro ‘NODE_MODULE_X’
   (node::addon_register_func) (regfunc),                          \
../src/bufferutil.cc:120:1: note: in expansion of macro ‘NODE_MODULE’
../src/bufferutil.cc:120:25: note: suggested alternative: ‘int’
bufferutil.target.mk:112: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1
make: Leaving directory '/var/www/osbenji.de/openhab-cloud/node_modules/bufferutil/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
gyp ERR! System Linux 4.15.0-124-generic
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /var/www/osbenji.de/openhab-cloud/node_modules/bufferutil
gyp ERR! node -v v14.15.1
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
> ws@0.4.31 install /var/www/osbenji.de/openhab-cloud/node_modules/socket.io-client/node_modules/ws
make: Entering directory '/var/www/osbenji.de/openhab-cloud/node_modules/socket.io-client/node_modules/ws/build'
bufferutil.target.mk:113: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
make: Leaving directory '/var/www/osbenji.de/openhab-cloud/node_modules/socket.io-client/node_modules/ws/build'
> utf-8-validate@1.2.2 install /var/www/osbenji.de/openhab-cloud/node_modules/utf-8-validate
> node-gyp rebuild
make: Entering directory '/var/www/osbenji.de/openhab-cloud/node_modules/utf-8-validate/build'
  CXX(target) Release/obj.target/validation/src/validation.o
In file included from ../node_modules/nan/nan.h:190:0,
             from ../src/validation.cc:15:
../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
   return obj->ForceSet(GetCurrentContext(), key, value, attribs);
In file included from ../node_modules/nan/nan_converters.h:59:0,
             from ../node_modules/nan/nan.h:195,
../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
../node_modules/nan/nan_converters_43_inl.h:15:45: error: no matching function for call to ‘v8::Value::ToBoolean(v8::Local<v8::Context>)’
   return val->To ## TYPE(GetCurrentContext());                                 \
../node_modules/nan/nan_converters_43_inl.h:18:1: note: in expansion of macro ‘X’
 X(Boolean)
In file included from ../src/validation.cc:7:0:
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2848:18: note: candidate: v8::Local<v8::Boolean> v8::Value::ToBoolean(v8::Isolate*) const
   Local<Boolean> ToBoolean(Isolate* isolate) const;
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2848:18: note:   no known conversion for argument 1 from ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
../node_modules/nan/nan_converters_43_inl.h:31:48: error: no matching function for call to ‘v8::Value::BooleanValue(v8::Local<v8::Context>)’
   return val->NAME ## Value(GetCurrentContext());                              \
../node_modules/nan/nan_converters_43_inl.h:34:1: note: in expansion of macro ‘X’
 X(bool, Boolean)
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2858:8: note: candidate: bool v8::Value::BooleanValue(v8::Isolate*) const
   bool BooleanValue(Isolate* isolate) const;
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2858:8: note:   no known conversion for argument 1 from ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
In file included from ../node_modules/nan/nan_new.h:189:0,
             from ../node_modules/nan/nan.h:196,
../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
../node_modules/nan/nan_implementation_12_inl.h:109:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
                       , obj));
/root/.cache/node-gyp/14.15.1/include/node/v8.h:4445:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
   static MaybeLocal<Function> New(
/root/.cache/node-gyp/14.15.1/include/node/v8.h:4445:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:
../node_modules/nan/nan_implementation_12_inl.h:345:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local<v8::String>&)’
   return v8::StringObject::New(value).As<v8::StringObject>();
/root/.cache/node-gyp/14.15.1/include/node/v8.h:5847:23: note: candidate: static v8::Local<v8::Value> v8::StringObject::New(v8::Isolate*, v8::Local<v8::String>)
   static Local<Value> New(Isolate* isolate, Local<String> value);
/root/.cache/node-gyp/14.15.1/include/node/v8.h:5847:23: note:   candidate expects 2 arguments, 1 provided
../node_modules/nan/nan_implementation_12_inl.h:345:58: error: expected primary-expression before ‘>’ token
../node_modules/nan/nan_implementation_12_inl.h:345:60: error: expected primary-expression before ‘)’ token
In file included from ../src/validation.cc:15:0:
../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
     v8::Isolate::GetCurrent(), target, func, argc, argv);
In file included from ../src/validation.cc:8:0:
/root/.cache/node-gyp/14.15.1/include/node/node.h:191:50: note: declared here
             NODE_EXTERN v8::Local<v8::Value> MakeCallback(
/root/.cache/node-gyp/14.15.1/include/node/node.h:108:42: note: in definition of macro ‘NODE_DEPRECATED’
 __attribute__((deprecated(message))) declarator
../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
     v8::Isolate::GetCurrent(), target, symbol, argc, argv);
/root/.cache/node-gyp/14.15.1/include/node/node.h:184:50: note: declared here
../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
     v8::Isolate::GetCurrent(), target, method, argc, argv);
/root/.cache/node-gyp/14.15.1/include/node/node.h:177:50: note: declared here
../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
../node_modules/nan/nan.h:890:53: error: no matching function for call to ‘v8::Value::ToString()’
   v8::Local<v8::String> string = from->ToString();
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2810:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
/root/.cache/node-gyp/14.15.1/include/node/v8.h:2810:44: note:   candidate expects 1 argument, 0 provided
../node_modules/nan/nan.h:900:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’
     length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3037:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const
   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3037:7: note:   no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
../node_modules/nan/nan.h:1453:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
../node_modules/nan/nan.h:1507:64: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, const v8::Local<v8::Value>&)’
 New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3670:37: note: candidate: v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)
   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3670:37: note:   candidate expects 3 arguments, 2 provided
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3673:37: note: candidate: v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)
   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
/root/.cache/node-gyp/14.15.1/include/node/v8.h:3673:37: note:   candidate expects 3 arguments, 2 provided
../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
../node_modules/nan/nan.h:1513:42: error: no matching function for call to ‘v8::Object::Set(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’
 New(persistentHandle)->Set(key, value);
../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
../node_modules/nan/nan.h:1519:44: error: no matching function for call to ‘v8::Object::Set(uint32_t&, const v8::Local<v8::Value>&)’
 New(persistentHandle)->Set(index, value);
../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
../node_modules/nan/nan.h:1525:61: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
     New(persistentHandle)->Get(New(key).ToLocalChecked()));
../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
../node_modules/nan/nan.h:1531:55: error: no matching function for call to ‘v8::Object::Get(const v8::Local<v8::String>&)’
 return scope.Escape(New(persistentHandle)->Get(key));
../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
../node_modules/nan/nan.h:1536:57: error: no matching function for call to ‘v8::Object::Get(uint32_t&)’
 return scope.Escape(New(persistentHandle)->Get(index));
In file included from /usr/include/c++/7/cassert:44:0,
             from /root/.cache/node-gyp/14.15.1/include/node/node_object_wrap.h:26,
             from ../src/validation.cc:11:
../node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
../node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
 assert(persistent().IsNearDeath());
In file included from ../node_modules/nan/nan.h:2190:0,
../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
../node_modules/nan/nan_object_wrap.h:67:18: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘MarkIndependent’
 persistent().MarkIndependent();
../node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
../node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
 assert(wrap->handle_.IsNearDeath());
../src/validation.cc: At global scope:
../src/validation.cc:106:30: error: ‘v8::Handle’ has not been declared
../src/validation.cc:106:36: error: expected ‘,’ or ‘...’ before ‘<’ token
../src/validation.cc: In static member function ‘static void Validation::Initialize(int)’:
../src/validation.cc:112:14: error: ‘target’ was not declared in this scope
 Nan::Set(target, Nan::New<String>("Validation").ToLocalChecked(), t->GetFunction());
../src/validation.cc:112:14: note: suggested alternative: ‘tzset’
          tzset
../src/validation.cc:112:86: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
../src/validation.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Validation::IsValidUTF8(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/validation.cc:131:50: error: no matching function for call to ‘v8::Value::ToObject()’
../src/validation.cc:140:12: error: variable or field ‘init’ declared void
../src/validation.cc:140:12: error: ‘Handle’ was not declared in this scope
../src/validation.cc:140:12: note: suggested alternative: ‘rand_r’
        rand_r
../src/validation.cc:140:25: error: expected primary-expression before ‘>’ token
../src/validation.cc:140:27: error: ‘target’ was not declared in this scope
../src/validation.cc:140:27: note: suggested alternative: ‘tzset’
                       tzset
../src/validation.cc:146:25: error: ‘init’ was not declared in this scope
 NODE_MODULE(validation, init)
../src/validation.cc:146:1: note: in expansion of macro ‘NODE_MODULE’
../src/validation.cc:146:25: note: suggested alternative: ‘int’
../src/validation.cc: In function ‘int is_valid_utf8(size_t, char*)’:
../src/validation.cc:81:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
   case 5 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:82:7: note: here
   case 4 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:82:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:83:7: note: here
   case 3 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:83:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:84:7: note: here
   case 2 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:84:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:85:7: note: here
   case 1 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:85:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:86:7: note: here
   case 0 : ch += (uint8_t) value[i];
../src/validation.cc: In function ‘int isLegalUTF8(const uint8_t*, int)’:
../src/validation.cc:51:13: warning: this statement may fall through [-Wimplicit-fallthrough=]
 case 4: if ((a = (*--srcptr)) < 0x80 || a > 0xBF) return 0;
../src/validation.cc:52:5: note: here
 case 3: if ((a = (*--srcptr)) < 0x80 || a > 0xBF) return 0;
../src/validation.cc:52:13: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:53:5: note: here
 case 2: if ((a = (*--srcptr)) < 0x80 || a > 0xBF) return 0;
../src/validation.cc:59:20: warning: this statement may fall through [-Wimplicit-fallthrough=]
     case 0xF4: if (a > 0x8F) return 0;
../src/validation.cc:62:5: note: here
 case 1: if (*source >= 0x80 && *source < 0xC2) return 0;
validation.target.mk:112: recipe for target 'Release/obj.target/validation/src/validation.o' failed
make: *** [Release/obj.target/validation/src/validation.o] Error 1
make: Leaving directory '/var/www/osbenji.de/openhab-cloud/node_modules/utf-8-validate/build'
gyp ERR! cwd /var/www/osbenji.de/openhab-cloud/node_modules/utf-8-validate
gyp ERR! not ok
> bcrypt@1.0.2 install /var/www/osbenji.de/openhab-cloud/node_modules/bcrypt
> node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.2/bcrypt_lib-v1.0.2-node-v83-linux-x64.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for bcrypt@1.0.2 and node@14.15.1 (node-v83 ABI) (falling back to source compile with node-gyp)
node-pre-gyp ERR! Tried to download(undefined): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.2/bcrypt_lib-v1.0.2-node-v83-linux-x64.tar.gz
make: Entering directory '/var/www/osbenji.de/openhab-cloud/node_modules/bcrypt/build'
  CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
  CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
sed: can't read ./Release/.deps/Release/obj.target/bcrypt_lib/src/blowfish.o.d.raw: No such file or directory
rm: cannot remove './Release/.deps/Release/obj.target/bcrypt_lib/src/blowfish.o.d.raw': No such file or directory
bcrypt_lib.target.mk:113: recipe for target 'Release/obj.target/bcrypt_lib/src/blowfish.o' failed
make: *** [Release/obj.target/bcrypt_lib/src/blowfish.o] Error 1
make: Leaving directory '/var/www/osbenji.de/openhab-cloud/node_modules/bcrypt/build'
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/var/www/osbenji.de/openhab-cloud/node_modules/bcrypt/lib/binding/bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=/var/www/osbenji.de/openhab-cloud/node_modules/bcrypt/lib/binding"
gyp ERR! cwd /var/www/osbenji.de/openhab-cloud/node_modules/bcrypt
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/var/www/osbenji.de/openhab-cloud/node_modules/bcrypt/lib/binding/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/var/www/osbenji.de/openhab-cloud/node_modules/bcrypt/lib/binding' (1)
node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/var/www/osbenji.de/openhab-cloud/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1048:16)
node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
node-pre-gyp ERR! System Linux 4.15.0-124-generic
node-pre-gyp ERR! command "/usr/bin/node" "/var/www/osbenji.de/openhab-cloud/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /var/www/osbenji.de/openhab-cloud/node_modules/bcrypt
node-pre-gyp ERR! node -v v14.15.1
node-pre-gyp ERR! node-pre-gyp -v v0.6.32
node-pre-gyp ERR! not ok
../src/bcrypt.cc:52:10: fatal error: node_blf.h: No such file or directory
compilation terminated.
bcrypt_lib.target.mk:113: recipe for target 'Release/obj.target/bcrypt_lib/src/bcrypt.o' failed
make: *** [Release/obj.target/bcrypt_lib/src/bcrypt.o] Error 1
gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.2.1 (node_modules/bufferutil):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.2.1 install: `node-gyp rebuild`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.2.2 (node_modules/utf-8-validate):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.2.2 install: `node-gyp rebuild`
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! bcrypt@1.0.2 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the bcrypt@1.0.2 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2020-11-23T15_00_18_826Z-debug.log
make: Entering directory ‘/var/www/osbenji.de/openhab-cloud/node_modules/bufferutil/build’
static void Initialize(v8::Handlev8::Object target)
No experience, but this looks like the important part.
I found a different tutorial on how to install openhab-cloud.
https://community.openhab.org/t/openhab-cloud-setup-guide-for-azure-and-ifttt/83208
This one worked just fine for me.
