Errors after upgrade to 2.2
Hey guys,
I am using a Raspberry Pi 3 with the stable release 2.2 - before I was using the 2.1 stable release.
After the upgrade I ran in many problems (karaf console, switch from SmartHome-Designer and so on). But here are some problems I do not know how to fix and I cannot find anything on the web for it. (Do not wonder about the time, I just restarted the Pi to make sure that they still exist.)
  1. [DONE - solved in Post #2] Some Execution failed, but what exactly - how to find out? That error appears three times in the log:
19:58:55.728 [WARN ] [clipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): error=2, Datei oder Verzeichnis nicht gefunden)
  1. [DONE - solved in Post #7] The public holiday-rule (just used the code from the sample rules: https://github.com/openhab/openhab1-addons/wiki/Samples-Rules#how-to-calculate-public-holidays). I really love it and it was working fine with 2.1 and now it does not:
19:59:21.910 [ERROR] [untime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Public Holiday': An error occurred during the script execution: SpecialDay uses unsupported uri fragment holiday.script#/1/@members.160
  1. Problem with ā€œgetEventā€. The funny thing is that I had it working on 2.2 till a restart, but I do not know how it worked, because I changed nothing. In 2.1 I had no problems at all:
20:00:13.498 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Office Andreas Button': 'getEvent' is not a member of 'org.eclipse.smarthome.core.thing.events.ChannelTriggeredEvent'; line 48, column 20, length 24
This is the standard rule for the Xiaomi Smart Home Buttons - just like this:
rule "Xiaomi Switch"
    Channel "mihome:sensor_switch:<ID>:button" triggered
    var actionName = receivedEvent.getEvent()
    switch(actionName) {
        case "SHORT_PRESSED": {
            <ACTION>
        case "DOUBLE_PRESSED": {
            <ACTION>
        case "LONG_PRESSED": {
            <ACTION>
        case "LONG_RELEASED": {
            <ACTION>
@Svolli wrote here Mi(Xiaomi) Smart home bindings? that it has been changed, but I do not understand why it worked for me some time in the 2.2 release. It would be very good to have this again, because I got many buttons with rules. :confused:
Last and longest error is coming now, I already found that https://github.com/eclipse/smarthome/issues/4751 about it, but I do not understand what to do, but it seems to be not really important - just wanna make sure… :tired_face: :
 19:57:57.963 [ERROR] [rg.eclipse.smarthome.config.discovery] - [org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl(30)] The addDiscoveryService method has thrown an exception
        at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.addDiscoveryService(DiscoveryServiceRegistryImpl.java:453) [108:org.eclipse.smarthome.config.discovery:0.10.0.b1]
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
        at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:658) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager.open(DependencyManager.java:1556) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:261) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [46:org.apache.felix.scr:2.0.12]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
        at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
        at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1118) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1520) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1006) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:859) [46:org.apache.felix.scr:2.0.12]
        at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [19:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
        at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [46:org.apache.felix.scr:2.0.12]
        at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [46:org.apache.felix.scr:2.0.12]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
        at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
        at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Thank you for all your time! I was pretty unsure about that upgrade, because most of my stuff was working really well (only had problems with the astro rule execution - [Astro Binding]: Queue full), but yeah that was annoying so I wanted to give it a try… Really thank you.
Greetings
Andy
Just read the docs on this one:
http://docs.openhab.org/addons/bindings/network/readme.html#arping
Thank you sihui - one point done. Did not think that ā€œarpingā€ is a program I could need for anything :confused:
On your No 2:
The error points to this part:
if (holidayName!=null) {
    postUpdate(SpecialDay,holidayName)
You could try to use it like:
SpecialDay.postUpdate(holidayName
On the other hand, do you really need the holidayName string, if not just delete the whole if part.
Hallo Jürgen,
I am using that string in my sitemap:
Text item=SpecialDay label="Feiertag" icon="calendar" visibility=[Holiday==ON]
So I would like to keep it :slight_smile: Changed it to the following:
if (holidayName !== null) {
    SpecialDay.postUpdate(holidayName)
Visual Studio Code still gives these errors:
message: 'Invalid number of arguments. The method postUpdate(Item, State) is not applicable for the arguments
message: 'Type mismatch: cannot convert from StringItem to State'
Do you think it is working anyways? :slight_smile:
Can’t say ATM, I’m using this script but without this part.
I’ll try to have a look.
It did run through with just the remark to change the ā€œ!=ā€ to ā€œ!==ā€ because null is used on one side.
So my code looks like this now:
if (holidayName!==null) {
    HolidayTest.postUpdate(holidayName)
I’ll have to wait for a Holiday to see the correct output, but that won’t take very long.
Yeah very lucky that we are close to some. Even if it is not working there is more coming to try it again :smiley:
I already fixed all my rules with null in it and added === & !==; I tried to understand it, but yeah… I just did it.
Thank you for your help - I will mark it as done in my list.
@DaAndy, please see this discussion regarding the Queue Full message. If you need the older astro binding, just let me know.
I did not look for the reason, I just did this:
rule "Xiaomi Switch - SHORT_PRESSED"
    Channel "mihome:sensor_switch:<ID>:button" triggered SHORT_PRESSED
    logInfo("RULE.XiaomiSwitch","<-- SHORT_PRESSED")
Hello Brad,
the discussion you linked is a blogpost about ā€œTaipei Signal Armyā€? :smiley: I do not have that Queue Full message anymore after the upgrade to 2.2 - main reason for the upgrade.
@Olymp
Hey Sergey,
I want to avoid to change all my rules - most of my buttons do need short, double & long pressed, so I will have three rules for one button then. That is why I am asking. The overview with one rule for each button was really good in my files and I do not want to loose it. Even it worked for some time and if you look for these ChannelTriggeredEvents there is even ā€œgetEventā€ listed, so this has to be a bug or something - at least I think so.
But thank you for your help. I guess that I will just do a backup and then split up the rules to have the buttons working again and when the problem is solved I can just put my backup in again. :slight_smile:
I suggested the option to work now! It is better to have 3 rules that work than one that does not work.
Um yeah - about that…
Someone sent me the following
                   _/^\_
                 /_o.I %_\    *
    *           (`'--:o(_@;
               /`;--.,__ `')             *
              ;@`o % O,*`'`&\
        *    (`'--)_@ ;o %'()\      *
             /`;--._`''--._O'@;
            /&*,()~o`;-.,_ `""`)
 *          /`,@ ;+& () o*`;-';\
           (`""--.,_0 +% @' &()\
           /-.,_    ``''--....-'`)  *
      *    /@%;o`:;'--,.__   __.'\
          ;*,&(); @ % &^;~`"`o;@();         *
          /(); o^~; & ().o@*&`;&%O\
    jgs   `"="==""==,,,.,="=="==="`
       __.----.(\-''#####---...___...-----._
     '`         \)_`"""""`
           o(  )_-\
ā€˜ā€™'
to which I had replied that one could just imagine that coming out of an old teletype like a Model 15 or Kleinschmidt on Christmas Eve many years ago.
The thread I was supposed to be referring you to is here.
I’ve made these changes too, it is working, but this did not fix the error messages in log.
Any idea?
Oh, it’s important. It’s possible/likely that discovery will not work, or will not work correctly, by the binding for which this error was generated.
This does not solve it on my side.
can you post the code you use?
Post the code you use and the errors you get.
That way we can have a look.
I played around a lot. For me it looks like a timing problem.
Sometimes no error in log after OH restart, sometimes a lot.
What I see, the timing between items load and persistance load is faster now. On OH2.1 it take up to 5sec between items and persistance ae loaded.
Can this be configured?
Soemtimes I get error messages that the items do not exist at the time the on startup persistance runs or a rule triggers after restart of OH2.2
You were referring to an observed error while executing the holiday script. However that does not correlate with your reported findings.
Please verify.
Not sure. The errors are related to the holiday.script. But the do not come on every restart of OH2.2
