Hi
I got my first setup up and running including some rules.
Now i reviewed the logs and got some issues and i don’t know how to resolve them. For example it plots me:
thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at items/WZ_Rollershutter_Balcony/state' for the unknown item 'WZ_Rollershutter_Balcony'.
I had that item in the past but now i renamed it but it seems to be in some file. i restarted openhab and my raspberry a few times but i can’t get rid of that error.
next problem:
2017-09-06 09:28:52.350 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
both errors / Warnings are plotted very often.
if you need more information i can provide you the log.
After a fresh openhab restart i get this:
2017-09-06 09:29:14.352 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Netzwerk.items'
2017-09-06 09:29:14.448 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Wall_Plugs.items'
2017-09-06 09:29:14.472 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Virtual.items'
2017-09-06 09:29:14.519 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Groups.items'
2017-09-06 09:29:14.600 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Hue.items'
2017-09-06 09:29:14.694 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Rollershutter.items'
2017-09-06 09:29:21.564 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Wohnzimmer.rules'
2017-09-06 09:29:22.740 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2017-09-06 09:29:23.811 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Hue.things'
2017-09-06 09:29:30.640 [INFO ] [nding.zway.handler.ZWayBridgeHandler] - Initializing Z-Way bridge ...
2017-09-06 09:29:31.096 [INFO ] [nding.zway.handler.ZWayBridgeHandler] - Z-Way bridge successfully authenticated
2017-09-06 09:29:43.407 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.178.90
2017-09-06 09:29:43.409 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.178.95:8080
2017-09-06 09:29:43.420 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.178.90
2017-09-06 09:29:43.422 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.178.95:8443
2017-09-06 09:29:44.791 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-09-06 09:29:45.122 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.link.ThingLinkManager@15dfcbc' takes more than 5000ms.
2017-09-06 09:29:45.184 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-09-06 09:29:45.556 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-09-06 09:29:48.781 [INFO ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at 'items/WZ_Rollershutter_Balcony/state' for the unknown item 'WZ_Rollershutter_Balcony'.
2017-09-06 09:29:50.308 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.link.ThingLinkManager@15dfcbc' takes more than 5000ms.
2017-09-06 09:30:01.152 [INFO ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at 'items/WZ_Rollershutter_Balcony/state' for the unknown item 'WZ_Rollershutter_Balcony'.
