I installed the latest snapshot as of the writing of this message on Ubuntu. Everything seemed to go OK. I pulled up the website and selected RECOMMENDED SETUP. It’s still spinning after a couple minutes but is giving lots of errors in the log. Is this expected?
2019-01-24 00:15:50.487 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : doFindMethod: Suitable but non-accessible method found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:15:50.496 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : findMethod: Suitable but non-accessible method setScheduler found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl, subclass of org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:15:50.498 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : bind method [setScheduler] not found; Component will fail
2019-01-24 00:15:50.499 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : bind method [setScheduler] not found
2019-01-24 00:15:50.502 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : doFindMethod: Suitable but non-accessible method found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:15:50.503 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : findMethod: Suitable but non-accessible method unsetScheduler found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl, subclass of org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:15:50.504 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : unbind method [unsetScheduler] not found; Component will fail
2019-01-24 00:15:50.505 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : unbind method [unsetScheduler] not found
2019-01-24 00:15:50.770 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.188:8080
2019-01-24 00:15:50.771 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.188:8443
2019-01-24 00:15:51.271 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-01-24 00:23:27.941 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-01-24 00:24:29.669 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : doFindMethod: Suitable but non-accessible method found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:24:29.682 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : findMethod: Suitable but non-accessible method setScheduler found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl, subclass of org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:24:29.684 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : bind method [setScheduler] not found; Component will fail
2019-01-24 00:24:29.685 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : bind method [setScheduler] not found
2019-01-24 00:24:29.686 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : doFindMethod: Suitable but non-accessible method found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:24:29.687 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : findMethod: Suitable but non-accessible method unsetScheduler found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl, subclass of org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:24:29.688 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : unbind method [unsetScheduler] not found; Component will fail
2019-01-24 00:24:37.730 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-01-24 00:24:38.166 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.188:8080
2019-01-24 00:24:38.167 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.188:8443
2019-01-24 00:35:07.356 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-01-24 00:38:58.749 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : doFindMethod: Suitable but non-accessible method found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:38:58.758 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : findMethod: Suitable but non-accessible method setScheduler found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl, subclass of org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl> 2019-01-24 00:15:50.487 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : doFindMethod: Suitable but non-accessible method found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
2019-01-24 00:38:58.758 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : findMethod: Suitable but non-accessible method setScheduler found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl, subclass of org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl2019-01-24 00:15:50.487 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(56)] : doFindMethod: Suitable but non-accessible method found in class org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl
KEEPS GOING AND THEN THE END OF THE LOG AS IT STANDS RIGHT NOW.
2019-01-25 00:36:10.944 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : unbind method [unsetScheduler] not found; Component will fail
2019-01-25 00:36:10.946 [ERROR] [org.eclipse.smarthome.core ] - bundle org.eclipse.smarthome.core:0.11.0.201901181547 (102)[org.eclipse.smarthome.core.internal.scheduler.PeriodicSchedulerImpl(44)] : unbind method [unsetScheduler] not found
2019-01-25 00:36:19.851 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-01-25 00:36:20.820 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.50:8080
2019-01-25 00:36:20.822 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.50:8443
2019-01-25 00:36:49.758 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-habpanel, openhab-ui-paper’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-basic; type=karaf.feature; version=“[2.5.0.SNAPSHOT,2.5.0.SNAPSHOT]”; filter:=“(&(osgi.identity=openhab-ui-basic)(type=karaf.feature)(version>=2.5.0.SNAPSHOT)(version<=2.5.0.SNAPSHOT))” [caused by: Unable to resolve openhab-ui-basic/2.5.0.SNAPSHOT: missing requirement [openhab-ui-basic/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.ui.basic; type=osgi.bundle; version=“[2.5.0.201901231358,2.5.0.201901231358]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui.basic/2.5.0.201901231358: missing requirement [org.openhab.ui.basic/2.5.0.201901231358] osgi.wiring.package; filter:=“(osgi.wiring.package=org.apache.commons.net.util)”]]
2019-01-25 00:37:11.034 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-habpanel, openhab-ui-paper’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-basic; type=karaf.feature; version=“[2.5.0.SNAPSHOT,2.5.0.SNAPSHOT]”; filter:=“(&(osgi.identity=openhab-ui-basic)(type=karaf.feature)(version>=2.5.0.SNAPSHOT)(version<=2.5.0.SNAPSHOT))” [caused by: Unable to resolve openhab-ui-basic/2.5.0.SNAPSHOT: missing requirement [openhab-ui-basic/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.ui.basic; type=osgi.bundle; version=“[2.5.0.201901231358,2.5.0.201901231358]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui.basic/2.5.0.201901231358: missing requirement [org.openhab.ui.basic/2.5.0.201901231358] osgi.wiring.package; filter:=“(osgi.wiring.package=org.apache.commons.net.util)”]]
2019-01-25 00:38:11.027 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-habpanel, openhab-ui-paper’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-basic; type=karaf.feature; version=“[2.5.0.SNAPSHOT,2.5.0.SNAPSHOT]”; filter:=“(&(osgi.identity=openhab-ui-basic)(type=karaf.feature)(version>=2.5.0.SNAPSHOT)(version<=2.5.0.SNAPSHOT))” [caused by: Unable to resolve openhab-ui-basic/2.5.0.SNAPSHOT: missing requirement [openhab-ui-basic/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.ui.basic; type=osgi.bundle; version=“[2.5.0.201901231358,2.5.0.201901231358]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui.basic/2.5.0.201901231358: missing requirement [org.openhab.ui.basic/2.5.0.201901231358] osgi.wiring.package; filter:=“(osgi.wiring.package=org.apache.commons.net.util)”]]
2019-01-25 00:39:11.142 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-habpanel, openhab-ui-paper’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-basic; type=karaf.feature; version=“[2.5.0.SNAPSHOT,2.5.0.SNAPSHOT]”; filter:=“(&(osgi.identity=openhab-ui-basic)(type=karaf.feature)(version>=2.5.0.SNAPSHOT)(version<=2.5.0.SNAPSHOT))” [caused by: Unable to resolve openhab-ui-basic/2.5.0.SNAPSHOT: missing requirement [openhab-ui-basic/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.ui.basic; type=osgi.bundle; version=“[2.5.0.201901231358,2.5.0.201901231358]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui.basic/2.5.0.201901231358: missing requirement [org.openhab.ui.basic/2.5.0.201901231358] osgi.wiring.package; filter:=“(osgi.wiring.package=org.apache.commons.net.util)”]]
2019-01-25 00:40:11.115 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-habpanel, openhab-ui-paper’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-basic; type=karaf.feature; version=“[2.5.0.SNAPSHOT,2.5.0.SNAPSHOT]”; filter:=“(&(osgi.identity=openhab-ui-basic)(type=karaf.feature)(version>=2.5.0.SNAPSHOT)(version<=2.5.0.SNAPSHOT))” [caused by: Unable to resolve openhab-ui-basic/2.5.0.SNAPSHOT: missing requirement [openhab-ui-basic/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.ui.basic; type=osgi.bundle; version=“[2.5.0.201901231358,2.5.0.201901231358]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui.basic/2.5.0.201901231358: missing requirement [org.openhab.ui.basic/2.5.0.201901231358] osgi.wiring.package; filter:=“(osgi.wiring.package=org.apache.commons.net.util)”]]
2019-01-25 00:41:11.133 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-habpanel, openhab-ui-paper’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-basic; type=karaf.feature; version=“[2.5.0.SNAPSHOT,2.5.0.SNAPSHOT]”; filter:=“(&(osgi.identity=openhab-ui-basic)(type=karaf.feature)(version>=2.5.0.SNAPSHOT)(version<=2.5.0.SNAPSHOT))” [caused by: Unable to resolve openhab-ui-basic/2.5.0.SNAPSHOT: missing requirement [openhab-ui-basic/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.ui.basic; type=osgi.bundle; version=“[2.5.0.201901231358,2.5.0.201901231358]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui.basic/2.5.0.201901231358: missing requirement [org.openhab.ui.basic/2.5.0.201901231358] osgi.wiring.package; filter:=“(osgi.wiring.package=org.apache.commons.net.util)”]]
2019-01-25 00:42:11.051 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-habpanel, openhab-ui-paper’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-basic; type=karaf.feature; version=“[2.5.0.SNAPSHOT,2.5.0.SNAPSHOT]”; filter:=“(&(osgi.identity=openhab-ui-basic)(type=karaf.feature)(version>=2.5.0.SNAPSHOT)(version<=2.5.0.SNAPSHOT))” [caused by: Unable to resolve openhab-ui-basic/2.5.0.SNAPSHOT: missing requirement [openhab-ui-basic/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.ui.basic; type=osgi.bundle; version=“[2.5.0.201901231358,2.5.0.201901231358]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui.basic/2.5.0.201901231358: missing requirement [org.openhab.ui.basic/2.5.0.201901231358] osgi.wiring.package; filter:=“(osgi.wiring.package=org.apache.commons.net.util)”]]
2019-01-25 00:43:11.119 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-habpanel, openhab-ui-paper’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-basic; type=karaf.feature; version=“[2.5.0.SNAPSHOT,2.5.0.SNAPSHOT]”; filter:=“(&(osgi.identity=openhab-ui-basic)(type=karaf.feature)(version>=2.5.0.SNAPSHOT)(version<=2.5.0.SNAPSHOT))” [caused by: Unable to resolve openhab-ui-basic/2.5.0.SNAPSHOT: missing requirement [openhab-ui-basic/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.ui.basic; type=osgi.bundle; version=“[2.5.0.201901231358,2.5.0.201901231358]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui.basic/2.5.0.201901231358: missing requirement [org.openhab.ui.basic/2.5.0.201901231358] osgi.wiring.package; filter:=“(osgi.wiring.package=org.apache.commons.net.util)”]]
