- Platform information:
- Hardware: Raspberry Pi3+
- OS: openhabian latest stable
Hello everybody,
I have an ESP32 that collects the data from my plant sensors and sends it to my broker via MQTT.
The problem, I get the following error message in the log.
2019-04-14 11:32:49.569 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.moi' in '{"tem":"19.9"}'
2019-04-14 11:32:49.577 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.fer' in '{"tem":"19.9"}'
2019-04-14 11:32:49.588 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.lux' in '{"tem":"19.9"}'
2019-04-14 11:32:51.017 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.tem' in '{"moi":"49"}'
2019-04-14 11:32:51.023 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.fer' in '{"moi":"49"}'
2019-04-14 11:32:51.027 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.lux' in '{"moi":"49"}'
What im doing wrong?
Things:
Thing topic mirflora1 "Blume 1" @ "BT-GERÄTE" {
Channels:
Type string : moi "Bodenfeuchte" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A3826", transformationPattern="JSONPATH:$.moi"]
Type string : tem "Temperatur" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A3826", transformationPattern="JSONPATH:$.tem"]
Type string : fer "Fruchtbarkeit" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A3826", transformationPattern="JSONPATH:$.fer"]
Type string : lux "Helligkeit" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A3826", transformationPattern="JSONPATH:$.lux"]
Thing topic mirflora2 "Blume 2" @ "BT-GERÄTE" {
Channels:
Type string : moi "Bodenfeuchte" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A36A8", transformationPattern="JSONPATH:$.moi"]
Type string : tem "Temperatur" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A36A8", transformationPattern="JSONPATH:$.tem"]
Type string : fer "Fruchtbarkeit" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A36A8", transformationPattern="JSONPATH:$.fer"]
Type string : lux "Helligkeit" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A36A8", transformationPattern="JSONPATH:$.lux"]
Thing topic mirflora3 "Blume 3" @ "BT-GERÄTE" {
Channels:
Type string : moi "Bodenfeuchte" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A3BAC", transformationPattern="JSONPATH:$.moi"]
Type string : tem "Temperatur" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A3BAC", transformationPattern="JSONPATH:$.tem"]
Type string : fer "Fruchtbarkeit" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A3BAC", transformationPattern="JSONPATH:$.fer"]
Type string : lux "Helligkeit" [ stateTopic="home/BLEGateway/BTtoMQTT/C47C8D6A3BAC", transformationPattern="JSONPATH:$.lux"]
Items:
Group gBlume
Number whz_blume1_tem "Temperatur" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora1:tem"}
Number whz_blume1_fer "Fruchtbarkeit" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora1:fer"}
Number whz_blume1_lux "Sonnenlicht" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora1:lux"}
Number whz_blume1_moi "Feuchtigkeit" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora1:moi"}
Number whz_blume1_tem2 "Temperatur" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora2:tem"}
Number whz_blume1_fer2 "Fruchtbarkeit" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora2:fer"}
Number whz_blume1_lux2 "Sonnenlicht" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora2:lux"}
Number whz_blume1_moi2 "Feuchtigkeit" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora2:moi"}
Number whz_blume1_tem3 "Temperatur" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora3:tem"}
Number whz_blume1_fer3 "Fruchtbarkeit" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora3:fer"}
Number whz_blume1_lux3 "Sonnenlicht" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora3:lux"}
Number whz_blume1_moi3 "Feuchtigkeit" <flower> (gBlume) {channel="mqtt:topic:broker:mirflora3:moi"}
MQTT-Message that the broker received
Client mosqsub/27667-openhabno received PUBLISH (d0, q0, r0, m0, ‘home/BLEGateway/BTtoMQTT/C47C8D6A3826’, … (14 bytes))
home/BLEGateway/BTtoMQTT/C47C8D6A3826 {“tem”:“20.2”}
Client mosqsub/27667-openhabno received PUBLISH (d0, q0, r0, m0, ‘home/BLEGateway/BTtoMQTT/C47C8D6A3BAC’, … (14 bytes))
home/BLEGateway/BTtoMQTT/C47C8D6A3BAC {“lux”:“6642”}
Client mosqsub/27667-openhabno received PUBLISH (d0, q0, r0, m0, ‘home/BLEGateway/BTtoMQTT/C47C8D6A3BAC’, … (13 bytes))
home/BLEGateway/BTtoMQTT/C47C8D6A3BAC {“fer”:“425”}
Client mosqsub/27667-openhabno received PUBLISH (d0, q0, r0, m0, ‘home/BLEGateway/BTtoMQTT/C47C8D6A36A8’, … (12 bytes))
home/BLEGateway/BTtoMQTT/C47C8D6A36A8 {“moi”:“36”}
Client mosqsub/27667-openhabno received PUBLISH (d0, q0, r0, m0, ‘home/BLEGateway/BTtoMQTT/C47C8D6A3826’, … (12 bytes))
home/BLEGateway/BTtoMQTT/C47C8D6A3826 {“moi”:“41”}
Client mosqsub/27667-openhabno received PUBLISH (d0, q0, r0, m0, ‘home/BLEGateway/BTtoMQTT/C47C8D6A3BAC’, … (12 bytes))
home/BLEGateway/BTtoMQTT/C47C8D6A3BAC {“moi”:“49”}
Client mosqsub/27667-openhabno received PUBLISH (d0, q0, r0, m0, ‘home/BLEGateway/BTtoMQTT/C47C8D6A3826’, … (13 bytes))
home/BLEGateway/BTtoMQTT/C47C8D6A3826 {“lux”:“492”}
