#Event missing from the ASTRO binding on 24 march 2018
Hi either f.y.i. or awareness
Since today i am missing the Astro binding events
Last one received according to the log:
2018-03-24 02:06:00.006 [vent.ChannelTriggeredEvent] - astro:moon:local:set#event triggered END
Is this just a hickup or change in “availability”
The Astro binding is still online and other things of this binding like
Sun Phase (text), azimuth and elevation are still working as normal.
Any ideas?
What version do you use? DST bug fix in 2.3.0-SNAPSHOT
Hi, after I did some update, upgrade and apply improvements in the OpenHABion config menu I am still running 2.2.0-1 but the good news is also the astro#events are working again.
          Welcome to            __  _____    ____  _
        ____  ____  ___  ____  / / / /   |  / __ )(_)___ _____
       / __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __  / / __ `/ __ \
      / /_/ / /_/ /  __/ / / / __  / ___ |/ /_/ / / /_/ / / / /
      \____/ .___/\___/_/ /_/_/ /_/_/  |_/_____/_/\__,_/_/ /_/
          /_/
              openHAB 2.2.0-1 (Release Build)
The “bad” news is that my astro#items, among others created in the PaperUI are back to their default (?) values and remapping info like “Season [MAP(astro.map):%s]” in item “Season_Name” needs to be redone.
However despite my efforts to change this again it does not get updated, Is this a bug of something an incompleteness inside OpenHABian?
