This looks nice! Do you use the official CALDAV binding?
Could you please share code for the template, items and binding config?
Man, I wish I could get access to my outlook.com Microsoft calendar to do something like this ![]()
Yes using the CalDAV binding
Got it working with ICloud you can read here [SOLVED] Apple icloud CalDav connection - #6 by Andrew_Pawelski
I used a modified CSS from the awesome work of @pmpkk Matrix Theme for HABPanel
I will share via a widget but I have found experience varies - if there is no place on an event the binding crashes everything and the sitemaps wont load which is a real shame
Heres the custom widget page any more info please let me know
Custom Widget: Up Next Calendar
Thank you for this code, looks awesome on my computer. Problem is now that it doesnât scale to phone size. How might I allow it to do this? Also, can you explain what should be changed to match my items, ive pakyed a bit, but cant figure it out, i have no knowledge of htmlâŠfor example, the ânameâ i assume is the name of the thing. âItemâ i assume is the name of the item itself. I coukd be wring in my assumption, as i have entered my own stuff in those areas, but cannot get it to work.
Also, this would be awesome if it were responsive. Do you know how, and can you help? Id like to use your example as its exactly the dashboard i want to use.
Is there a way to set the button position to be constrained to the template widget its on? That way when it gets resized on a different screen size, it stays where its meant to be. Im trying this on the mobile experimental option, but the button is constrained to the screen, not the template widget.
Maybe use percentage instead of pixels for top and left i.e. left: 17.3% etc.? Just an idea, I havenât really tested it.
thank you for that, it workedâŠhow do i change the icon color in nibi79s widget
Ciao, mi spiegate come fare?
English only please.
Hello, I hope to make me understand âŠ
You can tell me how to do it
Hello Omar,
welcome to this forum.
It is not clear what you want to know.
If you are looking for basic HABPanel instructions, take a look here:
http://docs.openhab.org/addons/uis/habpanel/readme.html
If you donât speak English, just feed it through https://translate.google.com, a lot of us donât speak native English ![]()
PeterJ,
Regarding your actual Nest Protect Icon, where are you grabbing the icon/image file from on your server?
I see the following lines that are pertinent:
<div ng-init="ServerPath='/static'; IconSet='nest'"></div>
<td rowspan="4" style="padding: 0px; padding-top: 0px; padding-bottom: 0px"><img id="nest-icon" height="80" width="80" src="{{ServerPath}}/images/{{IconSet}}/nest-protect-glow-blue.png"/></td>
I tried to just modify the second line there to the following:
<td rowspan="4" style="padding: 0px; padding-top: 0px; padding-bottom: 0px"><img id="nest-icon" height="80" width="80" src="/etc/openhab2/icons/classic/nest_protect_32.png"/></td>
I have couple .png files I made of a nest protect, one is 80x80 and the other is 32x32. I tried forcing the widget to use them, but am unable.
The icons are stored in /etc/openhab2/html/images/nest/. The /static/ directory maps to /etc/openhab2/html/ directory on the filesystem.
Thank you so much. That did it!!!
Marcel, thanks a lot for jumping in here, I only returned to the forum today to answer the question, to find you already did.
Hey guys love seeing all your panel layouts. I have a couple questions and I am very new so please stick with me.
I have a Panel Developed but canât seem to get the Weather to integrate into the panel.
Iâd also like to see a interactive list of sensors (Doors and Windows) any thoughts on that as to who to show it?
The other question is to display Pandora Music info any thoughts on showing this on the screen?
Thanks Guys!
What problem are you having with the weather?
Cant seem to get it to display anything. Just a empty box.
Can you post your code?
