Hi there,
I migrated to OH3 and now I’m having problems with the call of a python script with an additional parameter. I’d like to set the Volume of my LG-TV via Serial Port (yeah… no smart TV, but it works).
rule "LG Volume"
Item LG_Volume received command
var Number = LG_Volume.state.toString;
logInfo("lgvolume.rules", "TV Lautstärke gesetzt auf" + Number)
Thread::sleep(500)
executeCommandLine("/home/to/fernseher_lautstärke.py " + Number)
A similar script to power on / off works. I can also call the script from the command line using “/home/to/fernseher_lautstärke.py 13”, also as user openhab.
However, when openhab tries to invoke the script it fails and the log says:
021-01-24 13:00:28.428 [WARN ] [rg.openhab.core.io.net.exec.ExecUtil] - Error occurred when executing commandLine '[/home/to/fernseher_lautstärke.py 13]'
java.io.IOException: Cannot run program "/home/to/fernseher_lautstärke.py 13": error=2, No such file or directory
It worked before the update and the call seems right. What am I missing? Did anything change hiere?
My python script looks like this, but I suppose the error is somewhere else because calling it from the console works…:
#!/usr/bin/env python
import serial
import sys
ser = serial.Serial(
port='/dev/LGTV',
baudrate = 9600,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE,
bytesize=serial.EIGHTBITS,
timeout=1
temporaer = hex(int(sys.argv[1]))
temporaer2 = temporaer.replace("0x","")
ser.write('kf 01 %s\r'%(temporaer2))
Thanks for your support!
