Dear all,
I have been inspired by many posts and also I could not find a straight forward solution to my need, which was to extract data from my heat pump (Stiebel Eltron ISG), to store the data in a database and be able to render them into graphs. Please note that you can use this type of process to extract and record data from other devices displaying web pages or also allowing API calls such as sonnenBatterie.
I am using a solution that combines openHAB to extract the data, InfluxDB to store them and Grafana to display them into graphs.
I wanted to give back to the community what I’ve learned hoping that it will be useful to somebody. This is a step-by-step guide to install the entire suite of packages and configuration.
As this is my first post and one of my first project, it contains certainly some errors and I am glad to receive feedback.
Here is a screenshot of what the results look like:
Install openHAB, InfluxDB, Grafana to read, record Stiebel Eltron ISG data and present them graphically
Installation and configuration of openHAB on a Raspberry Pi 3 (RPI)
The principle is that I am using openHAB to perform “web scrapping” of the ISG page through which you can read the data of your Stiebel Heat Pump. For that I am using REGEX (see later notes on the fact that REGEX expressions may depend on the operating system, i.e. in my case Raspian (linux))
It is important to make your ISG “password less” (no user name and no password), meaning that when you type the IP address of your ISG you should be able to see the web page and the actual data directly. I couldn’t find a way to include credentials in a REGEX call. But as the device is on my network I thought it is not a major security issue. I’ll improve this when I will find or someone suggets a solution. If you are not comfortable making your ISG “pasword less” this guide does not work. From memory, you go in the ISG: Profile / Safety and blank out User Name and Password. If this is not the case, REGEX will obviously return a null data as there is nothing to read.
How does it work?
- home.items: I am creating an item for each data I want to retrieve from the ISG page. At this stage, each item is in a string format. For example OutTempStr
- This item item is followed by a second item which, will be the equivalent in number format e.g. OutTempNum
- As you can see you have for a pair of two items for each data element, which are named xxxStr for string and xxxNum for number; examples are: OutTempStr, OutTempNum
- The conversion string to number occures in home.rules
- These variables are then used to record their historical data values in InfluxDB and Grafana reads the data in InfluxDB to represent them graphically.
Also note that I will be using the following in this guide. Obvioulsy adjust with the actual IP adresses of your own devices:
- 192.168.1.125 refers to the IP address of the Raspberry PI
- 192.168.1.132 refers to the IP address of the ISG page (Stiebel)
Initial installation
Refer to the openHABian installation procedure at https://docs.openhab.org/installation/. Please note that this guide was developped in September 2017 and menus, options may change over time.
openHAB initial configuration
- Once openHAB has been installed on the RPI, obtain the IP address from the RPI, it is visible after logging. For the remaining part of this guide I will use the following IP for illustration purposes: 192.168.1.125
- Go to
http://192.168.1.125:8080 - Select the “Expert” package (it takes approx. 2 mins)
- Go to Putty and open an SSH connection to the RPI using the 192.168.1.125 IP address
- User is “openhabian” and password is still the default one: “openhabian”
- Once logged in, type
sudo openhabian-config - Reboot the RPI by typing
sudo reboot - Once rebooted, from the menu, select “Update”
- Once done, select “Upgrade Systems” from the menu
- Go to “Apply Improvements” and perform each improvements listed in the sub-menu, some time you will need to type exit when the process seems to hang
- Exit “openhabian-config”
- Once back in the command line, type
passwd.This will change the password for openhabian - Once completed, type,
sudo smbpasswd openhabian. This will change the smb password for openhabian - Type
sudo timedatectl set-timezonefor example Europe/Zurich (note typetimedatectl list-timezonesto get the available time zones) - Type
timedatectlto check the set timezone - Type
sudo reboot
OpenHAB setup of Items, Rules, Sitemap
- Go to the openHAB web interface, i.e.
http://192.168.1.125:8080 - Go to “PAPER UI”
- In the menu (top left corner) select “Add-ons”
- Go to “BINDINGS” and install “HTTP Bindings”
- log:tail can be accessed by typing
http://192.168.1.125:9001check that the binding has been installed and refresh the page
Caching the ISG pages
- Go into the RPI by accessing SSH
- Type
sudo nano /etc/openhab2/services/http.cfg - Copy paste the two http links (see examples at the end of this topic)
- This caches the two pages and avoids calls to the ISG for each items value retrievals
Creating Items
- Type
sudo nano /etc/openhab2/items/home.items - Copy paste the items list (see examples at the end of this topic)
Creating Rules
- Type
sudo nano /etc/openhab2/rules/home.rules - Copy paste the rules list (see examples at the end of this topic)
Creating Sitemap
- Type
sudo nano /etc/openhab2/sitemaps/home.sitemap - Copy paste the sitemap list (see examples at the end of this topic)
- Setting the default indications for “CLASSIC UI” and “BASIC UI”. This will tell openHAB, which files to look for Items, Rules and Sitemap
- Go to “PAPER UI” and in the top left corner menu “Configuration” and “Services”
- Go to “Basic UI” and select “CONFIGURE”
- Under Default Sitemap type “home” and SAVE
- Go to “Classic UI” and select “CONFIGURE”
- Go to
http://192.168.1.125:8080and the items configured should appear
Influxdb and Grafana installation and configuration
Installation
- SSH into the RPI
- Type
sudo openhabian-config - Select from the menu: “Optional Components”
- Select “Grafana” in the sub-menu and install it
- This will install both Influxdb (timeseries database) and Grafana (graphical representations from data store into Influxdb)
Influxdb set-up
- First install the openHAB Influxdb persistence
- Go to
http://192.168.1.125:8080and then “PAPER UI”, “Add-ons”, “PERSISTENCE” and install “Influxdb Persistence” - Verify correct installation in the log (
http://192.168.1.125:9001). If it fails uninstall and reinstall the persistence - Go into RPI using SSH and type
sudo service influxdb start
Let’s create the Influxdb database, users and grant rights
- Type
influx - Type
create database stiebel, “stiebel” is the name of the database to create, you can name it as you want but you will need to provide the exact same same in the later instructions and set-up - Type
show databasesto verify that the database “stiebel” has been created - Now we are going to create the users and assign priviledges
- Type
create user admin with password 'admin' with all privileges - Type
create user openhab with password 'openhab' - Type
show usersto verify that all users got created with the adequate access rights - Type
grant write on stiebel to openhab, this grants write privilege on “stiebel” database to “openhab” user - Type
create retention policy "default" on "stiebel" duration inf replication 1 default - Type
show retention policies on stiebel - The Influxdb database and its users are now created. Type
exitto return to the linux command line
Influxdb settings and connection to openHAB
- Type
sudo nano /etc/influxdb/influxdb.conf - Uncomment the following lines in the http section
[http] enabled = true
bind-address = “:8086”
auth-enabled = false - Restart the InfluxDB service:
sudo systemctl restart influxdb.service - Edit the Influxdb configuration file
sudo nano /etc/openhab2/services/influxdb.cfg - Uncomment and complete the following lines:
url=http://localhost:8086
user=openhab
password=openhab
db=stiebel
retentionPolicy=default - Create the persistence file
sudo nano /etc/openhab2/persistence/influxdb.persist - Create the persistence policy (see examples at the end of this topic):
- openHAB starts now to write data in the stiebel database
- Verify that records are being written to the database and type as follows:
typeinflux
typeuse stiebel
typeshow measurementsselect one of the variable that is likely to have changed recently and to have recorded some transactions e.g. OutTempNum
typeselect * from OutTempNum - At this stage Influxdb is fully set up and openHAB writes into the database, using the variables at the frequency defined in the persistence policy influxdb.persist
Grafana set-up
- Grafana can be accessed at
http://192.168.1.125:3000using the default login user id: “admin”, password: “admin” - Once logged, select “add data source” and perform the following set up:
- In the “Config” section, go to the “Type” line and select “Inlfuxdb” from the drop down list
- In the “Http settings” section, in the Url line insert
http://localhost:8086note that Access should be proxy - In the “Http Auth” section, click on “Basic Auth” to enable it
- In the “Basic Auth Details” section, input User: “openhab” with Password: “openhab”
- In the “InfluxDB Details” section, input Database: “stiebel”, User: “openhab” with Password: “openhab”
- Finally enter “Stiebel” at the top of the page in the line Name
- Click on “Save & Test” at the bottom of the page and it should indicate “Success, Data source is working” as confirmation
- Grafana is now able to read in the Influx database
From the top left menu, select “Dashboards” and then “+ New” and insert charts
The installation is now completed !
Examples
http.cfg
In this example, the IP address 192.168.1.132 represents the ISG device’s address.
ISG10.url=http://192.168.1.132/?s=1,0
ISG10.updateInterval=60000
ISG11.url=http://192.168.1.132/?s=1,1
ISG11.updateInterval=300000
home.items
Please note as I could not find a way to add credentials to the REGEX request, ISG should be “password less”. If you are not be comfortable having your ISG without credentials, then this procedure does not work. In my case, it is fine and I will improve it when I’ll find a solution or someone suggests one. To make ISG “password less”, go to “Profile” then “Safety” and blank out “User name” and “password”
Please also note that I found that REGEX works differently depending on the operating system. The following expressions work on a Raspberri Pi with raspian. It is highly likely that different operating systems will require to adjust the REGEX expressions. I could not find good enough manual to explain why REGEX is expecting different expressions, especially when or not to use the “\”. But i can confirm that the following examples work on my configuration.
Group gAll
Group gMeteo (gAll)
Group gStiebel (gAll)
//Meteo
String OutTempStr "Temperature exterieure [%s°C]" { http="<[ISG10:60000:REGEX(.*<td class=\"key\">OUTSIDE TEMPERATURE</td>.*?<td class=\"value\">(-?[\\d]+,[\\d]).*?</td>.*)]" }
Number OutTempNum "Temperature exterieure [%.1f°C]" <temperature> (gMeteo,gAll)
//Stiebel Sensors
String HeatPumpDepStr "PAC temp depart [%s°C]" { http="<[ISG10:60000:REGEX(.*<td class=\"key\">ACTUAL FLOW TEMPERATURE WP</td>.*?<td class=\"value\">(-?[\\d]+,[\\d]).*?</td>.*)]" }
Number HeatPumpDepNum "PAC temp depart [%.1f°C]" <boiler_viessmann> (gStiebel,gAll)
String HeatPumpRetStr "PAC temp retour [%s°C]" { http="<[ISG10:60000:REGEX(.*<td class=\"key\">ACTUAL RETURN TEMPERATURE</td>.*?<td class=\"value\">(-?[\\d]+,[\\d]).*?</td>.*)]" }
Number HeatPumpRetNum "PAC temp retour [%.1f°C]" <boiler_viessmann> (gStiebel,gAll)
String HeatPumpPressStr "PAC pression [%s bar]" { http="<[ISG10:60000:REGEX(.*<td class=\"key\">PRESSURE HTG CIRC</td>.*?<td class=\"value\">([\\d]+,[\\d]+).bar.*?</td>.*)]" }
Number HeatPumpPressNum "PAC pression [%.2f bar]" <boiler_viessmann> (gStiebel,gAll)
String HeatPumpVolStr "PAC debit [%s l/min]" { http="<[ISG10:60000:REGEX(.*<td class=\"key\">FLOW RATE</td>.*?<td class=\"value\">([\\d]+,[\\d]).*?</td>.*)]" }
Number HeatPumpVolNum "PAC debit [%.1f l/min]" <boiler_viessmann> (gStiebel,gAll)
String HeatPumpDailyStr "PAC energie [%s kWh]" { http="<[ISG11:300000:REGEX(.*<td class=\"key\">COMPRESSOR HEATING DAY</td>.*?<td class=\"value\">([\\d]+,[\\d]+).*?</td>.*)]" }
Number HeatPumpDailyNum "PAC energie [%.3f kWh]" <boiler_viessmann> (gStiebel,gAll)
String HeatPumpOutputHPStr "PAC Output HP [%s pc]" { http="<[ISG10:60000:REGEX(.*<td class=\"key\">OUTPUT HP</td>.*?<td class=\"value\">([\\d]+).*?</td>.*)]" }
Number HeatPumpOutputHPNum "PAC Output HP [%d %%]" <boiler_viessmann> (gStiebel,gAll)
String HeatPumpIntRateStr "PAC Int Pump Rate [%s %%]" { http="<[ISG10:60000:REGEX(.*<td class=\"key round-leftbottom\">INT PUMP RATE</td>.*?<td class=\"value round-rightbottom\">([\\d]+).*?</td>.*)]" }
Number HeatPumpIntRateNum "PAC Int Pump Rate [%d %%]" <boiler_viessmann> (gStiebel,gAll)
home.rules
//Outside Temperature conversion String to Number
rule "OutTemp String to Number conversion"
Item OutTempStr changed
OutTempNum.postUpdate(Float::parseFloat(String::format("%s",OutTempStr.state).replace(',','.')));
///Heat Pump Actual Flow Temperature conversion String to Number
rule "HeatPumpDep String to Number conversion"
Item HeatPumpDepStr changed
HeatPumpDepNum.postUpdate(Float::parseFloat(String::format("%s",HeatPumpDepStr.state).replace(',','.')));
///Heat Pump Actual Return Temperature conversion String to Number
rule "HeatPumpRet String to Number conversion"
Item HeatPumpRetStr changed
HeatPumpRetNum.postUpdate(Float::parseFloat(String::format("%s",HeatPumpRetStr.state).replace(',','.')));
///Heat Pump Pressure HTG CIRC conversion String to Number
rule "HeatPumpPress String to Number conversion"
Item HeatPumpPressStr changed
HeatPumpPressNum.postUpdate(Float::parseFloat(String::format("%s",HeatPumpPressStr.state).replace(',','.')));
///Heat Pump Flow Rate conversion String to Number
rule "HeatPumpVol String to Number conversion"
Item HeatPumpVolStr changed
HeatPumpVolNum.postUpdate(Float::parseFloat(String::format("%s",HeatPumpVolStr.state).replace(',','.')));
//Heat Pump Compressor Heating Day String to Number
rule "HeatPumpDaily String to Number conversion"
Item HeatPumpDailyStr changed
HeatPumpDailyNum.postUpdate(Float::parseFloat(String::format("%s",HeatPumpDailyStr.state).replace(',','.')));
///Heat Pump Output HP conversion String to Number
rule "HeatPumpOutputHP String to Number conversion"
Item HeatPumpOutputHPStr changed
HeatPumpOutputHPNum.postUpdate(Float::parseFloat(String::format("%s",HeatPumpOutputHPStr.state)));
///Heat Pump Int Rate conversion String to Number
rule "HeatPumpIntRate String to Number conversion"
Item HeatPumpIntRateStr changed
HeatPumpIntRateNum.postUpdate(Float::parseFloat(String::format("%s",HeatPumpIntRateStr.state)));
home.sitemap
sitemap home label="House"
Frame label="Meteo"
Text item=OutTempNum
Frame label="Stiebel Eltron"
Text item=HeatPumpDepNum
Text item=HeatPumpRetNum
Text item=HeatPumpPressNum
Text item=HeatPumpVolNum
Text item=HeatPumpDailyNum
Text item=HeatPumpOutputHPNum
Text item=HeatPumpIntRateNum
influxdb.persist
Strategies {
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
everyMinute : "0 * * * * ?"
every5Min : "0 */5 * * * ?"
every5Sec : "*/5 * * * * ?"
// If no strategy is specified for an item entrey below, the default list will be used
default = everyMinute
Items{
OutTempNum : strategy = everyMinute
HeatPumpDepNum, HeatPumpRetNum : strategy = everyMinute
HeatPumpPressNum, HeatPumpVolNum : strategy = everyMinute
HeatPumpOutputHPNum : strategy = everyMinute
HeatPumpIntRateNum : strategy = everyMinute
HeatPumpDailyNum : strategy = every5Min
Revision history
- December 2017: original post
- August 2018
. included improvement formating recommendations from rlkoshak
. included improvement from Thomas Graph to “cache” the Stiebel web pages, reducing the calls to the ISG pages
