Failed: 'getMinuteOfDay'
Dear all,
I need an advice.
I have just moved from OH 2.5 to OH3.
The following rule doesn’t work anymore:
Item Ingresso_IR changed from OFF to ON
if (now.getMinuteOfDay > 1380 || now.getMinuteOfDay < 360 + 45 ) {
Tasmota_02.sendCommand(ON)
createTimer (now.plusMinutes(5), [ | Tasmota_02.sendCommand(OFF) ] )
and the below error messages is in the log:
… failed: ‘getMinuteOfDay’ is not a member of ‘java.time.ZonedDateTime’…
Can you suggest how to fix it?
Check this. Should help DateTime Conversion (openHAB 3.x)
Add this to the top of your rule file
import org.openhab.core.model.script.ScriptServiceUtil
val getMinuteOfDay= [ZonedDateTime x |
    val int minutesOfDay= (x.getHour() * 60) + x.getMinute()
    minutesOfDay
and your item code changes to
            var curTime = new DateTimeType(BlindsClosedBy.state.toString("yyyy-MM-dd'T'HH:mm:00.000Z")).zonedDateTime
            blindsClosedBy = getMinuteOfDay.apply(curTime)
I don’t understand your currTime line. BlindsClosedBy is already a DateTimeType. So why create a new DateTimeType by forcing it to parse the DateTimeType you already have? Why not
var currTime = (BlindsClosedBy.state as DateTimeType).getZonedDateTime
