Failed to submit an event listener task ERROR - IPCam Binding?
I am seeing a strange error in the openhab.log:
2022-09-21 18:21:59.733 [WARN ] [io.netty.channel.AbstractChannel    ] - Force-closing a channel whose registration task was not accepted by an event loop: [id: 0xc5632bd8]
java.util.concurrent.RejectedExecutionException: event executor terminated
	at io.netty.util.concurrent.SingleThreadEventExecutor.reject(SingleThreadEventExecutor.java:923) ~[?:?]
	at io.netty.util.concurrent.SingleThreadEventExecutor.offerTask(SingleThreadEventExecutor.java:350) ~[?:?]
	at io.netty.util.concurrent.SingleThreadEventExecutor.addTask(SingleThreadEventExecutor.java:343) ~[?:?]
	at io.netty.util.concurrent.SingleThreadEventExecutor.execute(SingleThreadEventExecutor.java:825) ~[?:?]
	at io.netty.util.concurrent.SingleThreadEventExecutor.execute(SingleThreadEventExecutor.java:815) ~[?:?]
	at io.netty.channel.AbstractChannel$AbstractUnsafe.register(AbstractChannel.java:483) ~[?:?]
	at io.netty.channel.SingleThreadEventLoop.register(SingleThreadEventLoop.java:87) ~[?:?]
	at io.netty.channel.SingleThreadEventLoop.register(SingleThreadEventLoop.java:81) ~[?:?]
	at io.netty.channel.MultithreadEventLoopGroup.register(MultithreadEventLoopGroup.java:86) ~[?:?]
	at io.netty.bootstrap.AbstractBootstrap.initAndRegister(AbstractBootstrap.java:323) ~[?:?]
	at io.netty.bootstrap.Bootstrap.doResolveAndConnect(Bootstrap.java:155) ~[?:?]
	at io.netty.bootstrap.Bootstrap.connect(Bootstrap.java:139) ~[?:?]
	at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.sendOnvifRequest(OnvifConnection.java:533) ~[?:?]
	at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.connect(OnvifConnection.java:837) ~[?:?]
	at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.pollingCameraConnection(IpCameraHandler.java:1372) ~[?:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
2022-09-21 18:21:59.767 [ERROR] [ent.DefaultPromise.rejectedExecution] - Failed to submit a listener notification task. Event loop shut down?
	at io.netty.util.concurrent.DefaultPromise.safeExecute(DefaultPromise.java:841) ~[?:?]
	at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:499) ~[?:?]
	at io.netty.util.concurrent.DefaultPromise.addListener(DefaultPromise.java:184) ~[?:?]
	at io.netty.channel.DefaultChannelPromise.addListener(DefaultChannelPromise.java:95) ~[?:?]
	at io.netty.channel.DefaultChannelPromise.addListener(DefaultChannelPromise.java:30) ~[?:?]
2022-09-21 18:22:07.576 [WARN ] [netty.util.concurrent.DefaultPromise] - An exception was thrown by org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete()
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@d6a6f6[Not completed, task = java.util.concurrent.Executors$RunnableAdapter@111bd13[Wrapped task = org.openhab.binding.ipcamera.internal.onvif.OnvifConnection$$Lambda$1857/0x94df0628@fd4097]] rejected from java.util.concurrent.ScheduledThreadPoolExecutor@187f3c2[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 1]
	at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2055) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:825) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor.delayedExecute(ScheduledThreadPoolExecutor.java:340) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor.schedule(ScheduledThreadPoolExecutor.java:562) ~[?:?]
	at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.disconnect(OnvifConnection.java:869) ~[?:?]
	at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.offline(IpCameraHandler.java:1727) ~[?:?]
	at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.resetAndRetryConnecting(IpCameraHandler.java:1675) ~[?:?]
	at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.cameraCommunicationError(IpCameraHandler.java:1396) ~[?:?]
	at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete(IpCameraHandler.java:628) ~[?:?]
	at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete(IpCameraHandler.java:1) ~[?:?]
	at io.netty.util.concurrent.DefaultPromise.notifyListener0(DefaultPromise.java:578) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.DefaultPromise.notifyListeners0(DefaultPromise.java:571) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.DefaultPromise.notifyListenersNow(DefaultPromise.java:550) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:491) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.DefaultPromise.setValue0(DefaultPromise.java:616) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.DefaultPromise.setFailure0(DefaultPromise.java:609) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.DefaultPromise.tryFailure(DefaultPromise.java:117) [bundleFile:4.1.72.Final]
	at io.netty.channel.nio.AbstractNioChannel$AbstractNioUnsafe$1.run(AbstractNioChannel.java:262) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.PromiseTask.runTask(PromiseTask.java:98) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.ScheduledFutureTask.run(ScheduledFutureTask.java:170) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:164) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:469) [bundleFile:4.1.72.Final]
	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:503) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:986) [bundleFile:4.1.72.Final]
	at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.72.Final]
	at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.72.Final]
Here is everything about my installation from the UI / About / Technical Details
runtimeInfo:
  version: 3.4.0.M1
  buildString: Milestone Build
locale: en-US
systemInfo:
  configFolder: /etc/openhab
  userdataFolder: /var/lib/openhab
  logFolder: /var/log/openhab
  javaVersion: 11.0.13
  javaVendor: Azul Systems, Inc.
  javaVendorVersion: Zulu11.52+13-CA
  osName: Linux
  osVersion: 5.10.103-v7l+
  osArchitecture: arm
  availableProcessors: 4
  freeMemory: 41496
  totalMemory: 259522560
  startLevel: 100
bindings:
  - amazonechocontrol
  - astro
  - denonmarantz
  - gpstracker
  - icalendar
  - icloud
  - ipcamera
  - irobot
  - logreader
  - mail
  - mqtt
  - myq
  - network
  - ntp
  - openweathermap
  - remoteopenhab
  - roku
  - tuya
  - zwave
clientInfo:
  device:
    ios: false
    android: false
    androidChrome: false
    desktop: true
    iphone: false
    ipod: false
    ipad: false
    edge: false
    ie: false
    firefox: false
    macos: false
    windows: true
    cordova: false
    phonegap: false
    electron: false
    nwjs: false
    webView: false
    webview: false
    standalone: false
    os: windows
    pixelRatio: 1.5
    prefersColorScheme: light
  isSecureContext: false
  locationbarVisible: true
  menubarVisible: true
  navigator:
    cookieEnabled: true
    deviceMemory: N/A
    hardwareConcurrency: 4
    language: en-US
    languages:
      - en-US
    onLine: true
    platform: Win32
  screen:
    width: 1707
    height: 1067
    colorDepth: 24
  support:
    touch: false
    pointerEvents: true
    observer: true
    passiveListener: true
    gestures: false
    intersectionObserver: true
  themeOptions:
    dark: light
    filled: true
    pageTransitionAnimation: default
    bars: filled
    homeNavbar: default
    homeBackground: default
    expandableCardAnimation: default
  userAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML,
    like Gecko) Chrome/105.0.0.0 Safari/537.36
timestamp: 2022-09-22T01:18:07.626Z
I don’t see any clues in the first two errors that point to a culprit. I wondere if the IP Camera Binding error in the 3rd ERROR is the result of the previous error rather than the cause. I will try disabling that binding and see what happens.
I noticed a problem with my system the last couple of days. After the above error sequence, some things stop working, like Astro event triggers. I noticed it when my exterior lights don’t come on in the evening. So I suspect they are related, but have no idea how.
Appreciate any suggestions on how to troubleshoot.
Seems to be related to ipcamera binding.
If you search the error message in the form you will find the similar, where it also says that the binding is trying to do a reconnect every 8 seconds (what’s identical to your log).
A simple reboot has fixed the issues in the other car.
Thanks. I have found that restarting openHAB fixes it, for a while. But is comes back, recently within a day.
Try updating to the newer jar mentioned in the main ipcamera thread. I fixed some bugs which were creating logs like that and the changes are merged and will be in the next milestone, a jar can be downloaded from the GitHub issue.
Thanks for the suggestion. I have downloaded the jar file. I will report back on how it works for me.
After a couple of days with the new .jar file, everything seems to be working as expected and the system is stable.
