Hi Chris,
Following is an extract from the debug log. I tried to upload a TXT file but it would not upload. Does this help??
19:29:43.124 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 21
19:29:43.124 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 08 00 13 11 01 00 25 07 D6
19:29:43.124 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 17: Sending REQUEST Message = 01 08 00 13 11 01 00 25 07 D6
19:29:43.134 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
19:29:43.136 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
19:29:43.136 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
19:29:43.136 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
19:29:43.136 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
19:29:43.136 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: Sent Data successfully placed on stack.
19:29:43.195 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 07 00 00 06 EA
19:29:43.197 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
19:29:43.197 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 07 00 00 06 00 00 E4
19:29:43.197 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 07 00 00 06 00 00 E4
19:29:43.197 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=07 00 00 06
19:29:43.197 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: SendData Request. CallBack ID = 7, Status = Transmission complete and ACK received(0)
19:29:43.197 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: Node is ALIVE. Init stage is PING:{}.
19:29:43.197 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent
19:29:43.197 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveNodeStatusEvent
19:29:43.197 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Setting ONLINE
19:29:43.197 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node Status event during initialisation - Node is ALIVE
19:29:43.197 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - PING: queue length(1), free to send(false)
19:29:43.197 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Initialisation retry timer started 80000
19:29:43.197 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - queued packet. Queue length is 1
19:29:43.198 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 22. Queue={}
19:29:43.198 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 17: Node Status event - Node is ALIVE
19:29:43.198 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Poll, dest=17, callback=7, payload=11 01 0
0
19:29:43.198 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=07 00
00 06
19:29:43.198 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=7, expected=SendData, cancelled=false transaction complete!
19:29:43.198 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
19:29:43.198 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - PING: Transaction complete (SendData:Request) success(true)
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - checking initialisation queue. Queue size 1.
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - message removed from queue. Queue size 0.
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - PING: queue length(0), free to send(true)
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Initialisation retry timer started 80000
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: loop - PING try 5: stageAdvanced(false)
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - advancing to DETAILS
19:29:43.198 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInitializationStateEvent
19:29:43.198 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveInitializationStateEvent
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: loop - DETAILS try 0: stageAdvanced(true)
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: Restored from file - skipping static initialisation
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - advancing to GET_CONFIGURATION
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: loop - GET_CONFIGURATION try 0: stageAdvanced(true)
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: GET_CONFIGURATION - CONFIGURATION class not supported
19:29:43.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - advancing to DYNAMIC_VALUES
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: loop - DYNAMIC_VALUES try 0: stageAdvanced(true)
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - checking SWITCH_BINARY
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - found SWITCH_BINARY
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Found 1 instances of SWITCH_BINARY
19:29:43.199 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 17: Creating new message for application command SWITCH_BINARY_GET
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer - queued packet. Queue length is 1
19:29:43.199 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 23. Queue={}
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - checking VERSION
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - checking SWITCH_MULTILEVEL
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - found SWITCH_MULTILEVEL
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Found 1 instances of SWITCH_MULTILEVEL
19:29:43.199 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 17: Creating new message for command SWITCH_MULTILEVEL_GET
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - checking SECURITY
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - checking BASIC
19:29:43.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node advancer: DYNAMIC_VALUES - queued 2 frames
19:29:43.199 [DEBUG] [curityCommandClassWithInitialization] - NODE 17: updating lastSentMessageTimestamp
19:29:43.199 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 17: Response processed after 73ms/1950ms.
19:29:43.199 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 22
19:29:43.199 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 11 02 25 02 25 4C B8
19:29:43.199 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 17: Sending REQUEST Message = 01 09 00 13 11 02 25 02 25 4C B8
19:29:43.208 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
19:29:43.210 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
19:29:43.210 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
19:29:43.210 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
19:29:43.210 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
19:29:43.210 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: Sent Data successfully placed on stack.
19:29:43.270 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 4C 00 00 07 A0
19:29:43.272 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
19:29:43.272 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 4C 00 00 07 00 00 AE
19:29:43.272 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 4C 00 00 07 00 00 AE
19:29:43.272 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=4C 00 00 07
19:29:43.272 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: SendData Request. CallBack ID = 76, Status = Transmission complete and ACK received(0)
19:29:43.272 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=76, payload=11 02 2
5 02
19:29:43.272 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=4C 00
00 07
19:29:43.272 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=76, expected=ApplicationCommandHandler, cancelled=false MISMATCH
19:29:48.201 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 17: Timeout while sending message. Requeueing - 2 attempts left!
19:29:48.201 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 17: Got an error while sending data. Resending message.
19:29:48.201 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 23. Queue={}
19:29:48.201 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 22
19:29:48.201 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 11 02 25 02 25 4D B9
19:29:48.201 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 17: Sending REQUEST Message = 01 09 00 13 11 02 25 02 25 4D B9
19:29:48.211 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
19:29:48.213 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
19:29:48.213 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
19:29:48.213 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
19:29:48.213 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
19:29:48.213 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: Sent Data successfully placed on stack.
19:29:48.272 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 4D 00 00 07 A1
19:29:48.274 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
19:29:48.274 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 4D 00 00 07 00 00 AF
19:29:48.274 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 4D 00 00 07 00 00 AF
19:29:48.274 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=4D 00 00 07
19:29:48.274 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: SendData Request. CallBack ID = 77, Status = Transmission complete and ACK received(0)
19:29:48.274 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=77, payload=11 02 2
5 02
19:29:48.274 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=4D 00
00 07
19:29:48.275 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=77, expected=ApplicationCommandHandler, cancelled=false MISMATCH
19:29:53.204 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 17: Timeout while sending message. Requeueing - 1 attempts left!
19:29:53.204 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 17: Got an error while sending data. Resending message.
19:29:53.204 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 23. Queue={}
19:29:53.204 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 22
19:29:53.204 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 11 02 25 02 25 4E BA
19:29:53.204 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 17: Sending REQUEST Message = 01 09 00 13 11 02 25 02 25 4E BA
19:29:53.214 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
19:29:53.215 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
19:29:53.215 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
19:29:53.215 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
19:29:53.215 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
19:29:53.216 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: Sent Data successfully placed on stack.
19:29:53.277 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 4E 00 00 06 A3
19:29:53.279 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
19:29:53.279 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 4E 00 00 06 00 00 AD
19:29:53.279 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 4E 00 00 06 00 00 AD
19:29:53.279 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=4E 00 00 06
19:29:53.279 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: SendData Request. CallBack ID = 78, Status = Transmission complete and ACK received(0)
19:29:53.279 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=78, payload=11 02 2
5 02
19:29:53.279 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=4E 00
00 06
19:29:53.279 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=78, expected=ApplicationCommandHandler, cancelled=false MISMATCH
Mike
