@chris
11:15:20.717 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:207 ] - NODE 78: Node advancer - checking initialisation queue. Queue size 1.
11:15:20.718 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:213 ] - NODE 78: Node advancer - message removed from queue. Queue size 0.
11:15:20.719 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:276 ] - NODE 78: Node advancer - ASSOCIATIONS: queue length(0), free to send(true)
11:15:20.720 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ] - NODE 78: Node advancer: loop - ASSOCIATIONS try 1: stageAdvanced(false)
11:15:20.721 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:905 ] - NODE 78: Node advancer - advancing to SET_WAKEUP
11:15:20.721 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ] - NODE 78: Node advancer: loop - SET_WAKEUP try 0: stageAdvanced(true)
11:15:20.722 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:712 ] - NODE 78: Node advancer: SET_WAKEUP - TargetNode is set to controller
11:15:20.723 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:905 ] - NODE 78: Node advancer - advancing to SET_ASSOCIATION
11:15:20.724 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ] - NODE 78: Node advancer: loop - SET_ASSOCIATION try 0: stageAdvanced(true)
11:15:20.936 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:763 ] - NODE 78: Node advancer: SET_ASSOCIATION - ASSOCIATION set for group 3
11:15:20.937 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:905 ] - NODE 78: Node advancer - advancing to GET_CONFIGURATION
11:15:20.938 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ] - NODE 78: Node advancer: loop - GET_CONFIGURATION try 0: stageAdvanced(true)
11:15:21.167 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:905 ] - NODE 78: Node advancer - advancing to STATIC_END
11:15:21.168 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ] - NODE 78: Node advancer: loop - STATIC_END try 0: stageAdvanced(true)
11:15:21.169 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:100 ] - NODE 78: Serialise aborted as static stages not complete
11:15:21.170 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:905 ] - NODE 78: Node advancer - advancing to SESSION_START
11:15:21.171 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ] - NODE 78: Node advancer: loop - SESSION_START try 0: stageAdvanced(true)
11:15:21.171 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:905 ] - NODE 78: Node advancer - advancing to DYNAMIC_VALUES
11:15:21.172 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ] - NODE 78: Node advancer: loop - DYNAMIC_VALUES try 0: stageAdvanced(true)
11:15:21.173 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking CRC_16_ENCAP
11:15:21.174 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking WAKE_UP
11:15:21.175 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking VERSION
11:15:21.175 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION
11:15:21.176 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC
11:15:21.177 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking SENSOR_BINARY
11:15:21.177 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:821 ] - NODE 78: Node advancer: DYNAMIC_VALUES - found SENSOR_BINARY
11:15:21.178 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:825 ] - NODE 78: Found 1 instances of SENSOR_BINARY
11:15:21.179 [DEBUG] [.ZWaveBinarySensorCommandClass:128 ] - NODE 78: Creating new message for application command SENSOR_BINARY_GET
11:15:21.180 [DEBUG] [o.b.z.i.protocol.SerialMessage:111 ] - NODE 78: Creating empty message of class = SendData (0x13), type = Request (0x00)
11:15:21.181 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking BATTERY
11:15:21.182 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:821 ] - NODE 78: Node advancer: DYNAMIC_VALUES - found BATTERY
11:15:21.182 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:825 ] - NODE 78: Found 1 instances of BATTERY
11:15:21.183 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:137 ] - NODE 78: Creating new message for application command BATTERY_GET
11:15:21.184 [DEBUG] [o.b.z.i.protocol.SerialMessage:111 ] - NODE 78: Creating empty message of class = SendData (0x13), type = Request (0x00)
11:15:21.185 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking SENSOR_ALARM
11:15:21.186 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:821 ] - NODE 78: Node advancer: DYNAMIC_VALUES - found SENSOR_ALARM
11:15:21.186 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:825 ] - NODE 78: Found 1 instances of SENSOR_ALARM
11:15:21.189 [DEBUG] [c.ZWaveAlarmSensorCommandClass:284 ] - NODE 78: ====---- Checking alarm SMOKE - init false
11:15:21.189 [WARN ] [c.ZWaveAlarmSensorCommandClass:288 ] - NODE 78: Detected Fibaro FGK - 101 Door / Window sensor, only requesting alarm type Smoke.
11:15:21.190 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking BASIC
11:15:21.191 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION
11:15:21.192 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION
11:15:21.192 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:853 ] - NODE 78: Node advancer: DYNAMIC_VALUES - queued 2 frames
11:15:21.195 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:249 ] - NODE 78: Node advancer - queued packet. Queue length is 2
11:15:21.196 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:15:21.197 [DEBUG] [WaveController$ZWaveSendThread:1349 ] - NODE 78: Response processed for callback id 137 after 641ms/4782ms.
11:15:21.199 [DEBUG] [WaveController$ZWaveSendThread:1277 ] - NODE 78: Sending REQUEST Message = Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 30 02 , callbackid = 138
11:15:21.213 [DEBUG] [b.z.i.p.s.SendDataMessageClass:39 ] - NODE 78: Sent Data successfully placed on stack.
11:15:21.261 [DEBUG] [b.z.i.p.s.SendDataMessageClass:75 ] - NODE 78: SendData Request. CallBack ID = 138, Status = Transmission complete and ACK received(0)
11:15:21.311 [DEBUG] [ApplicationCommandMessageClass:39 ] - NODE 78: Application Command Request (ALIVE:DYNAMIC_VALUES)
11:15:21.312 [DEBUG] [ApplicationCommandMessageClass:138 ] - NODE 78: Incoming command class SENSOR_BINARY (0x30)
11:15:21.313 [DEBUG] [.ZWaveBinarySensorCommandClass:82 ] - NODE 78: Received Sensor Binary Request (v1)
11:15:21.314 [DEBUG] [.ZWaveBinarySensorCommandClass:102 ] - NODE 78: Sensor Binary report, type=Unknown, value=255
11:15:21.315 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveBinarySensorValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveBinarySensorCommandClass$ZWaveBinarySensorValueEvent@16321a6
11:15:21.316 [DEBUG] [.z.internal.ZWaveActiveBinding:460 ] - NODE 78: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 255
11:15:21.318 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:15:21.324 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveTransactionCompletedEvent: ZWaveTransactionCompletedEvent [completedMessage=Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 30 02 , callbackid = 138, state=true]
11:15:21.328 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1050 ] - NODE 78: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true)
11:15:21.329 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:207 ] - NODE 78: Node advancer - checking initialisation queue. Queue size 2.
11:15:21.330 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:213 ] - NODE 78: Node advancer - message removed from queue. Queue size 1.
11:15:21.331 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:276 ] - NODE 78: Node advancer - DYNAMIC_VALUES: queue length(1), free to send(true)
11:15:21.334 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:249 ] - NODE 78: Node advancer - queued packet. Queue length is 1
11:15:21.335 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:15:21.336 [DEBUG] [WaveController$ZWaveSendThread:1349 ] - NODE 78: Response processed for callback id 138 after 136ms/4782ms.
11:15:21.339 [DEBUG] [WaveController$ZWaveSendThread:1277 ] - NODE 78: Sending REQUEST Message = Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 80 02 , callbackid = 139
11:15:21.354 [DEBUG] [b.z.i.p.s.SendDataMessageClass:39 ] - NODE 78: Sent Data successfully placed on stack.
11:15:21.428 [DEBUG] [b.z.i.p.s.SendDataMessageClass:75 ] - NODE 78: SendData Request. CallBack ID = 139, Status = Transmission complete and ACK received(0)
11:15:21.479 [DEBUG] [ApplicationCommandMessageClass:39 ] - NODE 78: Application Command Request (ALIVE:DYNAMIC_VALUES)
11:15:21.480 [DEBUG] [ApplicationCommandMessageClass:138 ] - NODE 78: Incoming command class BATTERY (0x80)
11:15:21.481 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:81 ] - NODE 78: Received Battery Request
11:15:21.482 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:96 ] - NODE 78: Battery report value = 94
11:15:21.483 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveCommandClassValueEvent: org.openhab.binding.zwave.internal.protocol.event.ZWaveCommandClassValueEvent@19ac313
11:15:21.484 [DEBUG] [.z.internal.ZWaveActiveBinding:460 ] - NODE 78: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 94
11:15:21.486 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:15:21.492 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveTransactionCompletedEvent: ZWaveTransactionCompletedEvent [completedMessage=Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 80 02 , callbackid = 139, state=true]
11:15:21.494 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1050 ] - NODE 78: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true)
11:15:21.495 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:207 ] - NODE 78: Node advancer - checking initialisation queue. Queue size 1.
11:15:21.496 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:213 ] - NODE 78: Node advancer - message removed from queue. Queue size 0.
11:15:21.496 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:276 ] - NODE 78: Node advancer - DYNAMIC_VALUES: queue length(0), free to send(true)
11:15:21.497 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ] - NODE 78: Node advancer: loop - DYNAMIC_VALUES try 1: stageAdvanced(false)
11:15:21.498 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking CRC_16_ENCAP
11:15:21.499 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking WAKE_UP
11:15:21.500 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking VERSION
11:15:21.500 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION
11:15:21.501 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC
11:15:21.502 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking SENSOR_BINARY
11:15:21.503 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:821 ] - NODE 78: Node advancer: DYNAMIC_VALUES - found SENSOR_BINARY
11:15:21.503 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:825 ] - NODE 78: Found 1 instances of SENSOR_BINARY
11:15:21.504 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking BATTERY
11:15:21.505 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:821 ] - NODE 78: Node advancer: DYNAMIC_VALUES - found BATTERY
11:15:21.506 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:825 ] - NODE 78: Found 1 instances of BATTERY
11:15:21.506 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking SENSOR_ALARM
11:15:21.507 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:821 ] - NODE 78: Node advancer: DYNAMIC_VALUES - found SENSOR_ALARM
11:15:21.508 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:825 ] - NODE 78: Found 1 instances of SENSOR_ALARM
11:15:21.509 [DEBUG] [c.ZWaveAlarmSensorCommandClass:284 ] - NODE 78: ====---- Checking alarm SMOKE - init false
11:15:21.510 [WARN ] [c.ZWaveAlarmSensorCommandClass:288 ] - NODE 78: Detected Fibaro FGK - 101 Door / Window sensor, only requesting alarm type Smoke.
11:15:21.511 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking BASIC
11:15:21.512 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION
11:15:21.512 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:818 ] - NODE 78: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION
11:15:21.513 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:853 ] - NODE 78: Node advancer: DYNAMIC_VALUES - queued 0 frames
11:15:21.514 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:905 ] - NODE 78: Node advancer - advancing to DONE
11:15:21.515 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ] - NODE 78: Node advancer: loop - DONE try 0: stageAdvanced(true)
11:15:21.516 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:107 ] - NODE 78: Serializing to file etc/zwave/node78.xml
11:15:21.535 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:864 ] - NODE 78: Node advancer: Initialisation complete!
11:15:21.536 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveInitializationCompletedEvent: org.openhab.binding.zwave.internal.protocol.event.ZWaveInitializationCompletedEvent@66a373
11:15:21.537 [DEBUG] [.z.internal.ZWaveActiveBinding:435 ] - NODE 78: ZWaveIncomingEvent Called, Network Event, Init Done. Setting device ready.
11:15:21.547 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:15:21.548 [DEBUG] [WaveController$ZWaveSendThread:1349 ] - NODE 78: Response processed for callback id 139 after 208ms/4782ms.
11:15:22.494 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 78: No more messages, go back to sleep
11:15:22.495 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 78: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
11:15:22.497 [DEBUG] [o.b.z.i.protocol.SerialMessage:111 ] - NODE 78: Creating empty message of class = SendData (0x13), type = Request (0x00)
11:15:22.502 [DEBUG] [WaveController$ZWaveSendThread:1277 ] - NODE 78: Sending REQUEST Message = Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 84 08 , callbackid = 140
11:15:23.545 [DEBUG] [b.z.i.p.s.SendDataMessageClass:39 ] - NODE 78: Sent Data successfully placed on stack.
11:15:23.590 [DEBUG] [b.z.i.p.s.SendDataMessageClass:75 ] - NODE 78: SendData Request. CallBack ID = 140, Status = Transmission complete and ACK received(0)
11:15:23.597 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveTransactionCompletedEvent: ZWaveTransactionCompletedEvent [completedMessage=Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 84 08 , callbackid = 140, state=true]
11:15:23.600 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 78: Went to sleep
11:15:23.602 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 78: Is sleeping
11:15:23.603 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:15:23.605 [DEBUG] [WaveController$ZWaveSendThread:1349 ] - NODE 78: Response processed for callback id 140 after 1103ms/4782ms.
11:15:23.608 [DEBUG] [.b.z.i.c.ZWaveBatteryConverter:60 ] - NODE 78: Generating poll message for BATTERY endpoint 0
11:15:23.609 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:137 ] - NODE 78: Creating new message for application command BATTERY_GET
11:15:23.611 [DEBUG] [o.b.z.i.protocol.SerialMessage:111 ] - NODE 78: Creating empty message of class = SendData (0x13), type = Request (0x00)
11:15:23.614 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:241 ] - NODE 78: Putting message SendData in wakeup queue.
11:15:31.793 [DEBUG] [ApplicationCommandMessageClass:117 ] - NODE 78: Transaction not completed: node address inconsistent. lastSent=255, incoming={}
11:17:17.596 [DEBUG] [ApplicationCommandMessageClass:39 ] - NODE 78: Application Command Request (ALIVE:DONE)
11:17:17.597 [DEBUG] [ApplicationCommandMessageClass:138 ] - NODE 78: Incoming command class WAKE_UP (0x84)
11:17:17.598 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 78: Received Wake Up Request
11:17:17.598 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 78: Received WAKE_UP_NOTIFICATION
11:17:17.599 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 78: Is awake with 1 messages in the wake-up queue.
11:17:17.600 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveWakeUpEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveWakeUpCommandClass$ZWaveWakeUpEvent@1099758
11:17:17.602 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:17:17.606 [DEBUG] [WaveController$ZWaveSendThread:1277 ] - NODE 78: Sending REQUEST Message = Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 80 02 , callbackid = 150
11:17:17.621 [DEBUG] [b.z.i.p.s.SendDataMessageClass:39 ] - NODE 78: Sent Data successfully placed on stack.
11:17:17.668 [DEBUG] [b.z.i.p.s.SendDataMessageClass:75 ] - NODE 78: SendData Request. CallBack ID = 150, Status = Transmission complete and ACK received(0)
11:17:17.718 [DEBUG] [ApplicationCommandMessageClass:39 ] - NODE 78: Application Command Request (ALIVE:DONE)
11:17:17.719 [DEBUG] [ApplicationCommandMessageClass:138 ] - NODE 78: Incoming command class BATTERY (0x80)
11:17:17.719 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:81 ] - NODE 78: Received Battery Request
11:17:17.720 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:96 ] - NODE 78: Battery report value = 94
11:17:17.721 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveCommandClassValueEvent: org.openhab.binding.zwave.internal.protocol.event.ZWaveCommandClassValueEvent@16a46e5
11:17:17.722 [DEBUG] [.z.internal.ZWaveActiveBinding:460 ] - NODE 78: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 94
11:17:17.724 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:17:17.727 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveTransactionCompletedEvent: ZWaveTransactionCompletedEvent [completedMessage=Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 80 02 , callbackid = 150, state=true]
11:17:17.731 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:17:17.732 [DEBUG] [WaveController$ZWaveSendThread:1349 ] - NODE 78: Response processed for callback id 150 after 124ms/4782ms.
11:17:18.189 [DEBUG] [ApplicationCommandMessageClass:117 ] - NODE 78: Transaction not completed: node address inconsistent. lastSent=255, incoming={}
11:17:18.731 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 78: No more messages, go back to sleep
11:17:18.732 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 78: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
11:17:18.733 [DEBUG] [o.b.z.i.protocol.SerialMessage:111 ] - NODE 78: Creating empty message of class = SendData (0x13), type = Request (0x00)
11:17:18.739 [DEBUG] [WaveController$ZWaveSendThread:1277 ] - NODE 78: Sending REQUEST Message = Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 84 08 , callbackid = 151
11:17:18.753 [DEBUG] [b.z.i.p.s.SendDataMessageClass:39 ] - NODE 78: Sent Data successfully placed on stack.
11:17:18.800 [DEBUG] [b.z.i.p.s.SendDataMessageClass:75 ] - NODE 78: SendData Request. CallBack ID = 151, Status = Transmission complete and ACK received(0)
11:17:18.804 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveTransactionCompletedEvent: ZWaveTransactionCompletedEvent [completedMessage=Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 84 08 , callbackid = 151, state=true]
11:17:18.806 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 78: Went to sleep
11:17:18.806 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 78: Is sleeping
11:17:18.807 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:17:18.808 [DEBUG] [WaveController$ZWaveSendThread:1349 ] - NODE 78: Response processed for callback id 151 after 68ms/4782ms.
11:17:31.101 [DEBUG] [ApplicationCommandMessageClass:117 ] - NODE 78: Transaction not completed: node address inconsistent. lastSent=255, incoming={}
11:18:18.234 [DEBUG] [ApplicationCommandMessageClass:117 ] - NODE 78: Transaction not completed: node address inconsistent. lastSent=255, incoming={}
11:19:16.521 [DEBUG] [ApplicationCommandMessageClass:39 ] - NODE 78: Application Command Request (ALIVE:DONE)
11:19:16.522 [DEBUG] [ApplicationCommandMessageClass:138 ] - NODE 78: Incoming command class WAKE_UP (0x84)
11:19:16.523 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 78: Received Wake Up Request
11:19:16.523 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 78: Received WAKE_UP_NOTIFICATION
11:19:16.524 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 78: Is awake with 0 messages in the wake-up queue.
11:19:16.525 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveWakeUpEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveWakeUpCommandClass$ZWaveWakeUpEvent@d98b7c
11:19:16.527 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:19:17.528 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 78: No more messages, go back to sleep
11:19:17.528 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 78: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
11:19:17.529 [DEBUG] [o.b.z.i.protocol.SerialMessage:111 ] - NODE 78: Creating empty message of class = SendData (0x13), type = Request (0x00)
11:19:17.533 [DEBUG] [WaveController$ZWaveSendThread:1277 ] - NODE 78: Sending REQUEST Message = Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 84 08 , callbackid = 153
11:19:17.547 [DEBUG] [b.z.i.p.s.SendDataMessageClass:39 ] - NODE 78: Sent Data successfully placed on stack.
11:19:17.594 [DEBUG] [b.z.i.p.s.SendDataMessageClass:75 ] - NODE 78: SendData Request. CallBack ID = 153, Status = Transmission complete and ACK received(0)
11:19:17.598 [DEBUG] [b.z.i.protocol.ZWaveController:616 ] - NODE 78: Notifying event listeners: ZWaveTransactionCompletedEvent: ZWaveTransactionCompletedEvent [completedMessage=Message: class = SendData (0x13), type = Request (0x00), payload = 4E 02 84 08 , callbackid = 153, state=true]
11:19:17.601 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 78: Went to sleep
11:19:17.602 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 78: Is sleeping
11:19:17.603 [DEBUG] [b.z.i.protocol.ZWaveController:627 ] - NODE 78: Processing event ourselves
11:19:17.604 [DEBUG] [WaveController$ZWaveSendThread:1349 ] - NODE 78: Response processed for callback id 153 after 70ms/4782ms.
11:19:17.894 [DEBUG] [ApplicationCommandMessageClass:117 ] - NODE 78: Transaction not completed: node address inconsistent. lastSent=255, incoming={}
11:19:30.814 [DEBUG] [ApplicationCommandMessageClass:117 ] - NODE 78: Transaction not completed: node address inconsistent. lastSent=255, incoming={}
