I might have gone to the credit limit, so I will have to wait to try again… ![]()
Read through that thread and the other one ([CUL transport] Fix for issue with CUL transport race condition).
In your case (OH-beginner) I would suggest to continue in here, using the raw mode correctly should produce the same output as you have done in FHEM.
I do not know what is the on and off command for v3.
You have read the (german) page already!
Remember:
is (Sende Intertechno Kommando) 01010010101011101000000110 (Gerätecode Fernbedienung) 01 (Kommando ON) 0011 (Tastenpaar 4)
Im Gegensatz zum alten Protokoll (Intertechno V1) wird das Binärwort hier nicht mit 0 und F sondern 0 und 1 gesendet.
Die culfw unterscheidet anhand der Kommandolänge ob es sich um einen alten (12 Zeichen) oder neuen (32 Zeichen) Intertechno Befehl handelt. Genauso unterscheidet das IT-Modul in FHEM die beiden Formate:
define <name> IT <10-bit-housecode> <off-code> <on-code> [<dimup-code>] [<dimdown-code>]
und
define <name> IT <26 bit Address> <1 bit group bit> <4 bit unit>
und setzt das Reading protocol auf V3.
As you can see, now mention of off-code or on-code in the 26bit case…
My GUESS for your item definition:
Switch Funkstecker1 “Funkstecker IT Test1” (Test1) { culintertechno=“type=raw;address=01011011001000001011100010;commandOn=010010;commandOff=000010” }
I ommited the address part that started with a space.
so 01 is command ON
Do I have to wait 60min to get the ability to send commands again?
As now in debug it shows the request for credit report, but never shows a reply.
That doesn’t sound normal.
Is this the same when using an old plug?
Is the Stick showing abnormal blinking? I have read of cases when the Stick got stuck which needed a completed system restart.
Yes. I basically flicked too many times (I made 20 or so items to avoid trial and error line by line) and now nothing works.
But basically I think there is a restriction of how many signals you can send per hour.
I will try resetting the stick as you said.
I don’t it is per hour, the credit report you see in the log is about that restriction. IMHO it is per minute, but nevertheless your stick is probably stuck.
Edit
Reading the misc section shows that you were correct. What did the log show for credits?
I did as said and it works.
Could you help me make my old steckdose work well please?
So…
Below is actually a “hack” i had from FHEM. Ironically it is how I helped other make this super old thing work on FHEM:
Switch Funkstecker8 “Funkstecker IT Test8”{ culintertechno=“type=raw;address=0F0F0FFFFF;commandOn=FF;commandOff=FO”}
Switch Funkstecker9 “Funkstecker IT Test9”{ culintertechno=“type=raw;address=1F0F0FFFFF;commandOn=FF;commandOff=FO”}
So, in the above case, Funkstecker8 - only turns SwitchA On and Funkstecker9 - only turns SwitchB Off.
It doesn’t matter if it is sending commandOn or CommandOff - Funk8 - always to turn On, Funk9 - always to turn Off.
Using this “RAW” mode, can I make it more logical?
Thanks.
Those settings look odd, the OFF commands are using FO instead of F0(In words F zero).
The address of the second one starts with a 1 although all other non zero are set with F.
What kind of devices are these?
Confirm what is happening in all cases.
Funk8 ON turns switch A ON
Funk8 OFF
Funk9 ON turns switch B OFF
Funk9 OFF
To make it “logical” I’d use only the ON and OFF commands with the address empty.
It is called eHome:
Sorry above was a typo - F0 not FO (but actually it worked even with FO)…
The point is, that those last 2 characters don’t serve a purpose. They are just packing - I put 00 as both ON and OFF and it still works same way.
Funk8 ON / OFF = switch A ON
Funk9 ON / OFF = switch A OFF
So the on/off is in the start rather than the end
Both FHEM and OpenHAB do not seem to allow me to have a blank address…
Ok., never tried that, are errors logged? But the newer version I showed above uses a syntax for the he raw mode that does exactly that ( using only ON or OFF,no address).
will give it a try.
So far the v3 IT did not work, firing up several errors… ![]()
Switch Funkstecker8 “Funkstecker IT Test8”{ culintertechno=“type=raw;address=;commandOn=0F0F0FFFFF00;commandOff=1F0F0FFFFF00”}
I cannot see it send anything on debug… :confused
Sorry, too many links, which SNAPSHOT should I install?
[Intertechno] Support for Intertechno V3 protocol
or
(V3 not working yet - I meant that a hard reset resolved my credit issue).
Please be a bit more precise in your postings, after reading “I did as said and it works.” I assumed you got the V3 working.
So, let me summarise:
V3 - never worked. Since adding the 2 .jar from Mik, I get:
20:10:08.730 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘culintertechno’ of item ‘Funkstecker1’ could not be parsed correctly.
java.lang.NullPointerException
at org.openhab.binding.intertechno.internal.CULIntertechnoGenericBindingProvider.processBindingConfiguration(CULIntertechnoGenericBindingProvider.java:70)[190:org.openhab.binding.intertechno:1.10.0]
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:48)[185:org.openhab.core.compat1x:2.1.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:325)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:297)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:182)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:367)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:286)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:136)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:234)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:297)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.core.service.WatchQueueReader.run(WatchQueueReader.java:206)[98:org.eclipse.smarthome.core:0.9.0.b5]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_152]
20:10:08.737 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘culintertechno’ of item ‘Funkstecker2’ could not be parsed correctly.
20:10:08.742 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘culintertechno’ of item ‘Funkstecker3’ could not be parsed correctly.
20:10:08.751 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘culintertechno’ of item ‘Funkstecker8’ could not be parsed correctly.
java.lang.ArrayIndexOutOfBoundsException: 2
at org.openhab.binding.intertechno.internal.parser.RawParser.parseAddress(RawParser.java:30)[190:org.openhab.binding.intertechno:1.10.0]
20:10:08.758 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘culintertechno’ of item ‘Funkstecker8’ could not be parsed correctly.
Regarding eHome stuff,
so trying to use
Switch Funkstecker8 “Funkstecker IT Test8”{ culintertechno=“type=raw;commandOn=0F0F0FFFFFFF;commandOff=1F0F0FFFFFFF”}
Did not yield any result, the console does not show any transmission, but I do not know if this is because we are using “addons” do I need to active debug for them?
