16:28:28.420 [DEBUG] [penhab.io.transport.cul.CULActivator] - CUL transport has been started.
16:28:28.495 [DEBUG] [io.transport.cul.internal.CULManager] - Registering class org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl for device type serial
16:28:28.515 [DEBUG] [io.transport.cul.internal.CULManager] - Registering class org.openhab.io.transport.cul.internal.network.CULNetworkHandlerImpl for device type network
16:28:28.525 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent STARTED - org.openhab.io.transport.cul
16:28:28.593 [WARN ] [io.transport.cul.CULLifecycleManager] - CUL config is NULL, doing nothing
16:28:28.606 [INFO ] [ternal.serial.CULSerialConfigFactory] - Update config, baudrate = 38400
16:28:28.623 [INFO ] [ternal.serial.CULSerialConfigFactory] - Update config, parity = NONE (0)
16:28:28.629 [DEBUG] [io.transport.cul.internal.CULManager] - Trying to open device serial:/dev/ttyUSB0 in mode MAX
16:28:28.633 [DEBUG] [io.transport.cul.internal.CULManager] - Searching class for device type serial
16:28:28.679 [DEBUG] [internal.serial.CULSerialHandlerImpl] - Opening serial CUL connection for /dev/ttyUSB0
16:28:28.755 [DEBUG] [org.openhab.binding.intertechno ] - BundleEvent STARTING - org.openhab.binding.intertechno
16:28:28.764 [DEBUG] [hno.internal.CULIntertechnoActivator] - CULIntertechno binding has been started.
16:28:28.807 [DEBUG] [org.openhab.binding.intertechno ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.intertechno.CULIntertechnoBindingProvider}={component.name=org.openhab.binding.intertechno.genericbindingprovider, component.id=190, service.id=309, service.bundleid=190, service.scope=bundle} - org.openhab.binding.intertechno
16:28:28.886 [DEBUG] [org.openhab.binding.intertechno ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/command/*, service.pid=org.openhab.culintertechno, component.name=org.openhab.binding.intertechno.binding, component.id=189, service.id=311, service.bundleid=190, service.scope=bundle} - org.openhab.binding.intertechno
16:28:28.944 [DEBUG] [org.openhab.binding.intertechno ] - BundleEvent STARTED - org.openhab.binding.intertechno
16:28:28.990 [DEBUG] [internal.serial.CULSerialHandlerImpl] - Adding serial port event listener
16:28:29.038 [DEBUG] [port.cul.internal.AbstractCULHandler] - Requesting credit report
16:28:29.053 [DEBUG] [port.cul.internal.AbstractCULHandler] - Requesting credit report
16:28:29.158 [DEBUG] [io.transport.cul.internal.CULManager] - Trying to open device serial:/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 in mode SLOW_RF
16:28:29.164 [DEBUG] [io.transport.cul.internal.CULManager] - Searching class for device type serial
16:28:29.168 [DEBUG] [internal.serial.CULSerialHandlerImpl] - Opening serial CUL connection for /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
16:28:29.227 [WARN ] [io.transport.cul.CULLifecycleManager] - Can't open CUL
I will check the settings again.
/dev/ttyUSB0 or ttyUSB1 is dangerous reference since that is just up to boot luck.
I guess I configured Max!CUL binding to use the USB0 - I will thus use the by-id name instead.
By the way - are you using an 868 Stick for controlling Intertechno?
(I think that drastically shortens the life of the stick due to a temporary re-write).
16:40:17.077 [INFO ] [ternal.serial.CULSerialConfigFactory] - Update config, baudrate = 38400
16:40:17.084 [INFO ] [ternal.serial.CULSerialConfigFactory] - Update config, parity = NONE (0)
16:40:17.086 [DEBUG] [io.transport.cul.internal.CULManager] - Trying to open device serial:/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 in mode SLOW_RF
16:40:17.088 [DEBUG] [io.transport.cul.internal.CULManager] - Searching class for device type serial
16:40:17.091 [DEBUG] [internal.serial.CULSerialHandlerImpl] - Opening serial CUL connection for /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
16:40:17.120 [WARN ] [io.transport.cul.CULLifecycleManager] - Can't open CUL
org.openhab.io.transport.cul.CULDeviceException: gnu.io.NoSuchPortException
at org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl.openHardware(CULSerialHandlerImpl.java:110)[186:org.openhab.io.transport.cul:1.10.0]
at org.openhab.io.transport.cul.internal.AbstractCULHandler.open(AbstractCULHandler.java:133)[186:org.openhab.io.transport.cul:1.10.0]
at org.openhab.io.transport.cul.internal.CULManager.createNewHandler(CULManager.java:149)[186:org.openhab.io.transport.cul:1.10.0]
at org.openhab.io.transport.cul.internal.CULManager.getOpenCULHandler(CULManager.java:84)[186:org.openhab.io.transport.cul:1.10.0]
at org.openhab.io.transport.cul.CULLifecycleManager.open(CULLifecycleManager.java:86)[186:org.openhab.io.transport.cul:1.10.0]
at org.openhab.io.transport.cul.CULLifecycleManager.config(CULLifecycleManager.java:74)[186:org.openhab.io.transport.cul:1.10.0]
at org.openhab.binding.intertechno.internal.CULIntertechnoBinding.updated(CULIntertechnoBinding.java:147)[190:org.openhab.binding.intertechno:1.10.0]
I think the remaining issue could be that openhab cannot access /dev/serial
How can I add the /dev/serial to the same group that loads openhab?
The log you posted looks good at the start, however the old ācanāt open CULā is back. That went away by a change introduced to OpenHABian. When I had that I needed to start OH as root in order to use the CUL.
Are you using openHABian?
Or are you using already the second CUL on your system?
..and yes,I 'm using my 866 stick for intertechno .
17:24:47.825 [DEBUG] [port.cul.internal.AbstractCULHandler] - Requesting credit report
17:24:47.867 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: ? (`is01011011001000001011100010 0 0000010010 is unknown) Use one of A B C e F f G i K L l M N R T t U V W X x
17:24:47.874 [DEBUG] [port.cul.internal.AbstractCULHandler] - Requesting credit report
17:24:47.904 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: 00 534
17:24:47.911 [DEBUG] [port.cul.internal.AbstractCULHandler] - credit10ms = 534
17:24:47.936 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: 00 534
17:24:47.939 [DEBUG] [port.cul.internal.AbstractCULHandler] - credit10ms = 534
17:24:51.673 [INFO ] [smarthome.event.ItemCommandEvent ] - Item āFunkstecker1ā received command OFF
17:24:51.686 [INFO ] [marthome.event.ItemStateChangedEvent] - Funkstecker1 changed from ON to OFF
17:24:51.695 [DEBUG] [port.cul.internal.AbstractCULHandler] - Requesting credit report
17:24:52.571 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: is01011011001000001011100010F0F0000000010
17:24:52.576 [DEBUG] [port.cul.internal.AbstractCULHandler] - Requesting credit report
17:24:52.600 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: 00 538
17:24:52.602 [DEBUG] [port.cul.internal.AbstractCULHandler] - credit10ms = 538
17:24:52.625 [DEBUG] [port.cul.internal.AbstractCULHandler] - Received raw message from CUL: 00 539
17:24:52.627 [DEBUG] [port.cul.internal.AbstractCULHandler] - credit10ms = 539
I guessed it would work with your older pluggs (mine is >25 years old!).
Looking at the log you see what the binding sends to the stick:
The is for interechno-mode send
up to the first F it is your address, however each blank is replaced by an F, and at the end the OFF command is added.
If you would know the exact command needed to be sent directly (for example by screen) we could make that up for the binding.
