Hi
I run
- Openhab 2
- Z-wave binding (Fibaro Dimmer 2)
- Kodi Binding
I want to make a rule that slowly dims my light’s
The rule below only works with on and off, not with %, ( i.e. 75%, 50% and 25%)
“E1Lachter1_Switch” is my dimmer channel
E1Lachter1_Switch.sendCommand(OFF) is working
E1Lachter1_Switch.sendCommand(50) not working
sendCommand(E1Lachter1_Switch, 50) not working
sendCommand(E1Lachter1_Switch, “50”) not working
rule "Adjust living room lighting when Kodi starts/stops"
Item Kodi_State changed
var String stateKodi = Kodi_State.state.toString()
switch (stateKodi.lowerCase) {
case "play" : {
case "pause" : {
//sendCommand(E1Lachter1_Switch, 50)
E1Lachter1_Switch.sendCommand(ON)
case "stop" : {
//sendCommand(E1Lachter1_Switch, 100)
