The Fibaro FGD212 Dimmer has 2 dimmer channels, but i am unsure why and at what effect. Anyone got the same thing?
Typically with these devices you can use the second channel as a controller to control something else - either directly by associating it with another device, or indirectly by linking it to an item in OH and triggering rules etc.
Is this possible with both Channels ? or must 1 channel wired to a Device?
If not, than I can take this Device as an Controll Unit for Bulbs like HUE …
You can do it with both channels if you don’t want to wire up the actual dimmer. Effectively you have a 2 channel wall controller.
Thanks … thats cool but not cheap ![]()
It’s free
. If you want a dimmer, you get another switch that you can use as a controller for free…
