joheremans
(Jo Heremans)
February 17, 2017, 12:13pm
1
I have a Fibaro FGS223. Parameter 28 & 29 is used to set which actions result in sending scenes.
example 2 = key pressed 2 times, 4 = key pressed 3 times.
This parameter should be a multisilect list, 6 = key pressed 2 times & key pressed 3 times.
I use openhabian2 and with habmin or paperUI this parameter is a single list item.
For openhabian I did found the wrong entry in this file : openhab1-addons/bundles/binding/org.openhab.binding.zwave/database/fibaro/fgs223.xml at main · openhab/openhab1-addons · GitHub
But I don’t find where to correct this parameter for openhabian2.
Regards,
Jo
sihui
(SiHui)
February 18, 2017, 7:44am
2
Are you using an older zwave binding?
This problem was solved a couple of weeks ago:
Look at
Hello @chris ,
I too have a problem with the FGS223. I installed it in my livin room, but want to activate the scenes, so I can trigger alternate scenes from my mail light pushbutton.
But I think the options from the scene activation are wrong:
You are able to activate the scene for every one option, but not the combinations:
[image]
Like I want to set it to 7, (1, 2 and 3 combined).
Thanks for your input!
Best regards,
Wouter
and the answer right next to it.
joheremans
(Jo Heremans)
February 18, 2017, 6:23pm
3
Thanks, my binding was the latest snapshot. It was not clear that I could enter any value and I didn’t have to select a value from the drop downlist.
