Set the log level for the zwave binding to DEBUG. File can be downloaded here: https://we.tl/t-JSghHxBKKK
If you search for “color mode” i think you get to the right point. Node 41.
Unluckily there is no XML file for Node 41.
ll /var/lib/openhab2/zwave/ | grep 41 | wc -l → 0
But i have one for Node 40 (which was the same device but i reseted the device and included again which is now 41) https://we.tl/t-EY4sDqSinR
That means the device has not been fully discovered and should not be expected to work properly.You can try deleting & re-adding the Thing to get it rediscovered, while keeping the dimmer awake.
Never seen that error, sorry.
For the older device we had to set a config option:
I did this for this device now, but I am not sure if this helps.
Please upgrade your binding once the changes got merged.
If it is still not working please provide a DEBUG log and ping Chris for assistance (please be patient as he is very busy at the moment)
Please also do the basic stuff before: clear the cache, delete the Thing and re-add it.
Hi there,
first of all thank you for your amazing work here. Did anyone a successful test with this device up to now? Tried to understand your implementation of this device for future experiments ;).
I tested yesterday the current snapshot of openhab to check if the device is working. I basically come as far as @spider1354.
But i am not sure if the latest version of the zwave binding with @sihui mods was included. Unfortunetly i switched back to stable version for productive operation already.
Hi all,
tried the latest current Binding from today 4.11:
openhab> bundle:list|grep -i zwave
193 │ Active │ 80 │ 2.5.0.201911040345 │ openHAB Add-ons :: Bundles :: ZWave Binding
But do get still errors when including the RGBW Controller 2:
2019-11-04 18:58:48.319 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.initialize()’ on ‘org.openhab.binding.zwave.handler.ZWaveThingHandler@186d7b’: For input string: “1colorMode=DIFF_WHITE”
java.lang.NumberFormatException: For input string: “1colorMode=DIFF_WHITE”
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
at java.lang.Integer.parseInt(Integer.java:580) ~[?:?]
at java.lang.Integer.parseInt(Integer.java:615) ~[?:?]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.initialiseNode(ZWaveThingHandler.java:263) ~[?:?]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.bridgeStatusChanged(ZWaveThingHandler.java:537) ~[?:?]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.initialize(ZWaveThingHandler.java:163) ~[?:?]
at sun.reflect.GeneratedMethodAccessor76.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
2019-11-04 18:58:48.344 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing ‘zwave:device:22089965:node44’: For input string: “1colorMode=DIFF_WHITE”
The binding was last updated 7 days ago.
The developer is on a much needed vacation so I would not expect an update for another 2 weeks or so. He does not currently have VPN access to update when away.
I’ve updated to OpenHab 2.5 today and I still get this error. The thing with all its channels is present and I can add items, but they are all non-functional. The thing itself is stuck at:
Status: UNINITIALIZED - HANDLER_INITIALIZING_ERROR For input string: “1colorMode=DIFF_WHITE”
I’m having unknown device issue again. running 2.5 snapshot currently, but only switched to make sure stable wasn’t the issue. From Habmin it shows the following attributes:
Manufacturer: 010f"Fibargroup"
Type/ID: 0902:2000
Firmware: 5.0
and logs show
[WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 20: Device discovery could not resolve to a thingType! 010F:0902:2000::5.0
Sorry if this has been covered, but i’ve not come up with a solution. Thanks in advance
I would suggest to update your device’s firmware first.
My one works perfect. I had bought a Fibaro HC Light, added as secondary Zwave controller since then I can update all Fibaro Device firmware.
