Fibaro Roller Shutter FGRM-222 with Venetian Blinds - Lamellas Position
@chris
Any progress on this issue?
hey that wont work for me.
I send
sendCommand(EG_Raffstore_TerrasseR_shutter,99)
sendCommand(EG_Raffstore_TerrasseR_lamelle,60)
also tried to first set lamella etc but it always result it is going to down and stays completely closed and not tilting the lamella to 60
If I only send the command for lamella as single command it does tilt to 60
whats your parameter 13 set to?
best
“only in case of the main controller operation”
@mstormi
same for me
and you can fire two sendcommands in the same rule and it will tilt the lamella after moving to final position?
edit
just to be sure I have no general type issue
I use blind control defined as rollershutter and lamella position as dimmer …?
param 10: venetian + positioning and param 3: i tried both both zwave and fibar (no difference)
edit2:
setting shutter to 100 and 99 resulted in lamellas to be fully closed
shutter(90) … works
works not
works
sendCommand(EG_Raffstore_TerrasseR_shutter,90)
no clue why
Have you tried to recalibrate ?
yes freshly calibrated.
something like 95 works
100,99 wont work. no big deal. but maybe this helps somebody finding this in the future.
