Hmm, there actually are parameters #1 and #2 that according to the Fibaro manual if set should allow for local and RF protection, but I noticed they’re missing in my devices in habmin.
Checking the database entry for firmware up to 22.22, parameters #1 and #2 are in.
But the entry for firmware 24.24 and newer is actually lacking those.
I think that’s by mistake, probably is was overlooked because of the way the manual is written as it lists those first two parameters in a different section than all of the others.
I added those parameters to the database.
As with any DB update, this added functionality should become available in the next snapshot.
PS @chris I accidentially added another option to parameter #2 of the old device (#116 in DB) that I now fail to delete, could you please fix that.
I saw last night that a new version of Zwave Snapshot with fixed protection mode was turned on.
Now my question before I do something wrong.
Can I only replace the snapshot version of the Zwave Binding from build # 428?
I have already found a manual that I understand here in the community.
I’m not sure what “protection mode” means? If this refers to the protection command class, then this has not been added yet. The changes yesterday were mainly to support issues relating to configuration changes.
This was my problem with the Fibaro Rollershutter.
In the configuration for this device there was no possibility to activate the protection mode of the local buttons.
If that understood correctly, this should now be possible.
No - as said above, the changes yesterday were mainly to support issues relating to configuration changes, and the protection command class has not been added.
I don’t think you’re talking about the same thing. @Didschu wants to disable the local switch. You can do so by setting zwave parameter #1 to “2”.
I don’t think that’s related to the PROTECTION class. Just unfortunately for the time being, the device database definition does not know about that parameter 1. It now does as I have extended the database entry so he needs to install a binding version to include that database update.
No - if this is about configuring a parameter, then it’s not related. However, I also have not done a database update for a few days (I plan to do one tonight) so the update yesterday will not include any recent changes there.
I know that I’m really annoying, but I just do not want to go wrong. How do I recognize that a new snapshot version is available and the setting important to me has been added?
