rlkoshak
(Rich Koshak)
August 29, 2018, 4:35pm
5
You can change the Thing ID to match your old serial controller’s ID and all your recreated Things will retain the same ID as the old ones.
I can’t help much with the specific problems but wanted to make sure future readers see this and maybe avoid the same mistake.
Good luck!
sihui
(SiHui)
August 29, 2018, 5:30pm
6
I have several FGR222 running with the development version of the zwave binding, all is working well.
You need to find out what is wrong in your setup:
Do a bundle:list
through karaf and see if only one instance of the binding is active, if yes, clear cache and tmp folders and restart openHAB.
Also make sure you don’t have any errors in your openhab.log. Most likely you need to add the transport serial through karaf … but that is also described in the big dev thread you may have already found. If not do so now …
I assume you did read the posts regarding that you need to delete all things and readd them when switching to the dev binding … ?
Atsz
(Pedro Sánchez)
August 29, 2018, 5:47pm
7
Yes, I checked I had only the 2.4 instance active as a z-wave binding in the karaf bundle list, and I also added the transport serial. But I’m quite sure I forgot clearing the cache folder, I didn’t think it was important since I was creating new elements which didn’t exist before…I’ll try again when I have the time to set up again all my ~20 things and over 30 items… Sounds like hard work, but if you say yours are working all right, it’s worth trying.
Since I’m doing it all again, how did you do it? Paper UI or text files?
Thank you very much, I’ll tell you something when it’s done
PS: And yes, I noticed some people said you have to remove all things when switching to dev version, but as Rich Koshak says I though I would be able to change the bridge ID and go on. However I couldn’t find the option to edit the thing ID when adding it (maybe was there and I didn’t see it, maybe it was disabled) and it probably was a bad idea anyway, so I’ll try starting from scratch.
sihui
(SiHui)
August 29, 2018, 5:52pm
8
Atsz:
Just delete the things and readd them … 5 minutes work at most. Don’t exclude your devices!
Atsz:
Manual created zwave things are a bad idea because you cannot change any config parameters. PaperUI is working great for all my things …
Are you not using Visual Studio Code? You can replace your channel definitions with the new id in one minute …
Chri46
(Christian Berndt)
August 30, 2018, 7:09pm
10
Hi @Atsz
@sihui FYI
@chris FYI
This isssue is already looked into:
https://community.openhab.org/t/fibaro-roller-shutter-fgrm-222-with-venetian-blinds-lamellas-position/9396/245
I am on development build as well and am seeing the same as reported in your post.
I suggest to merge with the older topic.
sihui
(SiHui)
August 30, 2018, 7:45pm
11
I don’t get your point: the topic you are referring to is about Lamella position.
In this topic we are talking about
I’m using several FGR222 since a long time with different zwave builds and they are reporting a new state triggered by the hardware switches instantly.
Chri46
(Christian Berndt)
August 30, 2018, 9:02pm
12
I am referring to the comment on the “unknown command class” in the first post.
I am obsevering the exact same when using the HW switches - regardless if just changing the tilt or completely raising/lowering the blinds.
OH is completely unaware of the actions triggered by HW switches (toggle switches in my case).
And I am neither receiving usable updates immediately after HW are used nor after regular update/polling interval.
I was sharing both “tilt only” and full raise/lower logs in the other topic.
From my point of view those issues are originating from the same root cause.
OH not able to interpret “manufacturer proprietary” messages which are sent by fgr-222 after using HW switches.
Please review my posts on the other topic to get an insight of the issue am I (and others) are describing in the topic.
sihui
(SiHui)
August 31, 2018, 4:50am
13
Still works fine here and always has …
Chri46
(Christian Berndt)
August 31, 2018, 5:54am
14
@sihui :
never worked - I am using OH since version 2.1 and switched to zwave development release once the lamella support was introduced (now on 2.3 release build and ZWave Binding 2.4.0.201808210909)
Are you able to share your configuration and version of FGR-222?
sihui
(SiHui)
August 31, 2018, 6:05am
15
One out of six:
Please note that I don’t use the lamella function. If the problem is related to that, I can’t help because I can’t test
Atsz
(Pedro Sánchez)
August 31, 2018, 6:11am
16
It seems I’m having the same problem as @Chri46 . About @sihui config, I have different values for parameter 14 (toggle switch) and 50 (associations instead of scenes).
@sihui , when you say that it always has been working, you mean for every version of the binding in the past?
sihui
(SiHui)
August 31, 2018, 6:14am
17
Yes. I bought those almost two years ago and they always have been working fine.
But as noted above: I have never used the lamella function!
Atsz
(Pedro Sánchez)
August 31, 2018, 6:27am
18
I’m not using the lamella function either. It could be related to your Fibaros containing a different firmware version than ours despite being the same FGR 222 product. I bought mine about 6 months ago, so it would make sense…
sihui
(SiHui)
August 31, 2018, 6:36am
19
If your firmware is different than 25.25. and has different functions/parameters we need to add that to the database.
Please compare your xml file against mine and try to find the differences:
<node>
<homeId>0xc239030a</homeId>
<nodeId>11</nodeId>
<version>4</version>
<manufacturer>0x10f</manufacturer>
<deviceId>0x1000</deviceId>
<deviceType>0x302</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_METER</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_PROPRIETARY</commandClass>
<commandClass>COMMAND_CLASS_PROTECTION</commandClass>
<commandClass>COMMAND_CLASS_MARK</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTIVATION</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_MULTILEVEL</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_CLASS_B_MOTOR_CONTROL</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses>
<entry>
<COMMAND__CLASS__SCENE__ACTIVATION>
<version>0</version>
<instances>0</instances>
<control>false</control>
<versionSupported>0</versionSupported>
</COMMAND__CLASS__SCENE__ACTIVATION>
</entry>
<entry>
<multiLevelSwitchCommandClass>
<version>3</version>
<instances>1</instances>
<versionSupported>3</versionSupported>
<switchTypePrimary>CLOSE_OPEN</switchTypePrimary>
<switchTypeSecondary>DOWN_UP</switchTypeSecondary>
<isGetSupported>true</isGetSupported>
</multiLevelSwitchCommandClass>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
<version>1</version>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters>
<entry>
<int>32</int>
<configurationParameter>
<index>32</index>
<size>1</size>
<value>0</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>33</int>
<index>33</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>35</int>
<index>35</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>40</int>
<index>40</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>10</int>
<index>10</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>42</int>
<index>42</index>
<size>2</size>
<value>3600</value>
</entry>
<entry>
<int>43</int>
<index>43</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>12</int>
<index>12</index>
<size>2</size>
<value>150</value>
</entry>
<entry>
<int>44</int>
<index>44</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>13</int>
<index>13</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>14</int>
<index>14</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>17</int>
<index>17</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>18</int>
<index>18</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>50</int>
<index>50</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>22</int>
<index>22</index>
<size>2</size>
<value>240</value>
</entry>
<entry>
<int>29</int>
<index>29</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>30</int>
<index>30</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>31</int>
<index>31</index>
<size>1</size>
<value>0</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_HAIL</commandClass>
<COMMAND__CLASS__HAIL>
</COMMAND__CLASS__HAIL>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>271</deviceManufacturer>
<deviceType>770</deviceType>
<deviceId>4096</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<version>2</version>
<versionSupported>2</versionSupported>
<maxGroups>3</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__METER>
<meterType>ELECTRIC</meterType>
<meterScales>
<meterScale>E_W</meterScale>
<meterScale>E_KWh</meterScale>
</meterScales>
<canReset>true</canReset>
<isSupportRequestSupported>true</isSupportRequestSupported>
</COMMAND__CLASS__METER>
</entry>
<entry>
<COMMAND__CLASS__PROTECTION>
<localModes>
<localProtection>UNPROTECTED</localProtection>
<localProtection>PROTECTED</localProtection>
</localModes>
<rfModes>
<rfProtection>UNPROTECTED</rfProtection>
<rfProtection>NORFCONTROL</rfProtection>
</rfModes>
</COMMAND__CLASS__PROTECTION>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__MULTILEVEL>
<sensors>
<entry>
<multilevelSensorType>POWER</multilevelSensorType>
<multilevelSensor>
<sensorType>POWER</sensorType>
<initialised>true</initialised>
</multilevelSensor>
</entry>
</sensors>
</COMMAND__CLASS__SENSOR__MULTILEVEL>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__BINARY>
</COMMAND__CLASS__SWITCH__BINARY>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
<maxGroups>2</maxGroups>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>3.52</protocolVersion>
<applicationVersion>25.25</applicationVersion>
</COMMAND__CLASS__VERSION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>10</int>
<int>12</int>
<int>13</int>
<int>26</int>
<int>30</int>
<int>31</int>
<int>32</int>
<int>33</int>
<int>34</int>
<int>36</int>
<int>37</int>
<int>39</int>
<int>40</int>
<int>41</int>
<int>42</int>
<int>43</int>
<int>44</int>
</nodeNeighbors>
<lastReceived>2018-08-30 23:46:26.219 UTC</lastReceived>
</node>
Atsz
(Pedro Sánchez)
August 31, 2018, 7:10am
20
I’ve checked and firmware version it’s just the same, 25.25…
Here is my xml definition:
<node>
<homeId>0xe613d27e</homeId>
<nodeId>2</nodeId>
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>0</int>
<endPoint>
<deviceClass>
</deviceClass>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<sensors>
<entry>
<multilevelSensor>
</multilevelSensor>
</entry>
</sensors>
</entry>
<entry>
</entry>
<entry>
<localModes>
</localModes>
<rfModes>
</rfModes>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<configParameters>
<entry>
<int>32</int>
<index>32</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>33</int>
<index>33</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>35</int>
<index>35</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>40</int>
<index>40</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>10</int>
<index>10</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>42</int>
<index>42</index>
<size>2</size>
<value>3600</value>
</entry>
<entry>
<int>43</int>
<index>43</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>12</int>
<index>12</index>
<size>2</size>
<value>150</value>
</entry>
<entry>
<int>44</int>
<index>44</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>13</int>
<index>13</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>14</int>
<index>14</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>17</int>
<index>17</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>18</int>
<index>18</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>50</int>
<index>50</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>22</int>
<index>22</index>
<size>2</size>
<value>240</value>
</entry>
<entry>
<int>29</int>
<index>29</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>30</int>
<index>30</index>
<size>1</size>
<value>2</value>
</entry>
<entry>
<int>31</int>
<index>31</index>
<size>1</size>
<value>0</value>
</entry>
</configParameters>
</entry>
<entry>
</entry>
<entry>
<meterScales>
</meterScales>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<control>true</control>
</entry>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2018-08-29 14:58:39.934 UTC</lastReceived>
Chri46
(Christian Berndt)
August 31, 2018, 7:21am
21
Bought mine more than a year ago and all 9 FGR-222 I am using are showing 25.25 firmware version.
Main differences in configuration:
3: Blind position with Fibar Command (for Lamella support)
10: Venetian Blind Mode, with Positioning
14: Toggle Switches
50: Associations Active
I did compare your xml with one of my FGR-222, but did not spot any obvious difference.
network_e117085e__node_13.xml (17.0 KB)
Since I am using venetian blinds I need lamella support and therefore parameter 3 and 10 are set accordingly.
@Atsz : Since you are not using lamella support, there is no need to set parameter 3 to Blind position with Fibar Command, try changing 3 to Blind position with Z-Wave command. (the xml you provided states:
<int>3</int>
<index>3</index>
<size>1</size>
<value>1</value>
</entry>
and it should be set to (from sihui’s xml):
<int>3</int>
<index>3</index>
<size>1</size>
<value>0</value>
</entry>
Atsz
(Pedro Sánchez)
August 31, 2018, 7:29am
22
You’re right @Chri46 , but I’ve already tried both values for that parameter. I just forgot to set it back to Z-Wave command…
Chri46
(Christian Berndt)
August 31, 2018, 7:43am
23
setting parameter 3 to Blind position with Fibar Command the fibar proprietary reports you are observing are triggered.
to collect full logs please in karaf run
log:set DEBUG org.openhab.binding.zwave
and upload the openhab.log to Z-Wave log viewer while using the HW switches.
The log viewer significantly improves readability and helps troubleshooting.
after collecting logs:
run log:set DEFAULT org.openhab.binding.zwave
Atsz
(Pedro Sánchez)
September 24, 2018, 7:51am
24
Ok, so it’s been a while but I finally could try starting from scratch (delete all Z-Wave things, install new binding, add things again) using the latest version of Z-Wave binding (2.4) and now all my Fibaro Rollershutters report manual interactions. Thanks for your help!
