After a crashed SD card, I created a new card using openhabian-pi-raspios32-202308121256-gitc6a2fa1-crcc361b879.img.xz for use on my Raspberry Pi 4. I then restored my configuration from a backup.
Things are almost back to normal except I am seeing unwanted “updated to” entries in the log (I added the asterisks):
2023-09-20 15:45:09.895 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Foyer_Dimmer' **updated to 0**
2023-09-20 15:45:09.908 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Basement_Bedroom_Ceiling_Dimmer' **updated to 0**
2023-09-20 16:00:00.621 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'TPLINK_Dimmer_outlet1_Brightness' received command 20
2023-09-20 16:00:00.625 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'TPLINK_Dimmer_outlet1_Brightness' predicted to become 20
2023-09-20 16:00:00.628 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'TPLINK_Dimmer_outlet1_Brightness' **updated to 20**
2023-09-20 16:00:00.630 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TPLINK_Dimmer_outlet1_Brightness' changed from 5 to 20
2023-09-20 16:00:00.910 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'TPLINK_Dimmer_outlet1_Brightness' **updated to 20**
2023-09-20 16:30:00.602 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'TPLINK_Dimmer_outlet1_Brightness' received command 5
2023-09-20 16:30:00.605 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'TPLINK_Dimmer_outlet1_Brightness' predicted to become 5
2023-09-20 16:30:00.609 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'TPLINK_Dimmer_outlet1_Brightness' **updated to 5**
2023-09-20 16:30:00.611 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TPLINK_Dimmer_outlet1_Brightness' changed from 20 to 5
2023-09-20 16:30:00.888 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'TPLINK_Dimmer_outlet1_Brightness' **updated to 5**
2023-09-20 16:45:09.854 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'TPLINK_Dimmer_outlet1_Brightness' **updated to 5**
2023-09-20 16:45:09.962 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Foyer_Dimmer' **updated to 0**
2023-09-20 16:45:10.047 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Basement_Bedroom_Ceiling_Dimmer' **updated to 0**
I realize I can change the refresh rate of a thing, but that’s not what I want to do. Where do I tell OH not to log such events? My OH3 configuration didn’t show these entries.
