Platform information:
- Hardware: RPi 4 4GB
- OS: DietPi (latest version)
- Java Runtime Environment: ???
- openHAB version: 2.5
Issue of the topic: please be detailed explaining your issue
I installed frontail on my Dietpi Pi4 to log openhab over my browser at work. I setup frontail with help of this board [SOLVED] Logview on ubuntu and some changes I entered in the service-file. When I start the service my Pi say it runs but when I try to open the browser there is no connection (page not found). When I start frointail manualy without the servicefile it works. Where is my error? -
Please post configurations (if applicable):
frontail.service
#!/bin/sh - [Unit] Description=Frontail After=openhab2.service [Service] ExecStart=/usr/local/bin/frontail --ui-highlight -t dark /opt/openhab2/userdata/logs/openhab.log /opt/openhab2/userdata/logs/events.log Restart=always User=root Group=root Environment=PATH=/usr/local/bin/ Environment=NODE_ENV=production WorkingDirectory=/usr/local/bin/ [Install] WantedBy=multi-user.target Alias=frontail.service
systemctl status frontail.service
root@DietPi:~# systemctl status frontail.service
frontail.service - Frontail
Loaded: loaded (/lib/systemd/system/frontail.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-08-24 14:03:16 CEST; 295ms ago
Main PID: 1906 (node)
Tasks: 7 (limit: 4915)
CGroup: /system.slice/frontail.service
└─1906 node /usr/local/bin/frontail --ui-highlight -t dark /opt/openhab2/userdata/logs/openhab.log /opt/openhab2/userdata/logs/events.log
