Fujitsu / General Binding
Hi everyone, I can’t find any binding for fujtsu air conditioners with wi-fi module.
Is there any binding that allows access to the Fujitsu cloud?
Thanks in advance…
Michele
From a quick search I found:
but have no idea it that works with your ac.
No, RAC and VRF are industrial air conditioners, I was interested in a binding for domestic air conditioners.
Inside each air conditioner has a wi-fi module and
to control them remotely you use the AirStage app, which is the same one used for General air conditioners.
The Intesis Binding is local control only.
Those WiFi adapters are used in several AC brands.
No Intesis doesn’t work.
The only password I have available is the wifi connection password. There is no webserver password, they have no webserver (the web server is only for connecting to the AP)
What is the type of the WiFi Adapter and AC unit?
The stick is marked: AP-WH3E-XXXXXXXX where XX is the MAC Address.
UTY-TFSXH3 (AP-WH3E)
Here you can find the manual:
English manual please😉
Dongle:
Air conditioner manual:
Unfortunately there is no reference to the manufacturer…
Consider that not even discovery online suggests a binding for these devices, it doesn’t see them at all (I have 9 air conditioners)
Quick search lead me to a working HA integration, so in general, it would be possible to write a binding.
Unfortunately, I neither do have the device for testing, nor do I have time to develop a Binding for it.
But you can try some of the commands here
Something news about binding ?
I just found a solution how to integrate the AC given above into openhab. Please refer here: Fujitsu Airstage Control
