i measure my natural gas consuption using a pulse sensor attached to my meter.1 pulse is giving me a 0.01 m³.So i made that rule to set a counter for my gas
Number:Volume Total_gas "Total_gas"
rule "Gas_sensor"
Item Gassensorpulse changed
var gas_unit = Total_gas.state as Number + 0.01
Total_gas.postUpdate(gas_unit)
that way it works but i get a plain number without a unit (m³).What do i have to change to convert the number to a number with a unit?
rule "Gas_sensor"
Item Gassensorpulse changed to CLOSED
or
Item test changed
var Number gas_unit = Total_gas.state as Number + 0.01 | m³
but not changed
2022-02-15 15:00:11.800 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Total_gas' changed from 5718.62 to 5718.63
is not a smart thing to do with it, destroying its “quantity flavour”. var Number gas_unit = ...
and here you’re asking for the result as non-quantity too. In general, just let the system sort that part out.
This should be fairly bombproof var gas_unit = Total_gas.state as QuantityType<Volume> + 0.01 | m³
but you might have a problem with your starting value
which seems to have no units to begin with.
I suppose that’s a leftover from previous attempts.
I suspect this might get you out of that hole - var gas_unit = 0.01 | m³ + Total_gas.state as QuantityType<Volume>
as it usually gives the result in the units of the first operand
