I refreshed gCal bindings by adding Oauth2 support and upgraded Google Calendar API. This change has been requested to merge to official code, but I need some volunteers to test changes before code will be merged.
start OpenHAB first time and follow information from console. You must login to provided URL and put provided code to authorize openHAB to use your google calendar.
If you want to use alternate calendar (e.g shared calendar) just put calendar name in openhab.cfg under gcal:calendar_name
if you want to create own google credentials please follow tutorial
to create project and Credential. IMPORTANT - Under Application type choose OTHER
When credentials are created click Library ā Calendar API ā Enable API
Thank you very much for refreshing this service so people can schedule commands and updates in the future from their Google Calendar, without having to go through IFTTT or CalDAV.
I have some observations using your provided JAR:
Itās very convenient to use your Google API credentials for the purpose of testing (in Step 3 above), but users should be informed that this is what they are entering into their openhab.cfg file (just for the sake of disclosure and to understand the potential ramifications).
The steps to create oneās own credentials should probably be spelled out in greater detail, as there are some pitfalls along the way. I downloaded the file client_id.json and used the id and secret in that file. Was that correct?
I think I did it right because this appeared in the log:
[INFO ] [g.internal.GCalEventDownloader] - ################################################################################################
[INFO ] [g.internal.GCalEventDownloader] - # Google-Integration: U S E R I N T E R A C T I O N R E Q U I R E D !!
[INFO ] [g.internal.GCalEventDownloader] - # 1. Open URL 'https://www.google.com/device'
[INFO ] [g.internal.GCalEventDownloader] - # 2. Type provided code ZPWT-UVXXS
[INFO ] [g.internal.GCalEventDownloader] - # 3. Grant openHAB access to your Google calendar
[INFO ] [g.internal.GCalEventDownloader] - # 4. openHAB will automatically detect the permiossions and complete the authentication process
[INFO ] [g.internal.GCalEventDownloader] - # NOTE: You will only have 1800 mins before openHAB gives up waiting for the access!!!
I authorized the app against my Google account and I received no warnings or errors in doing so. However, following the instructions in the wiki page, the command was not sent at the intended time (or yet). The only message logged was the one shown above. This test was performed on openHAB 1.8.3 runtime.
I think peopleās ability to make use of your excellent contribution will succeed or fail based on the quality of the documentation explaining how to use it. I see the wiki page is very out of date, and seems to describe the current state (before your PR) as essentially unusable. So I donāt see any reason not to update the wiki now, with very clear and complete documentation for how to succeed.
Just an update to report that the GCal service worked!
After my report 4 days ago which didnāt appear to work, I have since restarted the openHAB server and made another test, and it worked just fine. Thank you @SirAd.
I would really encourage others to try it out. If you are a Google Calendar user, you can use either your default calendar, or make a special one, and schedule future events very easily this way.
To polish up the wiki page and get more testing done, we can revive this very useful openHAB component!
I was able to get this set up in OH2. However, itās not executing the scheduled commands.
I see this in the log, which all looks good to me.
2016-11-12 09:23:38.148 [DEBUG] [io.gcal.internal.GCalEventDownloader] - found 1 calendar events to process
2016-11-12 09:23:38.148 [DEBUG] [io.gcal.internal.GCalEventDownloader] - given event content doesn't match regular expression to extract start-, end commands - using whole content as startCommand (send PS15Z_Switch ON)
2016-11-12 09:23:38.149 [INFO ] [io.gcal.internal.GCalEventDownloader] - created new startJob 'Turn on PS15Z_Switch' with details 'SchedulerJob [jobKey=xxxxxxxxxxxxxxxxx@google.com_start, jobGroup=gcal, 1 triggers=[Sat Nov 12 09:30:00 EST 2016], content=send PS15Z_Switch ON'
2016-11-12 09:30:00.001 [DEBUG] [gcal.internal.util.ExecuteCommandJob] - About to execute CommandJob with arguments [send, PS15Z_Switch, ON, ]
The binding makes a call to this static method to execute the command, which doesnāt seem to be working.
ConsoleInterpreter.handleRequest(args, new LogConsole());
OTOH, if I run send PS15Z_Switch ON from the karaf console, it works.
Found it! I think the code should be refactored to remove use of ConsoleInterpreter, and have the GCal code do the work instead. @Kai, any advice otherwise?
* This class provides generic methods for handling console input (i.e. pure strings).
* NOTE: This class is only kept for backward compatibility so that openHAB 1 Add-ons still compile.
* It must not be used productively!
* @author Kai Kreuzer
* @since 0.4.0
Thatās great news! Is there a list of attributes, the GCal Binding can get from the google API?
thatās (apart from perfomance) is one of the main advantages over the CalDAV-binding: getting all meta-information, such as alerts. Iād like to use the calender also as trigger - and using not only the beginning of an event as an trigger, but the actual alert is a great advantage.
Iāll try to install the changed binding and get back with results.
The GCal binding isnāt actually a binding. Its job is to read calendar events from a Google Calendar, and then interpret the contents of each entryās description field as a set of instructions to perform when the event starts and optionally ends. The GCal persistence service works with it to write instructions to perform in the future to future calendar entries, say a week in the future. The GCal ābindingā will then perform those instructions in the future just like manually added calendar entries.
The latest code only works on the 1.8 runtime; changes are in process to have it work on 2.0 as well.
at the time of the respective alert let the loudspeaker in the house tell you to leave the house for the appointment
send direct commands to items (e.g. heating, lighting, ā¦)
I had some logic like this with smarthome.py, but was restricted as the alerts donāt whow up in ical-files. So the time to leave the house for school would be the same as the time to leave the house for the doctor (which is way farther, so the alert is way earlier).
Unfortunately, Iām using OH2, so if I understand correctly at present state the plugin wonāt work?
Your use cases are met by the GCal service, and it will soon be updated to function properly on OH2. Right now the code will do everything except actually perform the update, command or run the script expression. You can track progress towards OH2 compatibility here:
Yes, there is possibility to fetch extra information from event (e.g. reminders configuration). This implementation does not use it, but it would be possible to implement additional trigger based on reminder. You can use Google API playground available https://developers.google.com/oauthplayground/ to see what attributes are exposed by API
You can put the JAR in your addons directory and it ought to install and start. Note that if you want to also use GCal persistence, you will need that bundle as it was updated as well. Please let us know how it works for you!
Iām getting
2016-12-03 14:00:23.978 [ERROR] [b.core.service.AbstractActiveService] - Error while executing background thread Google Calender Event-Downloader
java.lang.NullPointerException
at org.openhab.io.gcal.internal.GCalEventDownloader.processEntries(GCalEventDownloader.java:295)[238:org.openhab.io.gcal:1.9.0.201612030211]
at org.openhab.io.gcal.internal.GCalEventDownloader.execute(GCalEventDownloader.java:140)[238:org.openhab.io.gcal:1.9.0.201612030211]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173)[204:org.openhab.core.compat1x:2.0.0.201612010742]
