TomR
(TomR)
February 28, 2021, 1:17pm
#1
Hello everybody! I’m trying to use OH3 with my FENECON FEMS Controller, which provides Data from my PV-Battery via REST-call.
I do the following test on linux commandline:
curl http://x:user@192.168.0.227:8084/rest/channel/_sum/ConsumptionActivePower
as result I got
{"address":"_sum/ConsumptionActivePower","type":"INTEGER","accessMode":"RO","text":"","unit":"W","value":591}
Now I use the http-Binding with this settings:
UID: http:url:FEMS
label: HTTP URL Thing
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: true
baseURL: http://192.168.0.227:8084
password: user
refresh: 5
commandMethod: GET
contentType: application/json
timeout: 3000
username: x
bufferSize: 2048
channels:
- id: Verbrauch_Haus
channelTypeUID: http:number
label: Energie
description: ""
configuration:
mode: READONLY
stateExtension: /rest/channel/_sum/ConsumptionActivePower
stateTransformation: JSONPATH:value.$
I got this errormessage:
2021-02-28 14:15:29.672 [WARN ] [p.internal.http.HttpResponseListener] - Requesting 'http://192.168.0.227:8084/rest/channel/_sum/ConsumptionActivePower' (method='GET', content='null') failed: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
Where is the problem?
The username is “x” and the password is “user”.
I have no Idea what I’m doing wrong with this binding?
Thanks a lot for your support!
Wolfgang_S
(Wolfgang_S)
February 28, 2021, 6:49pm
#2
Have a look to [SOLVED] OH3: http authentication issue could be that it is the same issue which seems to be solved in the snapshot of the binding.
TomR
(TomR)
March 1, 2021, 7:10am
#3
Thank you @Wolfgang_S for your hint! I try, but it won’t help.
It’ a bit strange, because I do the update, but in the adminview of OH3 (Settings / Addons / Bindings ) I got still the versioninfo 3.0.1 in case of 3.1.0.
Reboot of the machine was done, no change.
When I got the the OH-konsole and do
bundle:list -s |grep http
I got (beneath others) :
279 | Active | 80 | 3.1.0.202103010326 | org.openhab.binding.http
So the binding itself has 3.1.0, but how can I “say” OH to use this one?!
opus
(Jürgen Baginski)
March 1, 2021, 7:25am
#4
I would guess that the console is correct. Do you or did you have a http binding .jar in the addons folder?
TomR
(TomR)
March 1, 2021, 2:19pm
#5
There was a file openhab-addons-3.0.1.kar in the addons-folder.
I put it away and made a reboot, but it’s still shows 3.01 at the http-binding.
Now I testet the bundle:list again:
openhab> bundle:list -s |grep http
292 | Waiting | 80 | 3.0.1 | org.openhab.binding.http
So it looks like there are “peaces” of the 3.0.1-Binding still there - maybe I have to remove it somehow?
opus
(Jürgen Baginski)
March 1, 2021, 2:23pm
#6
I’d try bundle:uninstall 292
(more a guess then an advice).
TomR
(TomR)
March 1, 2021, 3:20pm
#7
I do clear the cache of OH3, now it looks like this:
147 | Active | 80 | 3.0.1 | org.openhab.core.io.http
148 | Active | 80 | 3.0.1 | org.openhab.core.io.http.auth
220 | Active | 80 | 4.1.42.Final | io.netty.codec-http
277 | Active | 80 | 3.1.0.202103010326 | org.openhab.binding.http
Only the correct 3.1.0-http-Binding is there - but in the frontend still the 3.0.1 is shown.
And the error with the
is also still there…very strange.
opus
(Jürgen Baginski)
March 1, 2021, 4:10pm
#8
Very strange, indeed!
I’d try:
uninstall/install the http binding from MainUI, if this doesn’t help
bundle:update
for the two weird bundles, after that
TomR
(TomR)
March 1, 2021, 10:50pm
#9
Uninstall / install the http binding brings back the 3.0.1-Version in the konsole.
After that I make the update via konsole via
update org.openhab.binding.http https://ci.openhab.org/job/openHAB-Addons/lastSuccessfulBuild/artifact/bundles/org.openhab.binding.http/target/org.openhab.binding.http-3.1.0-SNAPSHOT.jar
And it’s still the 3.01 in the frontend…I have no idea, whats went wrong. -(
TomR
(TomR)
March 2, 2021, 6:44am
#10
Maybe a little bit off-top in this thread: how can I update to the 3.1.0 milestone-build 2?
I have a normal debian-installation.
Before I wasting more time in searching ghosts…
opus
(Jürgen Baginski)
March 2, 2021, 7:15am
#11
TomR
(TomR)
March 2, 2021, 9:07pm
#12
After the update to OH 3.1 M2 it works without a problem.
Thank you for your support.
