Google Home Error linking openHAB account
I had successfully linked Google Home to openHAB a while ago, but then for some reason, I was unable to connect my Google Home to openHAB.
So I unlinked the device, and tried to add openHAB again.
After allowing the OAUth2 application authorisation, I get a
“Linking your openHab account” message, that is shortly followed by
“couldn’t update the settting. Check your connection”
When I log on to myopenHAB, I can see the the Google assistant voice control has been added to the account as an application, but the Home app (android), is not adding the device.
I’m using the latest Home app (1.29.20.20) and am at a loss to know where to start identifying the cause of the problem and find a solution. The “Check your connection” message doesn’t make sense, given that to add the device, I’ve logged onto my openHAB account, and successfully allowed OAuth2.
Did you solve this problem?
hello,
I have the same problem :frowning:
Still down for me.
Mine is working again now
I have restarted openhab, removed google assistant from the myopenhab site and also removed openhab from Google and readded both
I tried the same steps, but didn’t work for me..:frowning:
I’m having the same issue. The moment when I authorize Google Assitant on Myopenhab, the following error lines appear in my logs. Do you have any idea? (BTW, I have a standard openHABian environment.)
2018-06-11 20:04:59.932 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-06-11 20:04:59.938 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 3033051 failed: Connection refused
2018-06-11 20:04:59.943 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-06-11 20:04:59.947 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-06-11 20:05:00.037 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-06-11 20:05:00.050 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 3033052 failed: Connection refused
2018-06-11 20:05:00.060 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-06-11 20:05:00.086 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
I’m on Xubuntu Linux (desktop computer), Xulu (latest), and OH2.4.0 1308 snapshot, and I too have “connection refused” errors and warnings. Strange that it is both an error and a warning.
2018-07-05 23:11:10.057 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-voice-mactts'
2018-07-05 23:12:08.562 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-misc-ruleengine'
2018-07-05 23:14:15.701 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:15.704 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 17029647 failed: Connection refused
2018-07-05 23:14:15.705 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:15.706 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:15.918 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:15.919 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 17029649 failed: Connection refused
2018-07-05 23:14:15.920 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:36.061 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:36.067 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 17029721 failed: Connection refused
2018-07-05 23:14:36.067 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:36.272 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:36.273 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 17029722 failed: Connection refused
2018-07-05 23:14:36.273 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:36.274 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:48.895 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:48.896 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 17029788 failed: Connection refused
2018-07-05 23:14:48.897 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:49.084 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:49.085 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 17029789 failed: Connection refused
2018-07-05 23:14:49.085 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:14:49.087 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:15:05.619 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:15:05.620 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 17029878 failed: Connection refused
2018-07-05 23:15:05.620 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:15:05.871 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:15:05.872 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 17029880 failed: Connection refused
2018-07-05 23:15:05.873 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:20:29.158 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 11: Already processed another send data request for this callback Id, ignoring.
2018-07-05 23:43:14.073 [ERROR] [io.openhabcloud.internal.CloudClient] - Connection refused
2018-07-05 23:43:14.074 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 17039378 failed: Connection refused
2018-07-05 23:43:14.075 [WARN ] [io.openhabcloud.internal.CloudClient] - Connection refused
It seems that my problem was caused because i don’t use openhab with the default http ports. The https was working but the http isn’t but i wasn’t aware of this problem because I always used the https port. Now i fixed the http problem and the Google Assistant is working.
I’m trying to integrate my Google Home and see the same errors. I haven’t changed any standard ports, I’m on http (not https). What can be wrong, where to look?
To add to it - my cloud connector seems working well:
  • notifications have been working fine for a long time
  • I created a test item (to make it [ “Switchable” ]) I can see it state being changed in the event log on the myopenhab.org website.
    For whatever reason when Google tries to connect to it to make initial pairing, the Jetty rejects connection…
Edit - I’m getting the same error when trying to access the web link
" You are using openHAB 2.x. Click here to access your openHAB’s dashboard"
Edit2 - I reinstalled connector, I recreated myopenhab.org account (2x) and still same error. There must be someone who knows how to bite this problem. I noticed that OpenHAB app (Android) is failing with the same error when connecting remotely. Notifications work ok though. I started having impression that I’m missing some piece of configuration eventhough none of the official guides state anything in addition to what I’ve done.
I’m thinking - can it have anything to do with this:
2019-02-19 06:01:49.390 [WARN ] [.jetty.internal.ServerControllerImpl] - SSL password and SSL keystore password must be set in order to e          nable SSL.
2019-02-19 06:01:49.426 [WARN ] [.jetty.internal.ServerControllerImpl] - SSL connector will not be started
Hey,
check this one:
maybe it is your issue too
