I tried to boot up openHAB 2 which looks promising.
I didnt found a binding for GPIO within the release.
Is this feature dropped in openHAB 2?
I doubt it would be dropped. I might not yet be ported however.
It is not about porting them, it is about testing them and adding them to the distro.
I noticed that this wasn’t yet well documented, which I have just done here now:
https://github.com/openhab/openhab-distro/blob/master/docs/sources/features/compatibilitylayer.md#how-to-use-openhab-1x-add-ons-that-are-not-part-of-the-distribution
I was wondering if someone did try the GPIO Binding in the meantime?
I’d love to test it myself, but my time to play with it is very limited -.-
Well, thanks to an other sleepless night I was able to test it.
It works for me using the latest Jenkins build #1203
org.openhab.binding.gpio-1.9.0-SNAPSHOT.jar
org.openhab.io.gpio-1.9.0-SNAPSHOT.jar
Just put it in the addons folder, make sure to unexport the GPIOs before starting OH2 and it works.
I use the binding to realize a switch item:
Switch Rasen1 “Rasen rechts” {gpio=“pin:4” }
Thanks, that’s good news!
@maintainer Anybody willing to add it to the distro then?
@maintainer To make it easier for everybody, I have just enhanced the documentation on how to add a binding to the distro.
If nothing changed recently openHAB is still using the Eclipse SmartHome as its core framework.
“openHAB 2 used Eclipse SmartHome”… used => uses
Thanks, why don’t you fix it yourself next time?
I’m having problems getting it to work at all. I had a working OpenHab 1 with GPIO then I wanted the Hue emulator which is only on version 2 so I upgraded.
I have got 2 working just fine, but not GPIO. It acts as if it the addon is ignored. What I’ve done is:
feature:install openhab-runtime-compat1x
Copied org.openhab.binding.gpio-1.8.2.jar and org.openhab.io.gpio-1.8.2.jar to /opt/openhab2/addons/
I copied my old openhab.cfg to /opt/openhab2/conf/services/
In the items file I have lines like this:
Switch BlindUp “26” (gBlinds) { gpio=“pin:26” }
The switches appear on the UI but no gpio is changed.
openhab2 is running as root
ls /sys/class/gpio/ gives:
export gpiochip0 gpiochip100 unexport
Which shows nothing is binding.
Controlling the gpio from the command line outside openhab works fine.
I see no errors in any logs that might suggest what the problem is.
This is with a Raspberry Pi 3 with Rasbian.
Any ideas?
Please try the 1.9 snapshot version of the binding instead!
Now you say that it sounds obvious!
I can’t find anywhere to download a 1.9 snapshot, I take it I need to set up the IDE and build it?
Edit: Found here: https://openhab.ci.cloudbees.com/job/openHAB1-Addons/lastSuccessfulBuild/artifact/bundles/
The nightly builds can be furnished from cloudbees. Search for “openhab cloudbees” and I’m sure you will find it.
Thanks, I grabbed the 1.9 snapshot. It would not work at first until I renamed the files to have no version number, i.e.:
$ ls /opt/openhab2/addons/
org.openhab.binding.gpio.jar org.openhab.io.gpio.jar README
Great!
Cool - so will you create a PR to add it to the distro then?
I will give it a go. It will take some time with some learning curves but I should be able to.
BTW, it stopped working after restarting. Tailing logs suggested it still had 1.8 hanging around so I did a fresh clean install of oh2 and copied over the files and it works now even after a restart. No need to rename any addon jar files either.
I’m stuck and need some help from someone:
I could make a pull request but it would be pulling something known to produce build errors.
Fixed. PR made.
i have the same Problem with GPIO after Updating Openhab2. I am using Openhab2 on Opehabian. That why it is maybe different with you. I found the folder Opt but under this Folder i did not find the different Folder (openhab2 or addons).
I found some folders with name Openhab2:
can you tell me what kind of folde i should put in? or did you yourself these folders?
Thank you for your help, i am waiting for your reply.
Great
QT
Hi QT
any luck?
